Update translations (#13228)
diff --git a/config/locales/client.ar.yml b/config/locales/client.ar.yml
index 69cabd3..b38533b 100644
--- a/config/locales/client.ar.yml
+++ b/config/locales/client.ar.yml
@@ -756,7 +756,6 @@ ar:
           mailboxes:
             synchronized: "صندوق البريد المتزامن"
             none_found: "لم توجد صناديق بريد في حساب البريد الإلكتروني هذا."
-            disabled: "معطّل"
         membership:
           title: العضوية
           access: صلاحية
@@ -4355,6 +4354,7 @@ ar:
           require_approval: "يحتاج لموافقة"
           flag: "علم"
           replace: "غير"
+          silence: "صامت"
         action_descriptions:
           require_approval: "المنشورات التي تحتوي على هذه الكلمات تحتاج الى موافقة الطاقم قبل ان يتم رؤيتهم."
           flag: "اسمح للمنشورات التي تحتوي على هذه الكلمات, ولكن علمهم كـ غير مناسب لكي يتمكن المشرف من مراجعتهم."
diff --git a/config/locales/client.be.yml b/config/locales/client.be.yml
index c74823f..a1afcda 100644
--- a/config/locales/client.be.yml
+++ b/config/locales/client.be.yml
@@ -315,8 +315,6 @@ be:
             password: "Пароль"
           settings:
             title: "Налады"
-          mailboxes:
-            disabled: "адключана"
         membership:
           access: доступ
         categories:
diff --git a/config/locales/client.bs_BA.yml b/config/locales/client.bs_BA.yml
index 8aca0a7..12a6e49 100644
--- a/config/locales/client.bs_BA.yml
+++ b/config/locales/client.bs_BA.yml
@@ -641,7 +641,6 @@ bs_BA:
           mailboxes:
             synchronized: "Sinkronizirani poštanski sandučić"
             none_found: "Na ovom računu e-pošte nisu pronađeni poštanski sandučići."
-            disabled: "deaktiviran"
         membership:
           title: Članstvo
           access: Pristup
@@ -3915,6 +3914,7 @@ bs_BA:
           require_approval: "Zahtjeva Dozvolu"
           flag: "Prijava"
           replace: "Zamijeni"
+          silence: "Stišaj"
           block: "Spriječite postavljanje postova koji sadrže ove riječi. Korisnik će vidjeti poruku o pogrešci kada pokuša da pošalje svoj post."
           censor: "Dopustite poruke koje sadrže te riječi, ali ih zamijenite znakovima koji kriju cenzurirane riječi."
diff --git a/config/locales/client.ca.yml b/config/locales/client.ca.yml
index 9e60aec..a341bb6 100644
--- a/config/locales/client.ca.yml
+++ b/config/locales/client.ca.yml
@@ -595,8 +595,6 @@ ca:
             password: "Contrasenya"
           settings:
             title: "Configuració"
-          mailboxes:
-            disabled: "desactivat"
         membership:
           title: Membres
           access: Accés
@@ -3685,6 +3683,7 @@ ca:
           require_approval: "Requereix aprovació"
           flag: "Bandera"
           replace: "Reemplaça"
+          silence: "Silencia"
           block: "Impedeix que es publiquin texts que continguin aquestes paraules. L'usuari veurà un missatge d'error quan intenti enviar la publicació. "
           censor: "Permet publicacions que contenen aquestes paraules, però reemplaça-les amb caràcters que amaguin les paraules censurades."
diff --git a/config/locales/client.cs.yml b/config/locales/client.cs.yml
index 51341ed..61a0a76 100644
--- a/config/locales/client.cs.yml
+++ b/config/locales/client.cs.yml
@@ -3470,6 +3470,7 @@ cs:
           censor: "Cenzurovat "
           require_approval: "Vyžádat schválení"
           flag: "Nahlášení"
+          silence: "Ztišit"
           block: "Zabránit přidání příspěvků obsahující tato slova. Uživatel uvidí chybovou hlášku ve chvíli, kdy se pokusí odeslat svůj příspěvek."
           censor: "Povolit příspěvky obsahující tato slova, ale nahradit je symboly, které skryjí cenzurovaná slova."
diff --git a/config/locales/client.da.yml b/config/locales/client.da.yml
index e24169c..fd4f224 100644
--- a/config/locales/client.da.yml
+++ b/config/locales/client.da.yml
@@ -647,7 +647,6 @@ da:
           mailboxes:
             synchronized: "Synkroniseret postkasse"
             none_found: "Ingen postkasser blev fundet i denne e-mail-konto."
-            disabled: "deaktiveret"
         membership:
           title: Medlemskab
           access: Adgang
@@ -964,12 +963,15 @@ da:
       no_bookmarks_body: >
         Start med at bogmærke indlæg med %{icon} knappen, så bliver de vist her for at gøre det nemt at genfinde dem. Du kan også planlægge påmindelse!
       no_notifications_title: "Du har ingen notifikationer endnu"
+      no_notifications_body: >
+        Du vil blive underrettet i dette panel om aktivitet, der er direkte relevant for dig, herunder svar på dine emner og indlæg, når nogen <b>@omtaler</b> dig eller citerer dig, og svarer på emner, du læser. Underretninger sendes også til din e-mail, når du ikke har været logget ind i et stykke tid. <br><br> Se efter %{icon} ikonet der bestemmer, hvilke specifikke emner, kategorier og mærker du vil have besked om. For mere, se dine <a href='%{preferencesUrl}'>meddelelsesindstillinger</a>.
       first_notification: "Din første notifikation! Vælg den for at begynde."
       dynamic_favicon: "Vis tællinger på browser-ikonet"
       skip_new_user_tips:
         description: "Spring nye bruger-onboarding tips og emblemer over"
         not_first_time: "Ikke din første gang?"
         skip_link: "Spring disse tips over"
+        read_later: "Jeg læser det senere."
       theme_default_on_all_devices: "Gør dette til standard temaet på alle mine enheder"
       color_scheme_default_on_all_devices: "Sæt standard farveskema(er) på alle mine enheder"
       color_scheme: "Farveskema"
@@ -2648,7 +2650,7 @@ da:
         other: "se %{count} udeladte indlæg "
       notice:
         new_user: "Dette er første gang %{user} har sendt - lad os byde dem velkommen til vores fællesskab!"
-        returning_user: "Det er et stykke tid siden vi har set %{user} - deres sidste indlæg var %{time}."
+        returning_user: "Det er et stykke tid siden vi har set %{user} — deres sidste indlæg var %{time}."
       unread: "Indlæg er ulæst"
       has_replies:
         one: "%{count} Svar"
@@ -3372,7 +3374,7 @@ da:
           description: "Du sporer automatisk alle emner med dette mærke. Et antal for ulæste og nye indlæg vises ved siden af emnet."
         regular:
           title: "Almindeligt"
-          description: "Du vil blive notificeret if nogen nævner dit You will be notified if someone mentions your @name or replies to your post."
+          description: "Du får besked, hvis nogen nævner dit @navn eller svarer på dit indlæg."
         muted:
           title: "Lydløs"
           description: "Du vil ikke blive underrettet om noget vedr. nye emner med dette mærke, og de vises ikke på din ulæste fane."
@@ -4360,6 +4362,7 @@ da:
           flag: "Rapportér"
           replace: "Erstat"
           tag: "Mærke"
+          silence: "Mådehold (silence)"
           block: "Undgå, at indlæg, der indeholder disse ord, bliver sendt. Brugeren vil se en fejlmeddelelse, når de prøver at indsende deres post."
           censor: "Tillad indlæg, der indeholder disse ord, men erstat dem med tegn, der skjuler de censurerede ord."
diff --git a/config/locales/client.de.yml b/config/locales/client.de.yml
index ffd041c..2319e95 100644
--- a/config/locales/client.de.yml
+++ b/config/locales/client.de.yml
@@ -647,7 +647,6 @@ de:
           mailboxes:
             synchronized: "Synchronisierte Mailbox"
             none_found: "In diesem E-Mail Konto wurden keine Postfächer gefunden."
-            disabled: "deaktiviert"
         membership:
           title: Mitgliedschaft
           access: Zugriff
@@ -4397,6 +4396,7 @@ de:
           flag: "Melden"
           replace: "Ersetzen"
           tag: "Schlagwort"
+          silence: "Stummschalten"
GitHub sha: 8a99ee88
This commit appears in #13228 which was approved by gschlager. It was merged by gschlager.
