strengthen warning around crawler whitelist
diff --git a/config/locales/server.en.yml b/config/locales/server.en.yml
index ac6cd35..0149886 100644
--- a/config/locales/server.en.yml
+++ b/config/locales/server.en.yml
@@ -1422,7 +1422,7 @@ en:
     blacklist_ip_blocks: "A list of private IP blocks that should never be crawled by Discourse"
     whitelist_internal_hosts: "A list of internal hosts that discourse can safely crawl for oneboxing and other purposes"
     allowed_iframes: "A list of iframe src domain prefixes that discourse can safely allow in posts"
-    whitelisted_crawler_user_agents: "User agents of web crawlers that should be allowed to access the site."
+    whitelisted_crawler_user_agents: "User agents of web crawlers that should be allowed to access the site. WARNING! SETTING THIS WILL DISALLOW ALL CRAWLERS NOT LISTED HERE!"
     blacklisted_crawler_user_agents: "Unique case insensitive word in the user agent string identifying web crawlers that should not be allowed to access the site. Does not apply if whitelist is defined."
     slow_down_crawler_user_agents: "User agents of web crawlers that should be rate limited in robots.txt using the Crawl-delay directive"
     slow_down_crawler_rate: "If slow_down_crawler_user_agents is specified this rate will apply to all the crawlers (number of seconds delay between requests)"
GitHub sha: 24346e46
