SECURITY: Do not reveal post whisperer in personal messages.
Prior to this fix, post whisperer in personal messages are revealed in the topic’s participants list even though non-staff users are unable to see the whisper.
diff --git a/lib/post_creator.rb b/lib/post_creator.rb
index a4f2490..69a94bd 100644
--- a/lib/post_creator.rb
+++ b/lib/post_creator.rb
@@ -458,14 +458,18 @@ class PostCreator
   def ensure_in_allowed_users
     return unless @topic.private_message? && @topic.id
+    return if @post.whisper?
+    return if @topic.topic_allowed_users.exists?(user_id: @user.id)
-    unless @topic.topic_allowed_users.where(user_id: @user.id).exists?
-      unless @topic.topic_allowed_groups.where('group_id IN (
-                                              SELECT group_id FROM group_users where user_id = ?
-                                           )', @user.id).exists?
-        @topic.topic_allowed_users.create!(user_id: @user.id)
-      end
-    end
+    return if @topic
+      .topic_allowed_groups
+      .where(
+        "group_id IN (SELECT group_id FROM group_users where user_id = ?)",
+        @user.id
+      .exists?
+    @topic.topic_allowed_users.create!(user_id: @user.id)
   def unarchive_message
diff --git a/spec/components/post_creator_spec.rb b/spec/components/post_creator_spec.rb
index e01db2b..843465f 100644
--- a/spec/components/post_creator_spec.rb
+++ b/spec/components/post_creator_spec.rb
@@ -909,10 +909,10 @@ describe PostCreator do
   context 'private message' do
     let(:target_user1) { Fabricate(:coding_horror) }
     fab!(:target_user2) { Fabricate(:moderator) }
-    fab!(:unrelated) { Fabricate(:user) }
+    fab!(:unrelated_user) { Fabricate(:user) }
     let(:post) do
-      PostCreator.create(user, title: 'hi there welcome to my topic',
-                               raw: "this is my awesome message @#{unrelated.username_lower}",
+      PostCreator.create!(user, title: 'hi there welcome to my topic',
+                               raw: "this is my awesome message @#{unrelated_user.username_lower}",
                                archetype: Archetype.private_message,
                                target_usernames: [target_user1.username, target_user2.username].join(','),
                                category: 1)
@@ -934,7 +934,7 @@ describe PostCreator do
       expect(post.topic.category).to eq(nil)
       # does not notify an unrelated user
-      expect(unrelated.notifications.count).to eq(0)
+      expect(unrelated_user.notifications.count).to eq(0)
       expect(post.topic.subtype).to eq(TopicSubtype.user_to_user)
       # PMs do not increase post count or topic count
@@ -949,7 +949,7 @@ describe PostCreator do
       # if an admin replies they should be added to the allowed user list
       admin = Fabricate(:admin)
-      PostCreator.create(admin, raw: 'hi there welcome topic, I am a mod',
+      PostCreator.create!(admin, raw: 'hi there welcome topic, I am a mod',
                                 topic_id: post.topic_id)
       post.topic.reload
@@ -963,11 +963,27 @@ describe PostCreator do
       admin2 = Fabricate(:admin)
       group.add(admin2)
-      PostCreator.create(admin2, raw: 'I am also an admin, and a mod', topic_id: post.topic_id)
+      PostCreator.create!(admin2, raw: 'I am also an admin, and a mod', topic_id: post.topic_id)
       expect(post.topic.topic_allowed_users.where(user_id: admin2.id).count).to eq(0)
+    it 'does not add whisperers to allowed users of the topic' do
+      SiteSetting.enable_whispers = true
+      unrelated_user.update!(admin: true)
+        unrelated_user,
+        raw: "This is a whisper that I am testing",
+        topic_id: post.topic_id,
+        post_type: Post.types[:whisper]
+      expect(post.topic.topic_allowed_users.map(&:user_id)).to contain_exactly(
+        target_user1.id, target_user2.id, user.id
+    end
     it 'does not increase posts count for small actions' do
       topic = Fabricate(:private_message_topic, user: Fabricate(:user))
GitHub sha: 303e9e42b6baffd04d5dfd5069dc27c1bfbe2f78
This commit appears in #13830 which was approved by ZogStriP. It was merged by tgxworld.
