SECURITY: Mod should not see `group_users` and `second_factor_enabled`.
SECURITY: Mod should not see group_users and second_factor_enabled.
Moderators should not be able to see UserSerializer#group_users and UserSerializer#second_factor_enabled of other users.
Impact of leaking this is low because the information leaked is not exploitable.
diff --git a/app/serializers/user_serializer.rb b/app/serializers/user_serializer.rb
index 3b95db2..594b3fb 100644
--- a/app/serializers/user_serializer.rb
+++ b/app/serializers/user_serializer.rb
@@ -83,7 +83,7 @@ class UserSerializer < UserCardSerializer
   def include_group_users?
-    (object.id && object.id == scope.user.try(:id)) || scope.is_staff?
+    (object.id && object.id == scope.user.try(:id)) || scope.is_admin?
   def include_associated_accounts?
@@ -91,7 +91,7 @@ class UserSerializer < UserCardSerializer
   def include_second_factor_enabled?
-    (object&.id == scope.user&.id) || scope.is_staff?
+    (object&.id == scope.user&.id) || scope.is_admin?
   def second_factor_enabled
diff --git a/spec/serializers/user_serializer_spec.rb b/spec/serializers/user_serializer_spec.rb
index fe770e4..cad83e3 100644
--- a/spec/serializers/user_serializer_spec.rb
+++ b/spec/serializers/user_serializer_spec.rb
@@ -3,20 +3,33 @@
 require 'rails_helper'
 describe UserSerializer do
+  fab!(:user) { Fabricate(:user, trust_level: 0) }
   context "with a TL0 user seen as anonymous" do
-    let(:user) { Fabricate.build(:user, trust_level: 0, user_profile: Fabricate.build(:user_profile)) }
     let(:serializer) { UserSerializer.new(user, scope: Guardian.new, root: false) }
     let(:json) { serializer.as_json }
     let(:untrusted_attributes) { %i{bio_raw bio_cooked bio_excerpt location website website_name profile_background card_background} }
     it "doesn't serialize untrusted attributes" do
       untrusted_attributes.each { |attr| expect(json).not_to have_key(attr) }
-    it "doesn't serialize group_users" do
-      expect(json[:group_users]).to be_nil
+    it "serializes correctly" do
+      expect(json[:group_users]).to eq(nil)
+      expect(json[:second_factor_enabled]).to eq(nil)
+    end
+  end
+  context "as moderator" do
+      json = UserSerializer.new(
+        user,
+        scope: Guardian.new(Fabricate(:moderator)),
+        root: false
+      ).as_json
@@ -41,8 +54,8 @@ describe UserSerializer do
       expect(json[:user_option][:new_topic_duration_minutes]).to eq(60 * 24)
       expect(json[:user_option][:auto_track_topics_after_msecs]).to eq(0)
       expect(json[:user_option][:notification_level_when_replying]).to eq(3)
       expect(json[:group_users]).to eq([])
+      expect(json[:second_factor_enabled]).to eq(false)
GitHub sha: 245d29e5
