SECURITY: lodash 4.17.11 (#7565)
approved
#1
This version also now includes _.find
diff --git a/vendor/assets/javascripts/lodash.js b/vendor/assets/javascripts/lodash.js
index 373ae5e..f5e6c65 100644
--- a/vendor/assets/javascripts/lodash.js
+++ b/vendor/assets/javascripts/lodash.js
@@ -1,7 +1,7 @@
  * @license
  * Lodash (Custom Build) <https://lodash.com/>
- * Build: `lodash include="each,filter,map,range,first,isEmpty,chain,extend,every,omit,merge,union,sortBy,uniq,intersection,reject,compact,reduce,debounce,throttle,values,pick,keys,flatten,min,max,isArray,delay,isString,isEqual,without,invoke,clone,findIndex" minus="template" -d`
+ * Build: `lodash include="each,filter,map,range,first,isEmpty,chain,extend,every,omit,merge,union,sortBy,uniq,intersection,reject,compact,reduce,debounce,throttle,values,pick,keys,flatten,min,max,isArray,delay,isString,isEqual,without,invoke,clone,findIndex,find" minus="template" -d`
  * Copyright JS Foundation and other contributors <https://js.foundation/>
  * Released under MIT license <https://lodash.com/license>
  * Based on Underscore.js 1.8.3 <http://underscorejs.org/LICENSE>
@@ -13,7 +13,7 @@
   var undefined;
   /** Used as the semantic version number. */
-  var VERSION = '4.17.5';
+  var VERSION = '4.17.11';
   /** Used as the size to enable large array optimizations. */
   var LARGE_ARRAY_SIZE = 200;
@@ -246,6 +246,14 @@
   /** Used to access faster Node.js helpers. */
   var nodeUtil = (function() {
     try {
+      // Use `util.types` for Node.js 10+.
+      var types = freeModule && freeModule.require && freeModule.require('util').types;
+      if (types) {
+        return types;
+      // Legacy `process.binding('util')` for Node.js < 10.
       return freeProcess && freeProcess.binding && freeProcess.binding('util');
     } catch (e) {}
@@ -757,20 +765,6 @@
-   * Gets the value at `key`, unless `key` is "__proto__".
-   * @private
-   * @param {Object} object The object to query.
-   * @param {string} key The key of the property to get.
-   * @returns {*} Returns the property value.
-  function safeGet(object, key) {
-    return key == '__proto__'
-      ? undefined
-      : object[key];
    * Converts `set` to an array of its values.
    * @private
@@ -2770,7 +2764,7 @@
         if (isArguments(objValue)) {
           newValue = toPlainObject(objValue);
-        else if (!isObject(objValue) || (srcIndex && isFunction(objValue))) {
+        else if (!isObject(objValue) || isFunction(objValue)) {
           newValue = initCloneObject(srcValue);
@@ -3577,6 +3571,26 @@
+   * Creates a `_.find` or `_.findLast` function.
+   * @private
+   * @param {Function} findIndexFunc The function to find the collection index.
+   * @returns {Function} Returns the new find function.
+  function createFind(findIndexFunc) {
+    return function(collection, predicate, fromIndex) {
+      var iterable = Object(collection);
+      if (!isArrayLike(collection)) {
+        var iteratee = getIteratee(predicate, 3);
+        collection = keys(collection);
+        predicate = function(key) { return iteratee(iterable[key], key, iterable); };
+      var index = findIndexFunc(collection, predicate, fromIndex);
+      return index > -1 ? iterable[iteratee ? collection[index] : index] : undefined;
    * Creates a function that wraps `func` to invoke it with optional `this`
    * binding of `thisArg`, partial application, and currying.
@@ -4663,6 +4677,22 @@
+   * Gets the value at `key`, unless `key` is "__proto__".
+   * @private
+   * @param {Object} object The object to query.
+   * @param {string} key The key of the property to get.
+   * @returns {*} Returns the property value.
+  function safeGet(object, key) {
+    if (key == '__proto__') {
+      return;
+    return object[key];
    * Sets metadata for `func`.
    * **Note:** If this function becomes hot, i.e. is invoked a lot in a short
@@ -5519,6 +5549,44 @@
+   * Iterates over elements of `collection`, returning the first element
+   * `predicate` returns truthy for. The predicate is invoked with three
+   * arguments: (value, index|key, collection).
+   * @static
+   * @memberOf _
+   * @since 0.1.0
+   * @category Collection
+   * @param {Array|Object} collection The collection to inspect.
+   * @param {Function} [predicate=_.identity] The function invoked per iteration.
+   * @param {number} [fromIndex=0] The index to search from.
+   * @returns {*} Returns the matched element, else `undefined`.
+   * @example
+   * var users = [
+   *   { 'user': 'barney',  'age': 36, 'active': true },
+   *   { 'user': 'fred',    'age': 40, 'active': false },
+   *   { 'user': 'pebbles', 'age': 1,  'active': true }
+   * _.find(users, function(o) { return o.age < 40; });
+   * // => object for 'barney'
+   * // The `_.matches` iteratee shorthand.
+   * _.find(users, { 'age': 1, 'active': true });
+   * // => object for 'pebbles'
+   * // The `_.matchesProperty` iteratee shorthand.
+   * _.find(users, ['active', false]);
+   * // => object for 'fred'
+   * // The `_.property` iteratee shorthand.
+   * _.find(users, 'active');
+  var find = createFind(findIndex);
    * Iterates over elements of `collection` and invokes `iteratee` for each element.
    * The iteratee is invoked with three arguments: (value, index|key, collection).
    * Iteratee functions may exit iteration early by explicitly returning `false`.
@@ -7551,6 +7619,7 @@
   lodash.clone = clone;
   lodash.eq = eq;
   lodash.every = every;
+  lodash.find = find;
   lodash.findIndex = findIndex;
   lodash.forEach = forEach;
   lodash.get = get;
GitHub sha: b983b6cb
Approved #2
