Revert "Remove nginx-common package"
Revert “Remove nginx-common package”
This reverts commit 30e0c58d1dd851a00bf7decc6182e3948c10a545.
  • turns out we do depend on the default nginx.conf and directories provided by the distribution package
  • notably /etc/nginx.conf and /etc/nginx/conf.d
diff --git a/image/base/install-nginx b/image/base/install-nginx
index 1b68e55..0211234 100755
--- a/image/base/install-nginx
+++ b/image/base/install-nginx
@@ -21,8 +21,8 @@ echo "$HASH nginx-$VERSION.tar.gz" | sha256sum -c
 tar zxf nginx-$VERSION.tar.gz
 cd nginx-$VERSION
-# build dependencies
-apt install -y libpcre3 libpcre3-dev zlib1g zlib1g-dev
+# nginx-common for boilerplate files etc.
+apt install -y nginx-common libpcre3 libpcre3-dev zlib1g zlib1g-dev
 cd /tmp
 # this is the reason we are compiling by hand...
GitHub sha: 70a33234
