Revert "UX: Improve button position and visibility. (#78)"
Revert “UX: Improve button position and visibility. (#78)”
This reverts commit d394d64285dfbc0f42dfe22162977b50b7ea5c3f.
We made the UX here a bit too strong, we will followup with a reduction of noise and ensure the new “loud UX” only appears for the OP and only appears when no solution is accepted
diff --git a/assets/javascripts/discourse/connectors/topic-after-cooked/solved-panel.hbs b/assets/javascripts/discourse/connectors/topic-after-cooked/solved-panel.hbs
new file mode 100644
index 0000000..168f0f6
--- /dev/null
+++ b/assets/javascripts/discourse/connectors/topic-after-cooked/solved-panel.hbs
@@ -0,0 +1,5 @@
+{{#if topic.accepted_answer}}
+<p class="solved">
+{{{topic.acceptedAnswerHtml}}}
+</p>
+{{/if}}
diff --git a/assets/javascripts/discourse/initializers/extend-for-solved-button.js.es6 b/assets/javascripts/discourse/initializers/extend-for-solved-button.js.es6
index c33e8b5..ba9f7fe 100644
--- a/assets/javascripts/discourse/initializers/extend-for-solved-button.js.es6
+++ b/assets/javascripts/discourse/initializers/extend-for-solved-button.js.es6
@@ -62,10 +62,14 @@ function acceptPost(post) {
   }).catch(popupAjaxError);
-function initializeWithApi(api, container) {
-  const { mobileView } = container.lookup("site:main");
+function initializeWithApi(api) {
+  const currentUser = api.getCurrentUser();
-  TopicStatusIcons.addObject(["has_accepted_answer", "check-circle", "solved"]);
+  TopicStatusIcons.addObject([
+    "has_accepted_answer",
+    "far-check-square",
+    "solved"
   api.includePostAttributes(
     "can_accept_answer",
@@ -77,48 +81,38 @@ function initializeWithApi(api, container) {
     api.addDiscoveryQueryParam("solved", { replace: true, refreshModel: true });
-  if (!mobileView) {
-    api.addPostMenuButton("solved", attrs => {
-      if (attrs.accepted_answer) {
-        return {
-          action: "",
-          icon: "check-circle",
-          title: "solved.accepted_answer",
-          className: "accepted",
-          position: "first",
-          afterButton(h) {
-            return h("span.accepted", I18n.t("solved.solution"));
-    api.addPostMenuButton("solve", attrs => {
-      if (!attrs.accepted_answer && attrs.can_accept_answer) {
-        return {
-          action: "acceptAnswer",
-          title: "solved.accept_answer",
-          className: "unaccepted",
-          afterButton(h) {
-            return h("span.unaccepted", I18n.t("solved.mark_as_solution"));
-      } else if (attrs.accepted_answer && attrs.can_unaccept_answer) {
-        return {
-          action: "unacceptAnswer",
-          icon: "times-circle",
-          title: "solved.unaccept_answer",
-          afterButton(h) {
-            return h("span.unaccepted", I18n.t("solved.unmark_as_solution"));
+  api.addPostMenuButton("solved", attrs => {
+    const canAccept = attrs.can_accept_answer;
+    const canUnaccept = attrs.can_unaccept_answer;
+    const accepted = attrs.accepted_answer;
+    const isOp = currentUser && currentUser.id === attrs.topicCreatedById;
+    const position =
+      !accepted && canAccept && !isOp ? "second-last-hidden" : "first";
+    if (canAccept) {
+      return {
+        action: "acceptAnswer",
+        icon: "far-check-square",
+        className: "unaccepted",
+        title: "solved.accept_answer",
+        position
+    } else if (canUnaccept || accepted) {
+      const title = canUnaccept
+        ? "solved.unaccept_answer"
+        : "solved.accepted_answer";
+      return {
+        action: "unacceptAnswer",
+        icon: "check-square",
+        title,
+        className: "accepted fade-out",
+        position,
+        beforeButton(h) {
+          return h("span.accepted-text", I18n.t("solved.solution"));
   api.decorateWidget("post-contents:after-cooked", dec => {
     if (dec.attrs.post_number === 1) {
@@ -161,46 +155,6 @@ function initializeWithApi(api, container) {
-  if (mobileView) {
-    api.decorateWidget("post-contents:after-cooked", dec => {
-      const model = dec.getModel();
-      const result = [];
-      if (model.accepted_answer) {
-        result.push(
-          dec.attach("button", {
-            label: "solved.solution",
-            title: "solved.solution",
-            action: "noop",
-            className: "solved"
-      if (!model.accepted_answer && model.can_accept_answer) {
-        result.push(
-            label: "solved.mark_as_solution",
-            title: "solved.mark_as_solution",
-            className: "solve"
-      } else if (model.accepted_answer && model.can_unaccept_answer) {
-        result.push(
-            label: "solved.unmark_as_solution",
-            title: "solved.unmark_as_solution",
-      return dec.h("div.solved-container", result);
   api.attachWidgetAction("post", "acceptAnswer", function() {
     const post = this.model;
     const current = post.get("topic.postStream.posts").filter(p => {
@@ -243,7 +197,7 @@ function initializeWithApi(api, container) {
 export default {
-  initialize(container) {
+  initialize() {
     Topic.reopen({
       // keeping this here cause there is complex localization
       acceptedAnswerHtml: function() {
@@ -255,7 +209,7 @@ export default {
         return I18n.t("solved.accepted_html", {
-          icon: iconHTML("check-circle", { class: "accepted" }),
+          icon: iconHTML("check-square", { class: "accepted" }),
           username_lower: username.toLowerCase(),
           username: formatUsername(username),
           post_path: this.get("url") + "/" + postNumber,
@@ -273,7 +227,7 @@ export default {
             openTag: "span",
             closeTag: "span",
             title: I18n.t("topic_statuses.solved.help"),
         } else if (
           this.topic.can_have_answer &&
@@ -291,12 +245,12 @@ export default {
       }.property()
-    withPluginApi("0.1", api => initializeWithApi(api, container));
+    withPluginApi("0.1", initializeWithApi);
     withPluginApi("0.8.10", api => {
       api.replaceIcon(
         "notification.solved.accepted_notification",
-        "check-circle"
+        "check-square"
diff --git a/assets/stylesheets/solutions.scss b/assets/stylesheets/solutions.scss
index 1caa756..622ed3b 100644
--- a/assets/stylesheets/solutions.scss
+++ b/assets/stylesheets/solutions.scss
@@ -1,3 +1,4 @@
+.solved-panel,
 .post-controls .accepted,
 .fa.accepted,
 .accepted-text {
@@ -7,61 +8,9 @@
-.topic-body {
-  .solved-container {
-    display: flex;
-    .btn {
-      background-color: blend-primary-secondary(5%);
-      padding: 1em;
-  .solve,
-  .solved {
-    text-align: center;
-    .d-icon {
-      margin-right: 0.5em;
-  .solved {
-    color: green;
-    flex: 1;
-    &.btn .d-icon {
-      color: green;
-  .solve {
-    flex: 2;
-.post-controls button.accepted {
-  &:hover {
-    background: none;
-    cursor: auto;
-  &:active {
-    box-shadow: none;
-  &.btn-flat:hover .d-icon {
-    color: green;
-.post-controls .unaccepted {
-  color: dark-light-choose($primary-low-mid, $secondary-high);
 .post-controls span:not(.d-button-label) {
   display: inline-flex;
-  align-items: center;
+  align-items: baseline;
 .post-controls .accepted-text {
@@ -71,6 +20,29 @@
   z-index: 2;
+// you can style accepted answers however your want
+.quote.accepted-answer {
+  //  background-color: #E9FFE0;
+.mobile-view .solved-panel {
GitHub sha: a0191a1e
