Update readme with rswag instructions
diff --git a/README.md b/README.md
index 4216399..c36d780 100644
--- a/README.md
+++ b/README.md
@@ -6,9 +6,25 @@ To view the the Discourse API Documentation you can visit:
 ### Contributing
-Contributions are welcome! Start by cloning the repo.
+Contributions are welcome! Start by cloning this repo as well as the
+[discourse](https://github.com/discourse/discourse) repo.
-To edit the api docs, edit the openapi.yml file not the json file.
+The API docs are automatically generated from the discourse repo using a tool
+called rswag.
+You can generate the openapi.yml file that is located in this repo by running
+this command from inside of your discourse repo directory:
+rake rswag:specs:swaggerize && cp openapi/openapi.yaml ~/code/discourse_api_docs/openapi.yml
+Please do not manually edit the openapi.yml or openapi.json files located in
+this repo. These files must be edited from the rswag files located in
+https://github.com/discourse/discourse/tree/main/spec/requests/api
 To view your changes locally, run:
GitHub sha: 681924f8aafd80ce8d6b9cbda679ba0a95c75593
