Update spec/components/concern/has_custom_fields_spec.rb
Co-authored-by: Régis Hanol regis@hanol.fr
diff --git a/spec/components/concern/has_custom_fields_spec.rb b/spec/components/concern/has_custom_fields_spec.rb
index 8970630..51138c8 100644
--- a/spec/components/concern/has_custom_fields_spec.rb
+++ b/spec/components/concern/has_custom_fields_spec.rb
@@ -354,7 +354,7 @@ describe HasCustomFields do
          expect(test_item.custom_fields[:bob]).to eq('marley')
          expect(test_item.custom_fields[:jack]).to eq('black')
-         ## Update via string index again
+         # Update via string index again
          test_item.custom_fields['bob'] = 'the builder'
          expect(test_item.custom_fields[:bob]).to eq('the builder')
GitHub sha: 2100de44
This commit appears in #10486 which was approved by eviltrout. It was merged by eviltrout.
