Start Discourse in an initializer (#9930)
  • DEV: To be pedantic, there is more than EMBER in there now
  • DEV: Use less globals. Have Discourse start in an initializer
  • DEV: Remove another global
diff --git a/app/assets/javascripts/discourse-loader.js b/app/assets/javascripts/discourse-loader.js
index fc829ae..f6a28c0 100644
--- a/app/assets/javascripts/discourse-loader.js
+++ b/app/assets/javascripts/discourse-loader.js
@@ -1,7 +1,7 @@
 var define, requirejs;
 (function() {
-  var EMBER_MODULES = {};
+  var JS_MODULES = {};
   var ALIASES = {
     "ember-addons/ember-computed-decorators":
       "discourse-common/utils/decorators",
@@ -11,7 +11,7 @@ var define, requirejs;
   // In future versions of ember we don't need this
   if (typeof Ember !== "undefined") {
-    EMBER_MODULES = {
+    JS_MODULES = {
       jquery: { default: $ },
       "@ember/array": {
         default: Ember.Array,
@@ -285,7 +285,7 @@ var define, requirejs;
       name = "@ember/object";
-    var mod = EMBER_MODULES[name] || registry[name];
+    var mod = JS_MODULES[name] || registry[name];
     if (!mod) {
       throw new Error(
         "Could not find module `" + name + "` imported from `" + origin + "`"
@@ -308,8 +308,8 @@ var define, requirejs;
   requirejs = require = function(name) {
     name = transformForAliases(name);
-    if (EMBER_MODULES[name]) {
-      return EMBER_MODULES[name];
+    if (JS_MODULES[name]) {
+      return JS_MODULES[name];
     var mod = registry[name];
diff --git a/app/assets/javascripts/discourse/app/pre-initializers/discourse-bootstrap.js b/app/assets/javascripts/discourse/app/pre-initializers/discourse-bootstrap.js
new file mode 100644
index 0000000..494ed5e
--- /dev/null
+++ b/app/assets/javascripts/discourse/app/pre-initializers/discourse-bootstrap.js
@@ -0,0 +1,94 @@
+import PreloadStore from "discourse/lib/preload-store";
+import I18n from "I18n";
+import Session from "discourse/models/session";
+import RSVP from "rsvp";
+import { isTesting } from "discourse-common/config/environment";
+export default {
+  name: "discourse-bootstrap",
+  // The very first initializer to run
+  initialize(container, app) {
+    // Our test environment has its own bootstrap code
+    if (isTesting()) {
+      return;
+    const preloadedDataElement = document.getElementById("data-preloaded");
+    const setupData = document.getElementById("data-discourse-setup").dataset;
+    if (preloadedDataElement) {
+      const preloaded = JSON.parse(preloadedDataElement.dataset.preloaded);
+      Object.keys(preloaded).forEach(function(key) {
+        PreloadStore.store(key, JSON.parse(preloaded[key]));
+        if (setupData.debugPreloadedAppData === "true") {
+          /* eslint-disable no-console */
+          console.log(key, PreloadStore.get(key));
+          /* eslint-enable no-console */
+    app.CDN = setupData.cdn;
+    app.BaseUrl = setupData.baseUrl;
+    app.BaseUri = setupData.baseUri;
+    app.Environment = setupData.environment;
+    app.SiteSettings = PreloadStore.get("siteSettings");
+    app.ThemeSettings = PreloadStore.get("themeSettings");
+    app.LetterAvatarVersion = setupData.letterAvatarVersion;
+    app.MarkdownItURL = setupData.markdownItUrl;
+    app.ServiceWorkerURL = setupData.serviceWorkerUrl;
+    I18n.defaultLocale = setupData.defaultLocale;
+    window.Logster = window.Logster || {};
+    window.Logster.enabled = setupData.enableJsErrorReporting === "true";
+    app.set("assetVersion", setupData.assetVersion);
+    Session.currentProp(
+      "disableCustomCSS",
+      setupData.disableCustomCss === "true"
+    if (setupData.safeMode) {
+      Session.currentProp("safe_mode", setupData.safeMode);
+    app.HighlightJSPath = setupData.highlightJsPath;
+    app.SvgSpritePath = setupData.svgSpritePath;
+    if (app.Environment === "development") {
+      app.SvgIconList = setupData.svgIconList;
+    if (setupData.s3BaseUrl) {
+      app.S3CDN = setupData.s3Cdn;
+      app.S3BaseUrl = setupData.s3BaseUrl;
+    RSVP.configure("onerror", function(e) {
+      // Ignore TransitionAborted exceptions that bubble up
+      if (e && e.message === "TransitionAborted") {
+        return;
+      if (Discourse.Environment === "development") {
+        if (e) {
+          if (e.message || e.stack) {
+            console.log(e.message);
+            console.log(e.stack);
+          } else {
+            console.log("Uncaught promise: ", e);
+        } else {
+          console.log("A promise failed but was not caught.");
+      window.onerror(e && e.message, null, null, null, e);
diff --git a/app/assets/javascripts/discourse/app/pre-initializers/inject-discourse-objects.js b/app/assets/javascripts/discourse/app/pre-initializers/inject-discourse-objects.js
index 045798e..9c2a3e4 100644
--- a/app/assets/javascripts/discourse/app/pre-initializers/inject-discourse-objects.js
+++ b/app/assets/javascripts/discourse/app/pre-initializers/inject-discourse-objects.js
@@ -15,6 +15,7 @@ const ALL_TARGETS = ["controller", "component", "route", "model", "adapter"];
 export default {
+  after: "discourse-bootstrap",
     ALL_TARGETS.forEach(t => app.inject(t, "appEvents", "service:app-events"));
diff --git a/app/assets/javascripts/discourse/app/widgets/post-stream.js b/app/assets/javascripts/discourse/app/widgets/post-stream.js
index 6406d1c..1ccb12f 100644
--- a/app/assets/javascripts/discourse/app/widgets/post-stream.js
+++ b/app/assets/javascripts/discourse/app/widgets/post-stream.js
@@ -3,6 +3,7 @@ import { createWidget } from "discourse/widgets/widget";
 import transformPost from "discourse/lib/transform-post";
 import { Placeholder } from "discourse/lib/posts-with-placeholders";
 import { addWidgetCleanCallback } from "discourse/components/mount-widget";
 let transformCallbacks = null;
 export function postTransformCallbacks(transformed) {
@@ -19,7 +20,7 @@ export function addPostTransformCallback(callback) {
   transformCallbacks.push(callback);
-const CLOAKING_ENABLED = !window.inTestEnv;
+const CLOAKING_ENABLED = !isTesting();
 const DAY = 1000 * 60 * 60 * 24;
 const _dontCloak = {};
diff --git a/app/assets/javascripts/preload-application-data.js b/app/assets/javascripts/preload-application-data.js
deleted file mode 100644
index bb11ecb..0000000
--- a/app/assets/javascripts/preload-application-data.js
+++ /dev/null
@@ -1,84 +0,0 @@
-// discourse-skip-module
-(function() {
-  const ps = require("discourse/lib/preload-store").default;
-  const preloadedDataElement = document.getElementById("data-preloaded");
-  const setupData = document.getElementById("data-discourse-setup").dataset;
-  const I18n = require("I18n").default;
-  if (preloadedDataElement) {
-    const preloaded = JSON.parse(preloadedDataElement.dataset.preloaded);
-    Object.keys(preloaded).forEach(function(key) {
-      ps.store(key, JSON.parse(preloaded[key]));
-      if (setupData.debugPreloadedAppData === "true") {
-        /* eslint-disable no-console */
-        console.log(key, ps.get(key));
-        /* eslint-enable no-console */
-  window.Logster = window.Logster || {};
-  window.Logster.enabled = setupData.enableJsErrorReporting === "true";
-  Discourse.CDN = setupData.cdn;
-  Discourse.BaseUrl = setupData.baseUrl;
-  Discourse.BaseUri = setupData.baseUri;
-  Discourse.Environment = setupData.environment;
-  Discourse.SiteSettings = ps.get("siteSettings");
-  Discourse.ThemeSettings = ps.get("themeSettings");
-  Discourse.LetterAvatarVersion = setupData.letterAvatarVersion;
-  Discourse.MarkdownItURL = setupData.markdownItUrl;
-  Discourse.ServiceWorkerURL = setupData.serviceWorkerUrl;
-  I18n.defaultLocale = setupData.defaultLocale;
-  Discourse.start();
-  Discourse.set("assetVersion", setupData.assetVersion);
GitHub sha: 2b2434b8
This commit appears in #9930 which was merged by eviltrout.
https://meta.discourse.org/t/custom-layouts-plugin/55208/268
