Revert "PERF: Move highlightjs to a background worker, and add result cache (#10191)"
Revert “PERF: Move highlightjs to a background worker, and add result cache (#10191)”
This caused a CORS error when used with S3 asset storage
This reverts commit d09f283e911c0847ca23372aceefc344526690d2.
diff --git a/app/assets/javascripts/admin/components/highlighted-code.js b/app/assets/javascripts/admin/components/highlighted-code.js
index 30f89e4..9159bb5 100644
--- a/app/assets/javascripts/admin/components/highlighted-code.js
+++ b/app/assets/javascripts/admin/components/highlighted-code.js
@@ -1,37 +1,11 @@
 import Component from "@ember/component";
-import { highlightText } from "discourse/lib/highlight-syntax";
-import { escapeExpression } from "discourse/lib/utilities";
-import discourseComputed from "discourse-common/utils/decorators";
-import { htmlSafe } from "@ember/template";
+import { on, observes } from "discourse-common/utils/decorators";
+import highlightSyntax from "discourse/lib/highlight-syntax";
 export default Component.extend({
-  didReceiveAttrs() {
-    this._super(...arguments);
-    if (this.code === this.previousCode) return;
-    this.set("previousCode", this.code);
-    this.set("highlightResult", null);
-    const toHighlight = this.code;
-    highlightText(escapeExpression(toHighlight), this.lang).then(
-      ({ result }) => {
-        if (toHighlight !== this.code) return; // Code has changed since highlight was requested
-        this.set("highlightResult", result);
-  @discourseComputed("code", "highlightResult")
-  displayCode(code, highlightResult) {
-    if (highlightResult) return htmlSafe(highlightResult);
-    return code;
-  @discourseComputed("highlightResult", "lang")
-  codeClasses(highlightResult, lang) {
-    const classes = [];
-    if (lang) classes.push(lang);
-    if (highlightResult) classes.push("hljs");
-    return classes.join(" ");
+  @on("didInsertElement")
+  @observes("code")
+  _refresh: function() {
+    highlightSyntax($(this.element));
diff --git a/app/assets/javascripts/admin/models/theme.js b/app/assets/javascripts/admin/models/theme.js
index d17b87d..0b96660 100644
--- a/app/assets/javascripts/admin/models/theme.js
+++ b/app/assets/javascripts/admin/models/theme.js
@@ -7,8 +7,8 @@ import discourseComputed from "discourse-common/utils/decorators";
 import { popupAjaxError } from "discourse/lib/ajax-error";
 import { ajax } from "discourse/lib/ajax";
-import { url } from "discourse/lib/computed";
+import { url } from "discourse/lib/computed";
 const THEME_UPLOAD_VAR = 2;
 const FIELDS_IDS = [0, 1, 5];
@@ -321,7 +321,7 @@ const Theme = RestModel.extend({
-        highlightSyntax(document.querySelector(".bootbox.modal"));
+        highlightSyntax();
       } else {
         return this.save({ remote_update: true }).then(() =>
           this.set("changed", false)
diff --git a/app/assets/javascripts/admin/templates/components/highlighted-code.hbs b/app/assets/javascripts/admin/templates/components/highlighted-code.hbs
index 5dd40c0..4d67dd6 100644
--- a/app/assets/javascripts/admin/templates/components/highlighted-code.hbs
+++ b/app/assets/javascripts/admin/templates/components/highlighted-code.hbs
@@ -1 +1 @@
-<pre><code class={{codeClasses}}>{{displayCode}}</code></pre>
+<pre><code class={{lang}}>{{code}}</code></pre>
diff --git a/app/assets/javascripts/discourse/app/initializers/post-decorations.js b/app/assets/javascripts/discourse/app/initializers/post-decorations.js
index d1205bc..7b7d543 100644
--- a/app/assets/javascripts/discourse/app/initializers/post-decorations.js
+++ b/app/assets/javascripts/discourse/app/initializers/post-decorations.js
@@ -1,15 +1,15 @@
 import lightbox from "discourse/lib/lightbox";
 import { setupLazyLoading } from "discourse/lib/lazy-load-images";
 import { setTextDirections } from "discourse/lib/text-direction";
 import { withPluginApi } from "discourse/lib/plugin-api";
-import highlightSyntax from "discourse/lib/highlight-syntax";
 export default {
   initialize(container) {
     withPluginApi("0.1", api => {
       const siteSettings = container.lookup("site-settings:main");
-      api.decorateCookedElement(highlightSyntax, {
+      api.decorateCooked(highlightSyntax, {
       api.decorateCookedElement(lightbox, { id: "discourse-lightbox" });
diff --git a/app/assets/javascripts/discourse/app/lib/highlight-syntax.js b/app/assets/javascripts/discourse/app/lib/highlight-syntax.js
index 302fd4e..404e73c 100644
--- a/app/assets/javascripts/discourse/app/lib/highlight-syntax.js
+++ b/app/assets/javascripts/discourse/app/lib/highlight-syntax.js
@@ -1,181 +1,40 @@
-import { Promise } from "rsvp";
-import { getURLWithCDN } from "discourse-common/lib/get-url";
-import { next, schedule } from "@ember/runloop";
-import loadScript from "discourse/lib/load-script";
-import { isTesting } from "discourse-common/config/environment";
-let highlightJsUrl;
-let highlightJsWorkerUrl;
-const _moreLanguages = [];
-let _worker = null;
-let _workerPromise = null;
-const _pendingResolution = {};
-let _counter = 0;
-let _cachedResultsMap = new Map();
-const CACHE_SIZE = 100;
-export function setupHighlightJs(args) {
-  highlightJsUrl = args.highlightJsUrl;
-  highlightJsWorkerUrl = args.highlightJsWorkerUrl;
-export function registerHighlightJSLanguage(name, fn) {
-  _moreLanguages.push({ name: name, fn: fn });
-export default function highlightSyntax(elem, { autoHighlight = false } = {}) {
-  const selector = autoHighlight ? "pre code" : "pre code[class]";
-  elem.querySelectorAll(selector).forEach(e => highlightElement(e));
+/*global hljs:true */
+let _moreLanguages = [];
-function highlightElement(e) {
-  e.classList.remove("lang-auto");
-  let lang = null;
-  e.classList.forEach(c => {
-    if (c.startsWith("lang-")) {
-      lang = c.slice("lang-".length);
-  const requestString = e.textContent;
-  highlightText(e.textContent, lang).then(({ result, fromCache }) => {
-    const doRender = () => {
-      // Ensure the code hasn't changed since highlighting was triggered:
-      if (requestString !== e.textContent) return;
+import loadScript from "discourse/lib/load-script";
-      e.innerHTML = result;
-      e.classList.add("hljs");
+export default function highlightSyntax($elem) {
+  const selector = Discourse.SiteSettings.autohighlight_all_code
+      ? "pre code"
+      : "pre code[class]",
+    path = Discourse.HighlightJSPath;
-    if (fromCache) {
-      // This happened synchronously, we can safely add rendering
-      // to the end of the current Runloop
-      schedule("afterRender", null, doRender);
-    } else {
-      // This happened async, we are probably not in a runloop
-      // If we call `schedule`, a new runloop will be triggered immediately
-      // So schedule rendering to happen in the next runloop
-      next(() => schedule("afterRender", null, doRender));
-export function highlightText(text, language) {
-  // Large code blocks can cause crashes or slowdowns
-  if (text.length > 30000) {
-    return Promise.resolve({ result: text, fromCache: true });
+  if (!path) {
+    return;
-  return getWorker().then(w => {
-    let result;
-    if ((result = _cachedResultsMap.get(cacheKey(text, language)))) {
-      return Promise.resolve({ result, fromCache: true });
+  $(selector, $elem).each(function(i, e) {
+    // Large code blocks can cause crashes or slowdowns
+    if (e.innerHTML.length > 30000) {
+      return;
-    let resolve;
-    const promise = new Promise(f => (resolve = f));
-    w.postMessage({
-      type: "highlight",
-      id: _counter,
-      text,
-      language
+    $(e).removeClass("lang-auto");
+    loadScript(path).then(() => {
+      customHighlightJSLanguages();
+      hljs.highlightBlock(e);
-    _pendingResolution[_counter] = {
-      promise,
-      resolve,
GitHub sha: 7d300006
