Revert "Merge pull request from GHSA-hv9p-jfm4-gpr9"
Revert “Merge pull request from GHSA-hv9p-jfm4-gpr9”
This reverts commit b8340c6c8e50a71ff1bca9654b9126ca5a84ce9a.
diff --git a/app/assets/javascripts/discourse/controllers/email-login.js.es6 b/app/assets/javascripts/discourse/controllers/email-login.js.es6
deleted file mode 100644
index 5a025ce..0000000
--- a/app/assets/javascripts/discourse/controllers/email-login.js.es6
+++ /dev/null
@@ -1,29 +0,0 @@
-import { SECOND_FACTOR_METHODS } from "discourse/models/user";
-import { ajax } from "discourse/lib/ajax";
-import DiscourseURL from "discourse/lib/url";
-import { popupAjaxError } from "discourse/lib/ajax-error";
-export default Ember.Controller.extend({
-  secondFactorMethod: SECOND_FACTOR_METHODS.TOTP,
-  lockImageUrl: Discourse.getURL("/images/lock.svg"),
-  actions: {
-    finishLogin() {
-      ajax({
-        url: `/session/email-login/${this.model.token}`,
-        type: "POST",
-        data: {
-          second_factor_token: this.secondFactorToken,
-          second_factor_method: this.secondFactorMethod
-        .then(result => {
-          if (result.success) {
-            DiscourseURL.redirectTo("/");
-          } else {
-            this.set("model.error", result.error);
-        .catch(popupAjaxError);
diff --git a/app/assets/javascripts/discourse/routes/app-route-map.js.es6 b/app/assets/javascripts/discourse/routes/app-route-map.js.es6
index bfec70d..fe84822 100644
--- a/app/assets/javascripts/discourse/routes/app-route-map.js.es6
+++ b/app/assets/javascripts/discourse/routes/app-route-map.js.es6
@@ -177,7 +177,6 @@ export default function() {
   this.route("signup", { path: "/signup" });
   this.route("login", { path: "/login" });
-  this.route("email-login", { path: "/session/email-login/:token" });
   this.route("login-preferences");
   this.route("forgot-password", { path: "/password-reset" });
   this.route("faq", { path: "/faq" });
diff --git a/app/assets/javascripts/discourse/routes/email-login.js.es6 b/app/assets/javascripts/discourse/routes/email-login.js.es6
index 617de05..0000000
--- a/app/assets/javascripts/discourse/routes/email-login.js.es6
+++ /dev/null
@@ -1,11 +0,0 @@
-export default Discourse.Route.extend({
-  titleToken() {
-    return I18n.t("login.title");
-  model(params) {
-    return ajax(`/session/email-login/${params.token}`);
diff --git a/app/assets/javascripts/discourse/templates/email-login.hbs b/app/assets/javascripts/discourse/templates/email-login.hbs
index 1556a21..0000000
--- a/app/assets/javascripts/discourse/templates/email-login.hbs
+++ /dev/null
@@ -1,33 +0,0 @@
-<div class="container email-login clearfix">
-  <div class="pull-left col-image">
-    <img src={{lockImageUrl}} class="password-reset-img">
-  </div>
-  <div class="pull-left col-form">
-    <form>
-      {{#if model.error}}
-        <div class='alert alert-error'>
-          {{model.error}}
-        </div>
-      {{/if}}
-      {{#if model.can_login}}
-        {{#if model.second_factor_required}}
-          {{#second-factor-form
-            secondFactorMethod=secondFactorMethod
-            secondFactorToken=secondFactorToken
-            backupEnabled=model.backup_codes_enabled
-            isLogin=true}}
-            {{second-factor-input value=secondFactorToken secondFactorMethod=secondFactorMethod backupEnabled=backupEnabled}}
-          {{/second-factor-form}}
-        {{else}}
-          <h2>{{i18n "email_login.confirm_title" site_name=siteSettings.title}}</h2>
-          <p>{{i18n "email_login.logging_in_as" email=model.token_email}}</p>
-        {{/if}}
-        {{d-button label="email_login.confirm_button" action=(action "finishLogin") class="btn-primary"}}
-      {{/if}}
-    </form>
-  </div>
-</div>
diff --git a/app/assets/stylesheets/desktop/login.scss b/app/assets/stylesheets/desktop/login.scss
index 122d95e..86a46bf 100644
--- a/app/assets/stylesheets/desktop/login.scss
+++ b/app/assets/stylesheets/desktop/login.scss
@@ -267,7 +267,6 @@
 .password-reset,
-.email-login,
 .invites-show {
   .col-form {
     padding-left: 20px;
@@ -283,8 +282,7 @@
-.password-reset,
-.email-login {
+.password-reset {
   .col-form {
     padding-top: 40px;
diff --git a/app/assets/stylesheets/mobile/login.scss b/app/assets/stylesheets/mobile/login.scss
index ef6b808..4334699 100644
--- a/app/assets/stylesheets/mobile/login.scss
+++ b/app/assets/stylesheets/mobile/login.scss
@@ -182,7 +182,6 @@
 .password-reset,
-.email-login,
 .invites-show {
   margin-top: 30px;
   .col-image {
diff --git a/app/controllers/session_controller.rb b/app/controllers/session_controller.rb
index b48ee8a..3ea48ad 100644
--- a/app/controllers/session_controller.rb
+++ b/app/controllers/session_controller.rb
@@ -11,10 +11,10 @@ class SessionController < ApplicationController
     render body: nil, status: 500
-  before_action :check_local_login_allowed, only: %i(create forgot_password email_login email_login_info)
+  before_action :check_local_login_allowed, only: %i(create forgot_password email_login)
   before_action :rate_limit_login, only: %i(create email_login)
   skip_before_action :redirect_to_login_if_required
-  skip_before_action :preload_json, :check_xhr, only: %i(sso sso_login sso_provider destroy one_time_password)
+  skip_before_action :preload_json, :check_xhr, only: %i(sso sso_login sso_provider destroy email_login one_time_password)
   ACTIVATE_USER_KEY = "activate_user"
@@ -305,79 +305,49 @@ class SessionController < ApplicationController
-  def email_login_info
-    raise Discourse::NotFound if !SiteSetting.enable_local_logins_via_email
-    token = params[:token]
-    matched_token = EmailToken.confirmable(token)
-    if matched_token
-      response = {
-        can_login: true,
-        token: token,
-        token_email: matched_token.email
-      if matched_token.user&.totp_enabled?
-        response.merge!(
-          second_factor_required: true,
-          backup_codes_enabled: matched_token.user&.backup_codes_enabled?
-      end
-      render json: response
-    else
-      render json: {
-        can_login: false,
-        error: I18n.t('email_login.invalid_token')
-    end
-  end
   def email_login
     second_factor_token = params[:second_factor_token]
     second_factor_method = params[:second_factor_method].to_i
+    valid_token = !!EmailToken.valid_token_format?(token)
+    user = EmailToken.confirmable(token)&.user
-    if matched_token&.user&.totp_enabled?
+    if valid_token && user&.totp_enabled?
       if !second_factor_token.present?
-        return render json: { error: I18n.t('login.invalid_second_factor_code') }
-      elsif !matched_token.user.authenticate_second_factor(second_factor_token, second_factor_method)
+        @second_factor_required = true
+        @backup_codes_enabled = true if user&.backup_codes_enabled?
+        return render layout: 'no_ember'
+      elsif !user.authenticate_second_factor(second_factor_token, second_factor_method)
         RateLimiter.new(nil, "second-factor-min-#{request.remote_ip}", 3, 1.minute).performed!
+        @error = I18n.t('login.invalid_second_factor_code')
     if user = EmailToken.confirm(token)
       if login_not_approved_for?(user)
-        return render json: login_not_approved
+        @error = login_not_approved[:error]
       elsif payload = login_error_check(user)
-        return render json: payload
+        @error = payload[:error]
       else
         log_on_user(user)
-        return render json: success_json
+        return redirect_to path("/")
+    else
+      @error = I18n.t('email_login.invalid_token')
GitHub sha: 5f6f7070
