SPEC: Add test case in emit_web_hook_event_spec for commit 4c6bfb9
diff --git a/spec/jobs/emit_web_hook_event_spec.rb b/spec/jobs/emit_web_hook_event_spec.rb
index 06aadf8..099234b 100644
--- a/spec/jobs/emit_web_hook_event_spec.rb
+++ b/spec/jobs/emit_web_hook_event_spec.rb
@@ -1,4 +1,5 @@
 require 'rails_helper'
+require 'excon'
 describe Jobs::EmitWebHookEvent do
   let(:post_hook) { Fabricate(:web_hook) }
@@ -24,6 +25,16 @@ describe Jobs::EmitWebHookEvent do
     end.to raise_error(Discourse::InvalidParameters)
+  it "should not destroy webhook event in case of error" do
+    Excon::Connection.any_instance.stubs(:post).raises("error")
+    subject.execute(
+      web_hook_id: post_hook.id,
+      payload: { id: post.id }.to_json,
+      event_type: WebHookEventType::POST
+    expect(WebHookEvent.last.web_hook_id).to eq(post_hook.id)
+  end
   context 'when the web hook is failed' do
     before do
       SiteSetting.retry_web_hook_events = true
GitHub sha: 904ba266
Instead of stubbing the method which relies on the internal implementation detail, we can stub at the request level which is not coupled to the library which we use to make the request.
Was followed in DEV: Refactor `Jobs::EmitWebHookEvent` specs. · discourse/discourse@730ebdf · GitHub
