Update deprecated icon reference
diff --git a/assets/javascripts/discourse/initializers/extend-for-solved-button.js.es6 b/assets/javascripts/discourse/initializers/extend-for-solved-button.js.es6
index 6c9ab7c..ba9f7fe 100644
--- a/assets/javascripts/discourse/initializers/extend-for-solved-button.js.es6
+++ b/assets/javascripts/discourse/initializers/extend-for-solved-button.js.es6
@@ -67,7 +67,7 @@ function initializeWithApi(api) {
   TopicStatusIcons.addObject([
     "has_accepted_answer",
-    "check-square-o",
+    "far-check-square",
     "solved"
@@ -92,7 +92,7 @@ function initializeWithApi(api) {
     if (canAccept) {
       return {
         action: "acceptAnswer",
-        icon: "check-square-o",
+        icon: "far-check-square",
         className: "unaccepted",
         title: "solved.accept_answer",
         position
@@ -227,7 +227,7 @@ export default {
             openTag: "span",
             closeTag: "span",
             title: I18n.t("topic_statuses.solved.help"),
         } else if (
           this.topic.can_have_answer &&
GitHub sha: 2918f4a0
