Update postgres templates (#472)
  • postgres: Allow replication and basebackups to happen
  • the overrides for db_wal_level and db_max_wal_senders disallow replication and basebackups to be taken
  • there is no need for us to disable these features, allow the defaults to stay
  • postgres: remove out-of-support templates
  • taken from https://www.postgresql.org/support/versioning/ :
    • postgres 9.2 and 9.3 are no longer supported
    • 9.5 will be supported until February 11, 2021:
diff --git a/templates/postgres.10.template.yml b/templates/postgres.10.template.yml
index fb5b252..c60350c 100644
--- a/templates/postgres.10.template.yml
+++ b/templates/postgres.10.template.yml
@@ -5,8 +5,6 @@ params:
   db_name: discourse
   db_user: discourse
-  db_wal_level: minimal
-  db_max_wal_senders: 0
   db_checkpoint_segments: 6
   db_logging_collector: off
   db_log_min_duration_statement: 100
diff --git a/templates/postgres.12.template.yml b/templates/postgres.12.template.yml
index 20cd5d8..b4b76f5 100644
--- a/templates/postgres.12.template.yml
+++ b/templates/postgres.12.template.yml
   db_name: discourse
   db_user: discourse
diff --git a/templates/postgres.9.2.template.yml b/templates/postgres.9.2.template.yml
deleted file mode 100644
index b716877..0000000
--- a/templates/postgres.9.2.template.yml
+++ /dev/null
@@ -1,97 +0,0 @@
-hooks:
-  before_code:
-    - replace:
-       filename: /etc/service/unicorn/run
-       to: sv start postgres || exit 1
-run:
-  - exec: mkdir -p /shared/postgres_run
-  - exec: chown postgres:postgres /shared/postgres_run
-  - exec: chmod 775 /shared/postgres_run
-  - exec: rm -fr /var/run/postgresql
-  - exec: ln -s /shared/postgres_run /var/run/postgresql
-  - exec: socat /dev/null UNIX-CONNECT:/shared/postgres_run/.s.PGSQL.5432 || exit 0 && echo postgres already running stop container ; exit 1
-  - file:
-     path: /etc/service/postgres/run
-     chmod: "+x"
-     contents: |
-        #!/bin/sh
-        exec 2>&1
-        exec sudo -u postgres /usr/lib/postgresql/9.2/bin/postmaster -D /etc/postgresql/9.2/main
-  - exec:
-      cmd:
-        - chown -R root /var/lib/postgresql/9.2/main
-        - "[ ! -e /shared/postgres_data ] && install -d -m 0755 -o postgres -g postgres /shared/postgres_data && sudo -u postgres /usr/lib/postgresql/9.2/bin/initdb -D /shared/postgres_data || exit 0"
-        - chown -R postgres:postgres /shared/postgres_data
-  - replace:
-      filename: "/etc/postgresql/9.2/main/postgresql.conf"
-      from: "data_directory = '/var/lib/postgresql/9.2/main'"
-      to: "data_directory = '/shared/postgres_data'"
-  # listen on all interfaces
-  - replace:
-      to: "listen_addresses = '*'"
-  # Necessary to enable backups
-  - exec:
-      cmd:
-        - install -d -m 0755 -o postgres -g postgres /shared/postgres_backup
-  - replace:
-      to: "max_wal_senders = 4"
-  - replace:
-      to: "wal_level = hot_standby"
-  - replace:
-      filename: "/etc/postgresql/9.2/main/pg_hba.conf"
-      to: "local replication postgres  peer"
-  # allow all to connect in with md5 auth
-  - replace:
-      to: "host all all 0.0.0.0/0 md5"
-  - exec:
-      background: true
-      cmd: "sudo -u postgres /usr/lib/postgresql/9.2/bin/postmaster -D /etc/postgresql/9.2/main"
-  # give db a few secs to start up
-  - exec: "sleep 5"
-  - exec: sudo -u postgres createdb discourse || exit 0
-  - exec:
-      stdin: |
-        create user discourse;
-      cmd: sudo -u postgres psql discourse
-      raise_on_fail: false
-  - exec:
-      stdin: |
-        grant all privileges on database discourse to discourse;
-  - exec: /bin/bash -c 'sudo -u postgres psql discourse <<< "alter schema public owner to discourse;"'
-  - exec: /bin/bash -c 'sudo -u postgres psql discourse <<< "create extension if not exists hstore;"'
-  - exec: /bin/bash -c 'sudo -u postgres psql discourse <<< "create extension if not exists pg_trgm;"'
-  - exec:
-      stdin: |
-        update pg_database set encoding = pg_char_to_encoding('UTF8') where datname = 'discourse' AND encoding = pg_encoding_to_char('SQL_ASCII');
-  - exec:
-      hook: postgres
-      cmd: "echo postgres installed!"
diff --git a/templates/postgres.9.3.template.yml b/templates/postgres.9.3.template.yml
index dc90025..0000000
--- a/templates/postgres.9.3.template.yml
+++ /dev/null
@@ -1,182 +0,0 @@
-params:
-  db_synchronous_commit: "off"
-  db_shared_buffers: "256MB"
-  db_work_mem: "10MB"
-  db_default_text_search_config: "pg_catalog.english"
-  db_name: discourse
-  db_user: discourse
-  db_checkpoint_segments: 6
-  db_logging_collector: off
-  db_log_min_duration_statement: 100
-hooks:
-  before_code:
-    - replace:
-run:
-  - exec: apt-get remove -y postgresql-9.5 postgresql-client-9.5 postgresql-contrib-9.5
-  - exec: apt-get update && apt-get install -y postgresql-9.3 postgresql-client-9.3 postgresql-contrib-9.3
-  - exec: /etc/init.d/postgresql stop
-  - exec: rm -fr /shared/postgres_run/.s*
-  - exec: rm -fr /shared/postgres_run/*.pid
-  - exec: mkdir -p /shared/postgres_run/9.3-main.pg_stat_tmp
-  - exec: chown postgres:postgres /shared/postgres_run/9.3-main.pg_stat_tmp
-  - replace:
-      filename: "/etc/postgresql/9.3/main/postgresql.conf"
-      to: "port = 5432"
-  - file:
-     chmod: "+x"
-     contents: |
-        #!/bin/sh
-        exec 2>&1
-        echo -1000 >/proc/self/oom_score_adj
-        HOME=/var/lib/postgresql USER=postgres exec chpst -u postgres:postgres:ssl-cert -U postgres:postgres:ssl-cert /usr/lib/postgresql/9.3/bin/postmaster -D /etc/postgresql/9.3/main
-  - file:
-     path: /etc/runit/3.d/99-postgres
-     chmod: "+x"
-     contents: |
-       #!/bin/bash
-       sv stop postgres
-  - exec:
-      cmd:
-        - chown -R root /var/lib/postgresql/9.3/main
-        - "[ ! -e /shared/postgres_data ] && install -d -m 0755 -o postgres -g postgres /shared/postgres_data && sudo -E -u postgres /usr/lib/postgresql/9.3/bin/initdb -D /shared/postgres_data || exit 0"
-        - chown -R postgres:postgres /var/run/postgresql
-  - replace:
-      from: "data_directory = '/var/lib/postgresql/9.3/main'"
-  - replace:
-  # sync commit off is faster and less spiky, also marginally less safe
-  - replace:
-      to: "synchronous_commit = $db_synchronous_commit"
-  # default is 128MB which is way too small
-  - replace:
-      to: "shared_buffers = $db_shared_buffers"
GitHub sha: 278b7793
This commit appears in #472 which was approved by tgxworld. It was merged by Falco.
Seems that this commit is breaking rebuilds, replaces are still trying to use the now removed params
