Update spec/components/concern/has_custom_fields_spec.rb
Co-authored-by: Régis Hanol regis@hanol.fr
diff --git a/spec/components/concern/has_custom_fields_spec.rb b/spec/components/concern/has_custom_fields_spec.rb
index e74da75..8970630 100644
--- a/spec/components/concern/has_custom_fields_spec.rb
+++ b/spec/components/concern/has_custom_fields_spec.rb
@@ -338,7 +338,7 @@ describe HasCustomFields do
         expect(test_item.custom_fields['abc']).to eq('ghi')
-      it 'allows using string and symbol indices interchangably' do
+      it 'allows using string and symbol indices interchangeably' do
         test_item = CustomFieldsTestItem.new
         test_item.custom_fields["bob"] = "marley"
GitHub sha: 7e529020
This commit appears in #10486 which was approved by eviltrout. It was merged by eviltrout.
