Simplify animation used to denote draft is saved
The original implementation felt a bit too short, went with a much simpler animation which sticks around for 5 seconds.
5 seconds seems to be the standard and the same timing gmail use
diff --git a/app/assets/stylesheets/common/base/compose.scss b/app/assets/stylesheets/common/base/compose.scss
index 59941c7..2ab2284 100644
--- a/app/assets/stylesheets/common/base/compose.scss
+++ b/app/assets/stylesheets/common/base/compose.scss
@@ -455,50 +455,23 @@ div.ac-wrap {
 .save-animation {
-  transition: all 1s ease-in-out;
-  -webkit-transform: scale(0.1);
-  transform: scale(0.1);
-  -webkit-animation: transformer 1.5s forwards;
-  animation: transformer 1.5s forwards;
+  -webkit-animation: transformer 5s forwards;
+  animation: transformer 5s forwards;
 @-webkit-keyframes transformer {
-  0% {
-  20% {
-    -webkit-transform: scale(1.2);
-  40% {
-    -webkit-transform: scale(1);
-    -webkit-filter: opacity(1);
-  60% {
+  90% {
   100% {
     -webkit-filter: opacity(0);
 @keyframes transformer {
-  0% {
-  20% {
-    transform: scale(1.2);
-  40% {
-    transform: scale(1);
-    opacity: 1;
-  60% {
+  90% {
     opacity: 1;
   100% {
     opacity: 0;
GitHub sha: 2fea29a3
I could have gone with a longer animation duration but removing the scale kinda looks very rough and unpolished to me now. Why remove the keyframes anyways?
I wanted to minimize distraction here and found that the fancy popping kept on “making me look at it”, 5 seconds seems to be the norm for the delay here.
Open to tweaking this a bit more but I would prefer to leave that to @awesomerobot he can make the call on any more changes here.
