SPEC: Add test cases for topic answer mixin
diff --git a/spec/serializers/topic_answer_mixin_spec.rb b/spec/serializers/topic_answer_mixin_spec.rb
new file mode 100644
index 0000000..f0c785a
--- /dev/null
+++ b/spec/serializers/topic_answer_mixin_spec.rb
@@ -0,0 +1,24 @@
+require 'rails_helper'
+describe TopicAnswerMixin do
+  let(:topic) { Fabricate(:topic) }
+  let(:post) { Fabricate(:post, topic: topic) }
+  let(:guardian) { Guardian.new }
+  before do
+    topic.custom_fields["accepted_answer_post_id"] = post.id
+    topic.save_custom_fields
+  end
+  it "should have true for `has_accepted_answer` field in each serializer" do
+      TopicListItemSerializer,
+      SearchTopicListItemSerializer,
+      SuggestedTopicSerializer,
+      UserSummarySerializer::TopicSerializer
+    ].each do |serializer|
+      json = serializer.new(topic, scope: guardian, root: false).as_json
+      expect(json[:has_accepted_answer]).to be_truthy
+    end
+  end
+end
GitHub sha: 086c5de8
