update readme
update readme
diff --git a/README.md b/README.md
index 17a249d..2d6fcdf 100644
--- a/README.md
+++ b/README.md
@@ -2,20 +2,14 @@
 This plugin adds support for logging in to a Discourse site via VK.
-## How to Help
-- Create a PR with a new translation!
-- Log Issues
-- Submit PRs to help resolve issues
 ## Installation
 1. Follow the directions at [Install a Plugin](https://meta.discourse.org/t/install-a-plugin/19157) using https://github.com/discourse/discourse-plugin-linkedin-auth.git as the repository URL.
 2. Rebuild the app using `./launcher rebuild app`
 3. Create a new application (or use existing one) at https://vk.com/apps?act=manage.
-4. Update the application settings and note the app ID and Secure key.
+4. Go to the application settings and note the app ID and Secure key.
 5. In your Discourse instance, go to Site Settings, filter by "VK" and enter the app ID and the Secure key.
-6. Enable the plugin, and you're done!
+6. Check the "vk auth enabled" checkbox, and you're done!
 ## Notes
GitHub sha: b9b0f9a857fab7fd99e035be4641d53e4a30c46b
