Update changelog
diff --git a/CHANGELOG b/CHANGELOG
index 3fddacf..4e2914d 100644
--- a/CHANGELOG
+++ b/CHANGELOG
@@ -1,3 +1,8 @@
+0.4.3 - 11-02-2019
+- Feature: Add alias for Gauge #observe called #set, this makes it a bit easier to migrate from prom
+- Feature: Add increment and decrement to Counter
0.4.2 - 30-11-2018
- Fix/Feature: setting a Gauge to nil will remove Gauge (setting to non numeric will raise)
GitHub sha: a14d00bc
