Update gemspec: add uris for (changelog/bug tracker/source code) and (#8)
update homepage
diff --git a/mini_sql.gemspec b/mini_sql.gemspec
index e3f7903..987fc3b 100644
--- a/mini_sql.gemspec
+++ b/mini_sql.gemspec
@@ -12,9 +12,15 @@ Gem::Specification.new do |spec|
   spec.summary       = %q{A fast, safe, simple direct SQL executor}
   spec.description   = %q{A fast, safe, simple direct SQL executor for PG}
-  spec.homepage      = "https://discourse.org"
+  spec.homepage      = "https://github.com/discourse/mini_sql"
   spec.license       = "MIT"
+  spec.metadata = {
+    "bug_tracker_uri" => "https://github.com/discourse/mini_sql/issues",
+    "source_code_uri" => "https://github.com/discourse/mini_sql",
+    "changelog_uri" => "https://github.com/discourse/mini_sql/blob/master/CHANGELOG"
   spec.platform = 'java' if RUBY_ENGINE == 'jruby'
   # Specify which files should be added to the gem when it is released.
GitHub sha: 8edd2652
