Update duplicated test description
diff --git a/spec/lib/users_bouncer_spec.rb b/spec/lib/users_bouncer_spec.rb
index 8fd6c5a..ba8cd3e 100644
--- a/spec/lib/users_bouncer_spec.rb
+++ b/spec/lib/users_bouncer_spec.rb
@@ -49,7 +49,7 @@ RSpec.describe DiscourseAkismet::UsersBouncer, if: defined?(Reviewable) do
       expect(subject.should_check_user?(user)).to eq(false)
-    it "returns false when there are no auth token logs for that user" do
+    it "returns false when there client ip is not present" do
       user.user_auth_token_logs = [UserAuthTokenLog.new(client_ip: nil, action: 'an_action')]
GitHub sha: f1f50e06
