Revert "FIX: Incorrect search blurb when advanced search filters are used."
Revert “FIX: Incorrect search blurb when advanced search filters are used.”
This change was causing advanced search filters to disappear from the search input
This reverts commit 2e1eafae0647f6db439d6337b26d83edbca42865.
diff --git a/lib/search.rb b/lib/search.rb
index 8b86882..2525591 100644
--- a/lib/search.rb
+++ b/lib/search.rb
@@ -187,7 +187,7 @@ class Search
     @results = GroupedSearchResults.new(
       @opts[:type_filter],
-      term,
+      clean_term,
       @search_context,
       @include_blurbs,
       @blurb_length
diff --git a/lib/search/grouped_search_results.rb b/lib/search/grouped_search_results.rb
index 75f75ab..f523901 100644
--- a/lib/search/grouped_search_results.rb
+++ b/lib/search/grouped_search_results.rb
@@ -30,14 +30,12 @@ class Search
     attr_accessor :search_log_id
-    BLURB_LENGTH = 200
     def initialize(type_filter, term, search_context, include_blurbs, blurb_length)
       @type_filter = type_filter
       @term = term
       @search_context = search_context
       @include_blurbs = include_blurbs
-      @blurb_length = blurb_length || BLURB_LENGTH
+      @blurb_length = blurb_length || 200
       @posts = []
       @categories = []
       @users = []
@@ -74,7 +72,7 @@ class Search
-    def self.blurb_for(cooked, term = nil, blurb_length = BLURB_LENGTH)
+    def self.blurb_for(cooked, term = nil, blurb_length = 200)
       blurb = nil
       cooked = SearchIndexer.scrub_html_for_search(cooked)
@@ -93,11 +91,14 @@ class Search
       if term
-        if term =~ Regexp.new(Search::PHRASE_MATCH_REGEXP_PATTERN)
-          term = Regexp.last_match[1]
+        terms = term.split(/\s+/)
+        phrase = terms.first
+        if phrase =~ Regexp.new(Search::PHRASE_MATCH_REGEXP_PATTERN)
+          phrase = Regexp.last_match[1]
-        blurb = TextHelper.excerpt(cooked, term,
+        blurb = TextHelper.excerpt(cooked, phrase,
           radius: blurb_length / 2
diff --git a/spec/requests/search_controller_spec.rb b/spec/requests/search_controller_spec.rb
index ba24bf2..044e741 100644
--- a/spec/requests/search_controller_spec.rb
+++ b/spec/requests/search_controller_spec.rb
@@ -101,25 +101,6 @@ describe SearchController do
       expect(data['topics'][0]['id']).to eq(awesome_post.topic_id)
-    it "can search correctly with advanced search filters" do
-      awesome_post.update!(
-        raw: "#{"a" * Search::GroupedSearchResults::BLURB_LENGTH} elephant"
-      get "/search/query.json", params: {
-        term: 'order:views elephant', include_blurb: true
-      expect(response.status).to eq(200)
-      data = response.parsed_body
-      expect(data['posts'].length).to eq(1)
-      expect(data['posts'][0]['id']).to eq(awesome_post.id)
-      expect(data['posts'][0]['blurb']).to include('elephant')
-      expect(data['topics'][0]['id']).to eq(awesome_post.topic_id)
-    end
     it 'performs the query with a type filter' do
@@ -160,6 +141,7 @@ describe SearchController do
       it "should return the right result" do
           term: user_post.topic_id,
           type_filter: 'topic',
GitHub sha: cb1f8913
