Revert "UX: Added tooltips to topic admin menu (#7146)"
Revert “UX: Added tooltips to topic admin menu (#7146)”
This reverts commit d1c4981f6544740407dcca5fc39bbc737e13a9ee.
Per discussion with @coding-horror it was decided this change is to far reaching.
Instead we will make smaller strategic changes to tooltips that add value.
diff --git a/app/assets/javascripts/discourse/widgets/topic-admin-menu.js.es6 b/app/assets/javascripts/discourse/widgets/topic-admin-menu.js.es6
index e0f94d7..2d6e065 100644
--- a/app/assets/javascripts/discourse/widgets/topic-admin-menu.js.es6
+++ b/app/assets/javascripts/discourse/widgets/topic-admin-menu.js.es6
@@ -16,7 +16,6 @@ createWidget("admin-menu-button", {
         action: attrs.action,
         icon: attrs.icon,
         label: attrs.fullLabel || `topic.${attrs.label}`,
-        title: attrs.title,
         secondaryAction: "hideAdminMenu"
@@ -137,8 +136,7 @@ export default createWidget("topic-admin-menu", {
       buttonClass: "btn-default",
       action: "toggleMultiSelect",
       icon: "tasks",
-      label: "actions.multi_select",
-      title: "topic.actions.multi_select_tooltip"
+      label: "actions.multi_select"
     const topic = attrs.topic;
@@ -150,8 +148,7 @@ export default createWidget("topic-admin-menu", {
         buttonClass: "btn-danger",
         action: "deleteTopic",
         icon: "far-trash-alt",
-        label: "actions.delete",
-        title: "topic.actions.delete_tooltip"
+        label: "actions.delete"
@@ -161,8 +158,7 @@ export default createWidget("topic-admin-menu", {
         action: "recoverTopic",
         icon: "undo",
-        label: "actions.recover",
-        title: "topic.actions.recover_tooltip"
+        label: "actions.recover"
@@ -172,8 +168,7 @@ export default createWidget("topic-admin-menu", {
         action: "toggleClosed",
         icon: "unlock",
-        label: "actions.open",
-        title: "topic.actions.open_tooltip"
+        label: "actions.open"
     } else {
       buttons.push({
@@ -181,8 +176,7 @@ export default createWidget("topic-admin-menu", {
         icon: "lock",
-        label: "actions.close",
-        title: "topic.actions.close_tooltip"
+        label: "actions.close"
@@ -191,8 +185,7 @@ export default createWidget("topic-admin-menu", {
       action: "showTopicStatusUpdate",
       icon: "far-clock",
-      label: "actions.timed_update",
-      title: "topic.actions.timed_update_tooltip"
+      label: "actions.timed_update"
     const isPrivateMessage = topic.get("isPrivateMessage");
@@ -204,10 +197,7 @@ export default createWidget("topic-admin-menu", {
         action: "showFeatureTopic",
         icon: "thumbtack",
-        label: featured ? "actions.unpin" : "actions.pin",
-        title: featured
-          ? "topic.actions.unpin_tooltip"
-          : "topic.actions.pin_tooltip"
+        label: featured ? "actions.unpin" : "actions.pin"
@@ -217,8 +207,7 @@ export default createWidget("topic-admin-menu", {
         action: "showChangeTimestamp",
         icon: "calendar-alt",
-        label: "change_timestamp.title",
-        title: "topic.change_timestamp.tooltip"
+        label: "change_timestamp.title"
@@ -227,8 +216,7 @@ export default createWidget("topic-admin-menu", {
       action: "resetBumpDate",
       icon: "anchor",
-      label: "actions.reset_bump_date",
-      title: "topic.actions.reset_bump_date_tooltip"
+      label: "actions.reset_bump_date"
     if (!isPrivateMessage) {
@@ -237,10 +225,7 @@ export default createWidget("topic-admin-menu", {
         action: "toggleArchived",
         icon: "folder",
-        label: topic.get("archived") ? "actions.unarchive" : "actions.archive",
-        title: topic.get("archived")
-          ? "topic.actions.unarchive_tooltip"
-          : "topic.actions.archive_tooltip"
+        label: topic.get("archived") ? "actions.unarchive" : "actions.archive"
@@ -250,10 +235,7 @@ export default createWidget("topic-admin-menu", {
       action: "toggleVisibility",
       icon: visible ? "far-eye-slash" : "far-eye",
-      label: visible ? "actions.invisible" : "actions.visible",
-      title: visible
-        ? "topic.actions.invisible_tooltip"
-        : "topic.actions.visible_tooltip"
+      label: visible ? "actions.invisible" : "actions.visible"
     if (details.get("can_convert_topic")) {
@@ -264,12 +246,7 @@ export default createWidget("topic-admin-menu", {
           ? "convertToPublicTopic"
           : "convertToPrivateMessage",
         icon: isPrivateMessage ? "comment" : "envelope",
-        label: isPrivateMessage
-          ? "actions.make_public"
-          : "actions.make_private",
-        title: isPrivateMessage
-          ? "topic.actions.make_public_tooltip"
-          : "topic.actions.make_private_tooltip"
+        label: isPrivateMessage ? "actions.make_public" : "actions.make_private"
@@ -278,8 +255,7 @@ export default createWidget("topic-admin-menu", {
         action: "showModerationHistory",
         icon: "list",
-        fullLabel: "admin.flags.moderation_history",
-        title: "admin.flags.moderation_history_tooltip"
+        fullLabel: "admin.flags.moderation_history"
diff --git a/config/locales/client.en.yml b/config/locales/client.en.yml
index 7413b1d..0221f6f 100644
--- a/config/locales/client.en.yml
+++ b/config/locales/client.en.yml
@@ -1932,36 +1932,21 @@ en:
       actions:
         recover: "Un-Delete Topic"
-        recover_tooltip: "Restores the topic."
         delete: "Delete Topic"
-        delete_tooltip: "Marks the topic as deleted."
         open: "Open Topic"
-        open_tooltip: "Marks the topic as open and allows new replies."
         close: "Close Topic"
-        close_tooltip: "Marks the topic as closed and prevents new replies."
         multi_select: "Select Posts…"
-        multi_select_tooltip: "Toggles multiselect mode in which multiple posts can be selected."
         timed_update: "Set Topic Timer..."
-        timed_update_tooltip: "Opens a new window in which a timer for different actions can be set."
         pin: "Pin Topic…"
-        pin_tooltip: "Opens a window in which the topic can be featured in different ways."
         unpin: "Un-Pin Topic…"
-        unpin_tooltip: "Unpins the topic and it will no longer be featured."
         unarchive: "Unarchive Topic"
-        unarchive_tooltip: "Unfreezes the topic and allows interacting with it."
         archive: "Archive Topic"
-        archive_tooltip: "Freezes the topic and prevents interacting with it."
         invisible: "Make Unlisted"
-        invisible_tooltip: "Prevents the inclusion of the topic in lists and digest emails."
         visible: "Make Listed"
-        visible_tooltip: "Marks the topic as visible and includes the topic in lists and digest emails."
         reset_read: "Reset Read Data"
         make_public: "Make Public Topic"
-        make_public_tooltip: "Converts to public topic and makes it visible for other users."
         make_private: "Make Personal Message"
-        make_private_tooltip: "Converts to personal message and makes it invisible for other users."
         reset_bump_date: "Reset Bump Date"
-        reset_bump_date_tooltip: "Puts the topic back into chronological order according to when it was originally created."
       feature:
         pin: "Pin Topic"
@@ -2119,7 +2104,6 @@ en:
       change_timestamp:
         title: "Change Timestamp..."
-        tooltip: "Opens a window in which the timestamp can be changed."
         action: "change timestamp"
         invalid_timestamp: "Timestamp cannot be in the future."
         error: "There was an error changing the timestamp of the topic."
@@ -2996,7 +2980,6 @@ en:
         old_posts: "Old Flagged Posts"
         topics: "Flagged Topics"
GitHub sha: c47b0a8b
