Revert "Reland "DEV: Add checks that assets do not modify cookies to smoke-test.js" (#9774)" (#9783)
Revert “Reland “DEV: Add checks that assets do not modify cookies to smoke-test.js” (#9774)” (#9783)
This reverts commit 186c471c44a278cfc8f29a18a649ce681ef92ab5.
diff --git a/test/smoke_test.js b/test/smoke_test.js
index 728ac91..abd1a45 100644
--- a/test/smoke_test.js
+++ b/test/smoke_test.js
@@ -14,15 +14,6 @@ console.log(`Starting Discourse Smoke Test for ${url}`);
 const puppeteer = require("puppeteer");
 const path = require("path");
-async function getCookie(name, page) {
-  const cookies = await page.cookies();
-  let found = null;
-  cookies.forEach(c => {
-    if (c.name === name) found = c;
-  return found;
 (async () => {
   const browser = await puppeteer.launch({
     // when debugging localy setting the SHOW_BROWSER env variable can be very helpful
@@ -79,11 +70,7 @@ async function getCookie(name, page) {
   page.on("console", msg => console.log(`PAGE LOG: ${msg.text()}`));
   page.on("response", resp => {
-    if (
-      resp.status() !== 200 &&
-      resp.status() !== 302 &&
-      resp.status() !== 304
+    if (resp.status() !== 200 && resp.status() !== 302) {
       console.log(
         "FAILED HTTP REQUEST TO " + resp.url() + " Status is: " + resp.status()
@@ -142,49 +129,6 @@ async function getCookie(name, page) {
     return page.waitForSelector("header .login-button", { visible: true });
-  // Prep for assets check
-  const anyStylesheetEl = await page.$('link[href][rel="stylesheet"]');
-  const anyAssetPath = await page.evaluate(
-    el => el.getAttribute("href"),
-    anyStylesheetEl
-  if (!anyAssetPath) {
-    return console.log("FAILED - could not retrieve an asset path");
-  function checkNoCookies(testPath) {
-    return async function() {
-      const priorCookie = await getCookie("_t", page);
-      const testURL = new URL(testPath, url);
-      await page.setCookie({
-        name: "_t",
-        value: "invalid_auth_token",
-        url: url,
-        domain: priorCookie.domain,
-        path: priorCookie.path,
-        expires: priorCookie.expires,
-        httpOnly: priorCookie.httpOnly,
-        secure: priorCookie.secure,
-        session: priorCookie.session,
-        sameSite: priorCookie.sameSite
-      const badCookie = await getCookie("_t", page);
-      if (badCookie.value !== "invalid_auth_token") {
-        throw "FAILED - could not set cookie";
-      await page.goto(testURL);
-      const newCookie = await getCookie("_t", page);
-      if (newCookie === null || newCookie.value !== "invalid_auth_token") {
-        throw "FAILED - Cookie was modified while fetching " + testPath;
-      await page.setCookie(priorCookie);
   if (process.env.LOGIN_AT_BEGINNING) {
     await login();
@@ -238,28 +182,6 @@ async function getCookie(name, page) {
       return promise;
-    await exec(
-      `assets do not set cookies (${anyAssetPath})`,
-      checkNoCookies(anyAssetPath || "/assets/stylesheets/bogus.css")
-    await exec(
-      "service-worker.js does not set cookies",
-      checkNoCookies("/service-worker.js")
-    await exec("application paths do clear invalid cookies", async () => {
-      const fn = checkNoCookies("/about");
-      let failure = false;
-      try {
-        await fn();
-        failure = true;
-      } catch (e) {
-        // Expecting cookies to be set, so a throw is correct
-      if (failure) {
-        throw "FAILED - cookies not fixed on an application path";
     await exec("it shows a topic list", () => {
       return page.waitForSelector(".topic-list", { visible: true });
GitHub sha: 63b8b3c8
This commit appears in #9783 which was merged by riking.
