Revert "Move the widget-hbs compiler to js from es6"
Revert “Move the widget-hbs compiler to js from es6”
This reverts commit 5d66a2c16e6bd21246e6becbef34da8ed07926bc.
diff --git a/lib/discourse_js_processor.rb b/lib/discourse_js_processor.rb
index fdf61e9..4060b16 100644
--- a/lib/discourse_js_processor.rb
+++ b/lib/discourse_js_processor.rb
@@ -55,8 +55,8 @@ class DiscourseJsProcessor
       embed-application
     ).any? { |f| relative_path == "#{js_root}/#{f}.js" }
-    !!(relative_path =~ /^#{js_root}\/[^\/]+\// ||
-      relative_path =~ /^#{test_root}\/[^\/]+\//)
+    relative_path =~ /^#{js_root}\/[^\/]+\// ||
+      relative_path =~ /^#{test_root}\/[^\/]+\//
   def self.skip_module?(data)
@@ -87,7 +87,7 @@ class DiscourseJsProcessor
 JS
-      source = File.read("#{Rails.root}/lib/javascripts/widget-hbs-compiler.js")
+      source = File.read("#{Rails.root}/lib/javascripts/widget-hbs-compiler.js.es6")
       js_source = ::JSON.generate(source, quirks_mode: true)
       js = ctx.eval("Babel.transform(#{js_source}, { ast: false, plugins: ['check-es2015-constants', 'transform-es2015-arrow-functions', 'transform-es2015-block-scoped-functions', 'transform-es2015-block-scoping', 'transform-es2015-classes', 'transform-es2015-computed-properties', 'transform-es2015-destructuring', 'transform-es2015-duplicate-keys', 'transform-es2015-for-of', 'transform-es2015-function-name', 'transform-es2015-literals', 'transform-es2015-object-super', 'transform-es2015-parameters', 'transform-es2015-shorthand-properties', 'transform-es2015-spread', 'transform-es2015-sticky-regex', 'transform-es2015-template-literals', 'transform-es2015-typeof-symbol', 'transform-es2015-unicode-regex'] }).code")
       ctx.eval(js)
diff --git a/lib/javascripts/widget-hbs-compiler.js b/lib/javascripts/widget-hbs-compiler.js
deleted file mode 100644
index 907ca44..0000000
--- a/lib/javascripts/widget-hbs-compiler.js
+++ /dev/null
@@ -1,349 +0,0 @@
-function resolve(path) {
-  if (path.indexOf("settings") === 0 || path.indexOf("transformed") === 0) {
-    return `this.${path}`;
-  return path;
-function sexpValue(value) {
-  if (!value) {
-    return;
-  let pValue = value.original;
-  if (value.type === "StringLiteral") {
-    return JSON.stringify(pValue);
-  } else if (value.type === "SubExpression") {
-    return sexp(value);
-  return pValue;
-function pairsToObj(pairs) {
-  let result = [];
-  pairs.forEach(p => {
-    result.push(`"${p.key}": ${sexpValue(p.value)}`);
-  return `{ ${result.join(", ")} }`;
-function i18n(node) {
-  let key = sexpValue(node.params[0]);
-  let hash = node.hash;
-  if (hash.pairs.length) {
-    return `I18n.t(${key}, ${pairsToObj(hash.pairs)})`;
-  return `I18n.t(${key})`;
-function sexp(value) {
-  if (value.path.original === "hash") {
-    return pairsToObj(value.hash.pairs);
-  if (value.path.original === "concat") {
-    let result = [];
-    value.params.forEach(p => {
-      result.push(sexpValue(p));
-    return result.join(" + ");
-  if (value.path.original === "i18n") {
-    return i18n(value);
-function valueOf(value) {
-  if (value.type === "SubExpression") {
-  } else if (value.type === "PathExpression") {
-    return value.original;
-  } else if (value.type === "StringLiteral") {
-    return JSON.stringify(value.value);
-function argValue(arg) {
-  return valueOf(arg.value);
-function useHelper(state, name) {
-  let id = state.helpersUsed[name];
-  if (!id) {
-    id = ++state.helperNumber;
-    state.helpersUsed[name] = id;
-  return `__h${id}`;
-function mustacheValue(node, state) {
-  let path = node.path.original;
-  switch (path) {
-    case "attach":
-      let widgetName = argValue(node.hash.pairs.find(p => p.key === "widget"));
-      let attrs = node.hash.pairs.find(p => p.key === "attrs");
-      if (attrs) {
-        return `this.attach(${widgetName}, ${argValue(attrs)})`;
-      return `this.attach(${widgetName}, attrs)`;
-      break;
-    case "yield":
-      return `this.attrs.contents()`;
-      break;
-    case "i18n":
-      return i18n(node);
-      break;
-    case "avatar":
-      let template = argValue(node.hash.pairs.find(p => p.key === "template"));
-      let username = argValue(node.hash.pairs.find(p => p.key === "username"));
-      let size = argValue(node.hash.pairs.find(p => p.key === "size"));
-      return `${useHelper(
-        state,
-        "avatar"
-      )}(${size}, { template: ${template}, username: ${username} })`;
-      break;
-    case "date":
-      return `${useHelper(state, "dateNode")}(${valueOf(node.params[0])})`;
-      break;
-    case "d-icon":
-      return `${useHelper(state, "iconNode")}(${valueOf(node.params[0])})`;
-      break;
-    default:
-      // Shortcut: If our mustach has hash arguments, we can assume it's attaching.
-      // For example `{{home-logo count=123}}` can become `this.attach('home-logo, { "count": 123 });`
-        let widgetString = JSON.stringify(path);
-        // magic: support applying of attrs. This is commonly done like `{{home-logo attrs=attrs}}`
-        let firstPair = hash.pairs[0];
-        if (firstPair.key === "attrs") {
-          return `this.attach(${widgetString}, ${firstPair.value.original})`;
-        return `this.attach(${widgetString}, ${pairsToObj(hash.pairs)})`;
-      if (node.escaped) {
-        return `${resolve(path)}`;
-      } else {
-        return `new ${useHelper(state, "rawHtml")}({ html: '<span>' + ${resolve(
-          path
-        )} + '</span>'})`;
-      break;
-class Compiler {
-  constructor(ast) {
-    this.idx = 0;
-    this.ast = ast;
-    this.state = {
-      helpersUsed: {},
-      helperNumber: 0
-  newAcc() {
-    return `_a${this.idx++}`;
-  processNode(parentAcc, node) {
-    let instructions = [];
-    let innerAcc;
-    switch (node.type) {
-      case "Program":
-        node.body.forEach(bodyNode => {
-          instructions = instructions.concat(
-            this.processNode(parentAcc, bodyNode)
-        break;
-      case "ElementNode":
-        innerAcc = this.newAcc();
-        instructions.push(`var ${innerAcc} = [];`);
-        node.children.forEach(child => {
-          instructions = instructions.concat(this.processNode(innerAcc, child));
-        if (node.attributes.length) {
-          let attributes = [];
-          node.attributes.forEach(a => {
-            const name = a.name === "class" ? "className" : a.name;
-            if (a.value.type === "MustacheStatement") {
-              attributes.push(
-                `"${name}":${mustacheValue(a.value, this.state)}`
-            } else {
-              attributes.push(`"${name}":"${a.value.chars}"`);
-          const attrString = `{${attributes.join(", ")}}`;
-            `${parentAcc}.push(virtualDom.h('${node.tag}', ${attrString}, ${innerAcc}));`
-        } else {
-            `${parentAcc}.push(virtualDom.h('${node.tag}', ${innerAcc}));`
-        break;
-      case "TextNode":
-        return `${parentAcc}.push(${JSON.stringify(node.chars)});`;
-      case "MustacheStatement":
-        const value = mustacheValue(node, this.state);
-        if (value) {
-          instructions.push(`${parentAcc}.push(${value});`);
-        break;
-      case "BlockStatement":
-        let negate = "";
-        switch (node.path.original) {
-          case "unless":
-            negate = "!";
-          case "if":
-              `if (${negate}${resolve(node.params[0].original)}) {`
-            node.program.body.forEach(child => {
-                this.processNode(parentAcc, child)
GitHub sha: eaa324ec
