SECURITY: moves open_timeout in start declaration (#477)
diff --git a/lib/onebox/helpers.rb b/lib/onebox/helpers.rb
index a3df3f2..6b8f4d3 100644
--- a/lib/onebox/helpers.rb
+++ b/lib/onebox/helpers.rb
@@ -63,8 +63,7 @@ module Onebox
       result = StringIO.new
-      Net::HTTP.start(uri.host, uri.port, use_ssl: uri.normalized_scheme == 'https') do |http|
-        http.open_timeout = Onebox.options.connect_timeout
+      Net::HTTP.start(uri.host, uri.port, open_timeout: Onebox.options.connect_timeout, use_ssl: uri.normalized_scheme == 'https') do |http|
         http.read_timeout = Onebox.options.timeout
         http.verify_mode = OpenSSL::SSL::VERIFY_NONE  # Work around path building bugs
@@ -118,8 +117,7 @@ module Onebox
     def self.fetch_content_length(location)
       uri = URI(location)
-      Net::HTTP.start(uri.host, uri.port, use_ssl: uri.is_a?(URI::HTTPS)) do |http|
+      Net::HTTP.start(uri.host, uri.port, open_timeout: Onebox.options.connect_timeout, use_ssl: uri.is_a?(URI::HTTPS)) do |http|
         if uri.is_a?(URI::HTTPS)
           http.use_ssl = true
diff --git a/lib/onebox/version.rb b/lib/onebox/version.rb
index a769525..24ed330 100644
--- a/lib/onebox/version.rb
+++ b/lib/onebox/version.rb
@@ -1,5 +1,5 @@
 # frozen_string_literal: true
 module Onebox
-  VERSION = "2.2.15"
+  VERSION = "2.2.16"
GitHub sha: f149a34fed3976834f6a7ee4cd6b92186c59ba0a
This commit appears in #477 which was approved by CvX. It was merged by jjaffeux.
