TopicView/PostSerializer should be able to handle topics without categories
diff --git a/lib/topic_view.rb b/lib/topic_view.rb
index 14db181..b2f37cc 100644
--- a/lib/topic_view.rb
+++ b/lib/topic_view.rb
@@ -431,7 +431,7 @@ class TopicView
   def category_group_moderator_user_ids
     @category_group_moderator_user_ids ||= begin
-      if SiteSetting.enable_category_group_moderation? && @topic.category&.reviewable_by_group&.present?
+      if SiteSetting.enable_category_group_moderation? && @topic.category&.reviewable_by_group.present?
         posts_user_ids = Set.new(@posts.map(&:user_id))
         Set.new(
           @topic.category.reviewable_by_group.group_users.where(user_id: posts_user_ids).pluck('distinct user_id')
diff --git a/spec/serializers/topic_view_serializer_spec.rb b/spec/serializers/topic_view_serializer_spec.rb
index 2599c08..3262da2 100644
--- a/spec/serializers/topic_view_serializer_spec.rb
+++ b/spec/serializers/topic_view_serializer_spec.rb
@@ -379,4 +379,24 @@ describe TopicViewSerializer do
+  context "viewing private messages when enable_category_group_moderation is enabled" do
+    fab!(:pm_topic) do
+      Fabricate(:private_message_topic, topic_allowed_users: [
+        Fabricate.build(:topic_allowed_user, user: user),
+        Fabricate.build(:topic_allowed_user, user: admin)
+    end
+    fab!(:post) { Fabricate(:post, topic: pm_topic) }
+    before do
+      SiteSetting.enable_category_group_moderation = true
+    end
+    # Ensure having enable_category_group_moderation turned on doesn't break private messages
+    it "should return posts" do
+      json = serialize_topic(pm_topic, user)
+      expect(json[:post_stream][:posts]).to be_present
+    end
+  end
GitHub sha: 8f140b89
