Revert "FIX: Heartbeat check per sidekiq process (#7873)"
Revert “FIX: Heartbeat check per sidekiq process (#7873)”
This reverts commit 340855da55c6cdb3b861a37fda11c01f0606552a.
diff --git a/app/jobs/regular/run_heartbeat.rb b/app/jobs/regular/run_heartbeat.rb
index 7b6bd65..364343d 100644
--- a/app/jobs/regular/run_heartbeat.rb
+++ b/app/jobs/regular/run_heartbeat.rb
@@ -2,8 +2,19 @@
 module Jobs
   class RunHeartbeat < Jobs::Base
+    sidekiq_options queue: 'critical'
+    def self.heartbeat_key
+      'heartbeat_last_run'
+    end
     def execute(args)
-      Demon::Sidekiq.trigger_heartbeat(args[:queue_name])
+      $redis.set(self.class.heartbeat_key, Time.new.to_i.to_s)
+    end
+    def self.last_heartbeat
+      $redis.get(heartbeat_key).to_i
diff --git a/app/jobs/scheduled/heartbeat.rb b/app/jobs/scheduled/heartbeat.rb
index efd8213..c1b8a8c 100644
--- a/app/jobs/scheduled/heartbeat.rb
+++ b/app/jobs/scheduled/heartbeat.rb
@@ -7,9 +7,7 @@ module Jobs
     every 3.minute
     def execute(args)
-      Demon::Sidekiq::QUEUE_IDS.each do |identifier|
-        Jobs.enqueue(:run_heartbeat, queue_name: identifier, queue: identifier)
-      end
+      Jobs.enqueue(:run_heartbeat, {})
diff --git a/config/unicorn.conf.rb b/config/unicorn.conf.rb
index 20d9f6d..85b2800 100644
--- a/config/unicorn.conf.rb
+++ b/config/unicorn.conf.rb
@@ -144,32 +144,25 @@ before_fork do |server, worker|
           @sidekiq_next_heartbeat_check ||= Time.new.to_i + @sidekiq_heartbeat_interval
           if @sidekiq_next_heartbeat_check < Time.new.to_i
-            @sidekiq_next_heartbeat_check = Time.new.to_i + @sidekiq_heartbeat_interval
-            restarted = false
+            last_heartbeat = Jobs::RunHeartbeat.last_heartbeat
+            restart = false
             if out_of_memory?
               Rails.logger.warn("Sidekiq is consuming too much memory (using: %0.2fM) for '%s', restarting" % [(max_rss.to_f / 1.megabyte), ENV["DISCOURSE_HOSTNAME"]])
-              Demon::Sidekiq.restart
-              restarted = true
+              restart = true
-            if !restarted
-                last_heartbeat = Demon::Sidekiq.get_queue_last_heartbeat(identifier)
-                if last_heartbeat < Time.new.to_i - @sidekiq_heartbeat_interval
-                  if demon = Demon::Sidekiq.demons.values.find { |d| d.identifier == identifier }
-                    STDERR.puts "Sidekiq heartbeat test for worker #{demon.pid} failed, restarting"
-                    Rails.logger.warn "Sidekiq heartbeat test for worker #{demon.pid} failed, restarting"
-                    demon.stop
-                    demon.start
-                    restarted = true
-                  end
-                end
-              end
+            if last_heartbeat < Time.new.to_i - @sidekiq_heartbeat_interval
+              STDERR.puts "Sidekiq heartbeat test failed, restarting"
+              Rails.logger.warn "Sidekiq heartbeat test failed, restarting"
+              restart = true
+            @sidekiq_next_heartbeat_check = Time.new.to_i + @sidekiq_heartbeat_interval
-            if restarted
+            if restart
+              Demon::Sidekiq.restart
               sleep 10
               force_kill_rogue_sidekiq
diff --git a/lib/demon/base.rb b/lib/demon/base.rb
index e118189..d162611 100644
--- a/lib/demon/base.rb
+++ b/lib/demon/base.rb
@@ -11,7 +11,6 @@ class Demon::Base
   def self.start(count = 1, verbose: false)
     @demons ||= {}
-    before_start(count)
     count.times do |i|
       (@demons["#{prefix}_#{i}"] ||= new(i, verbose: verbose)).start
@@ -38,10 +37,7 @@ class Demon::Base
-  def self.before_start(count)
-  end
-  attr_reader :pid, :parent_pid, :started, :index, :identifier
+  attr_reader :pid, :parent_pid, :started, :index
   attr_accessor :stop_timeout
   def initialize(index, rails_root: nil, parent_pid: nil, verbose: false)
diff --git a/lib/demon/sidekiq.rb b/lib/demon/sidekiq.rb
index 11fdf56..d6da3b5 100644
--- a/lib/demon/sidekiq.rb
+++ b/lib/demon/sidekiq.rb
@@ -3,38 +3,6 @@
 require "demon/base"
 class Demon::Sidekiq < Demon::Base
-  RANDOM_HEX = SecureRandom.hex
-  QUEUE_IDS = []
-  def self.queues_last_heartbeat_hash_key
-    @@queues_last_heartbeat_hash_key ||= "#{RANDOM_HEX}_queues_last_heartbeat_hash"
-  end
-  def self.trigger_heartbeat(name)
-    $redis.hset(queues_last_heartbeat_hash_key, name, Time.new.to_i.to_s)
-    extend_expiry(queues_last_heartbeat_hash_key)
-  end
-  def self.get_queue_last_heartbeat(name)
-    $redis.hget(queues_last_heartbeat_hash_key, name).to_i
-  end
-  def self.clear_heartbeat_queues!
-    $redis.del(queues_last_heartbeat_hash_key)
-  end
-    # cleans up heartbeat queues from previous boot up
-    Sidekiq::Queue.all.each { |queue| queue.clear if queue.name[/^\h{32}$/] }
-    count.times do
-      QUEUE_IDS << SecureRandom.hex
-    end
-  end
-  def self.extend_expiry(key)
-    $redis.expire(key, 60 * 60)
-  end
   def self.prefix
     "sidekiq"
@@ -44,11 +12,6 @@ class Demon::Sidekiq < Demon::Base
     blk ? (@blk = blk) : @blk
-  def run
-    @identifier = QUEUE_IDS[@index]
-    super
-  end
   private
   def suppress_stdout
@@ -73,7 +36,7 @@ class Demon::Sidekiq < Demon::Base
     options = ["-c", GlobalSetting.sidekiq_workers.to_s]
-    [['critical', 8], [@identifier, 8], ['default', 4], ['low', 2], ['ultra_low', 1]].each do |queue_name, weight|
+    [['critical', 8], ['default', 4], ['low', 2], ['ultra_low', 1]].each do |queue_name, weight|
       custom_queue_hostname = ENV["UNICORN_SIDEKIQ_#{queue_name.upcase}_QUEUE_HOSTNAME"]
       if !custom_queue_hostname || custom_queue_hostname.split(',').include?(`hostname`.strip)
diff --git a/spec/jobs/heartbeat_spec.rb b/spec/jobs/heartbeat_spec.rb
index c132e62..315fe41 100644
--- a/spec/jobs/heartbeat_spec.rb
+++ b/spec/jobs/heartbeat_spec.rb
@@ -2,7 +2,6 @@
 require 'rails_helper'
 require_dependency 'jobs/base'
-require_dependency 'demon/sidekiq'
 describe Jobs::Heartbeat do
   after do
@@ -11,14 +10,12 @@ describe Jobs::Heartbeat do
   it "still enqueues heartbeats in readonly mode" do
     freeze_time 1.week.from_now
-    Demon::Sidekiq.clear_heartbeat_queues!
-    Jobs.run_immediately!
     Discourse.enable_readonly_mode
-    queue = SecureRandom.hex
-    Demon::Sidekiq::QUEUE_IDS << queue
-    Jobs::Heartbeat.new.perform(nil)
-    expect(Demon::Sidekiq.get_queue_last_heartbeat(queue)).to eq(Time.new.to_i)
+    Sidekiq::Testing.inline! do
+      Jobs::Heartbeat.new.perform(nil)
+      expect(Jobs::RunHeartbeat.last_heartbeat).to eq(Time.new.to_i)
+    end
GitHub sha: e805d449
Revert "Revert "FIX: Heartbeat check per sidekiq process (#7873)""
