UI: fixes sidebar settings border and active styles (#13990)
  • active setting should now correctly show an arrow which was previously floating in the middle of nowhere
  • uses a correct color for border separation, previously the border was present but invisible as similar to the background
  • slighty tweak padding
  • makes arrow computation based on a variable
diff --git a/app/assets/stylesheets/common/components/navs.scss b/app/assets/stylesheets/common/components/navs.scss
index c1d7f39..6bef0c1 100644
--- a/app/assets/stylesheets/common/components/navs.scss
+++ b/app/assets/stylesheets/common/components/navs.scss
@@ -69,7 +69,7 @@
   background: var(--primary-low);
   li {
-    border-bottom: 1px solid var(--primary-low);
+    border-bottom: 1px solid var(--primary-low-mid-or-secondary-high);
     &:last-of-type {
       border-bottom: 0;
@@ -82,7 +82,7 @@
   a {
     margin: 0;
-    padding: 13px;
+    padding: 0.75em;
     font-size: $font-up-1;
     line-height: $line-height-small;
     cursor: pointer;
@@ -92,13 +92,16 @@
     &.active {
       color: var(--secondary);
       background-color: var(--quaternary);
+      position: relative;
+      --arrow-thickness: 8px;
       &::after {
-        left: 90%;
-        top: 33%;
-        content: " ";
         position: absolute;
-        border: 8px solid transparent;
+        right: 0;
+        top: calc(50% - var(--arrow-thickness));
+        content: " ";
+        border: var(--arrow-thickness) solid transparent;
         border-left-color: var(--secondary);
GitHub sha: 2efe91f49f899fbfb8fd148e8894251c0318d0b0
This commit appears in #13990 which was approved by tgxworld. It was merged by jjaffeux.
