UI: improvements to footer nav for app and PWAs
Adds support for iPad and Chrome PWAs
Better scroll direction logic when reaching bottom of the page
diff --git a/app/assets/javascripts/discourse/components/footer-nav.js.es6 b/app/assets/javascripts/discourse/components/footer-nav.js.es6
new file mode 100644
index 0000000..3fe473b
--- /dev/null
+++ b/app/assets/javascripts/discourse/components/footer-nav.js.es6
@@ -0,0 +1,130 @@
+import MountWidget from "discourse/components/mount-widget";
+import MobileScrollDirection from "discourse/mixins/mobile-scroll-direction";
+import Scrolling from "discourse/mixins/scrolling";
+import { observes } from "ember-addons/ember-computed-decorators";
+const MOBILE_SCROLL_DIRECTION_CHECK_THROTTLE = 150;
+const FooterNavComponent = MountWidget.extend(
+  Scrolling,
+  MobileScrollDirection,
+    widget: "footer-nav",
+    mobileScrollDirection: null,
+    scrollEventDisabled: false,
+    classNames: ["footer-nav", "visible"],
+    routeHistory: [],
+    currentRouteIndex: 0,
+    canGoBack: false,
+    canGoForward: false,
+    backForwardClicked: null,
+    buildArgs() {
+      return {
+        canGoBack: this.canGoBack,
+        canGoForward: this.canGoForward
+    didInsertElement() {
+      this._super(...arguments);
+      this.bindScrolling({ name: "footer-nav" });
+      $(window).on("resize.footer-nav-on-scroll", () => this.scrolled());
+      this.appEvents.on("page:changed", this, "_routeChanged");
+      this.appEvents.on("composer:opened", this, "_composerOpened");
+      this.appEvents.on("composer:closed", this, "_composerClosed");
+      $("body").addClass("with-footer-nav");
+    willDestroyElement() {
+      this.unbindScrolling("footer-nav");
+      $(window).unbind("resize.footer-nav-on-scroll");
+      this.appEvents.off("page:changed", this, "_routeChanged");
+      this.appEvents.off("composer:opened", this, "_composerOpened");
+      this.appEvents.off("composer:closed", this, "_composerClosed");
+      $("body").removeClass("with-footer-nav");
+    // The user has scrolled the window, or it is finished rendering and ready for processing.
+    scrolled() {
+      if (
+        this.isDestroyed ||
+        this.isDestroying ||
+        this._state !== "inDOM" ||
+        this.scrollEventDisabled
+        return;
+      const offset = window.pageYOffset || $("html").scrollTop();
+      Ember.run.throttle(
+        this,
+        this.calculateDirection,
+        offset,
+        MOBILE_SCROLL_DIRECTION_CHECK_THROTTLE
+    // We observe the scroll direction on mobile and if it's down, we show the topic
+    // in the header, otherwise, we hide it.
+    @observes("mobileScrollDirection")
+    toggleMobileFooter() {
+      this.$().toggleClass(
+        "visible",
+        this.mobileScrollDirection === null ? true : false
+      // body class used to adjust positioning of #topic-progress-wrapper
+      $("body").toggleClass(
+        "footer-nav-visible",
+    _routeChanged(route) {
+      // only update route history if not using back/forward nav
+      if (this.backForwardClicked) {
+        this.backForwardClicked = null;
+        return;
+      this.routeHistory.push(route.url);
+      this.set("currentRouteIndex", this.routeHistory.length);
+      this.queueRerender();
+    _composerOpened() {
+      this.set("mobileScrollDirection", "down");
+      this.set("scrollEventDisabled", true);
+    _composerClosed() {
+      this.set("mobileScrollDirection", null);
+      this.set("scrollEventDisabled", false);
+    goBack() {
+      this.set("currentRouteIndex", this.get("currentRouteIndex") - 1);
+      this.backForwardClicked = true;
+      window.history.back();
+    goForward() {
+      this.set("currentRouteIndex", this.get("currentRouteIndex") + 1);
+      window.history.forward();
+    @observes("currentRouteIndex")
+    setBackForward() {
+      let index = this.get("currentRouteIndex");
+      this.set("canGoBack", (index > 1 || document.referrer) ? true : false);
+      this.set("canGoForward", index < this.routeHistory.length ? true : false);
+export default FooterNavComponent;
diff --git a/app/assets/javascripts/discourse/components/mobile-footer.js.es6 b/app/assets/javascripts/discourse/components/mobile-footer.js.es6
deleted file mode 100644
index cecfbd4..0000000
--- a/app/assets/javascripts/discourse/components/mobile-footer.js.es6
+++ /dev/null
@@ -1,128 +0,0 @@
-import MountWidget from "discourse/components/mount-widget";
-import MobileScrollDirection from "discourse/mixins/mobile-scroll-direction";
-import Scrolling from "discourse/mixins/scrolling";
-import { observes } from "ember-addons/ember-computed-decorators";
-const MOBILE_SCROLL_DIRECTION_CHECK_THROTTLE = 150;
-const MobileFooterComponent = MountWidget.extend(
-  Scrolling,
-  MobileScrollDirection,
-    widget: "mobile-footer-nav",
-    mobileScrollDirection: null,
-    scrollEventDisabled: false,
-    classNames: ["mobile-footer", "visible"],
-    routeHistory: [],
-    currentRouteIndex: 0,
-    canGoBack: false,
-    canGoForward: false,
-    backForwardClicked: null,
-    buildArgs() {
-      return {
-        canGoBack: this.canGoBack,
-        canGoForward: this.canGoForward
-    didInsertElement() {
-      this._super(...arguments);
-      this.bindScrolling({ name: "mobile-footer" });
-      $(window).on("resize.mobile-footer-on-scroll", () => this.scrolled());
-      this.appEvents.on("page:changed", this, "_routeChanged");
-      this.appEvents.on("composer:opened", this, "_composerOpened");
-      this.appEvents.on("composer:closed", this, "_composerClosed");
-    willDestroyElement() {
-      this.unbindScrolling("mobile-footer");
-      $(window).unbind("resize.mobile-footer-on-scroll");
-      this.appEvents.off("page:changed", this, "_routeChanged");
-      this.appEvents.off("composer:opened", this, "_composerOpened");
-      this.appEvents.off("composer:closed", this, "_composerClosed");
-    // The user has scrolled the window, or it is finished rendering and ready for processing.
-    scrolled() {
-      if (
-        this.isDestroyed ||
-        this.isDestroying ||
-        this._state !== "inDOM" ||
-        this.scrollEventDisabled
-        return;
-      const offset = window.pageYOffset || $("html").scrollTop();
-      Ember.run.throttle(
-        this,
-        this.calculateDirection,
-        offset,
-        MOBILE_SCROLL_DIRECTION_CHECK_THROTTLE
-    // We observe the scroll direction on mobile and if it's down, we show the topic
-    // in the header, otherwise, we hide it.
-    @observes("mobileScrollDirection")
-    toggleMobileFooter() {
-      this.$().toggleClass(
-        "visible",
-        this.mobileScrollDirection === null ? true : false
-      // body class used to adjust positioning of #topic-progress-wrapper
-      $("body").toggleClass(
-        "mobile-footer-nav-visible",
-    _routeChanged(route) {
-      // only update route history if not using back/forward nav
-      if (this.backForwardClicked) {
-        this.backForwardClicked = null;
-        return;
-      this.routeHistory.push(route.url);
-      this.set("currentRouteIndex", this.routeHistory.length);
-      this.queueRerender();
-    _composerOpened() {
-      this.set("mobileScrollDirection", "down");
-      this.set("scrollEventDisabled", true);
-    _composerClosed() {
-      this.set("mobileScrollDirection", null);
-      this.set("scrollEventDisabled", false);
-    goBack() {
-      this.set("currentRouteIndex", this.get("currentRouteIndex") - 1);
-      this.backForwardClicked = true;
GitHub sha: f060c9b3
