Update translations (#14648)
diff --git a/config/locales/client.ar.yml b/config/locales/client.ar.yml
index 4f49b1a..d2b293f 100644
--- a/config/locales/client.ar.yml
+++ b/config/locales/client.ar.yml
@@ -2748,6 +2748,7 @@ ar:
         time_frame_required: "يُرجى تحديد إطار زمني"
         min_duration: "يجب أن تكون المدة أكبر من 0"
         max_duration: "يجب أن تكون المدة أقل من 20 عامًا"
+        duration: "المدة"
       auto_update_input:
         none: "تحديد إطار زمني"
         now: "الآن"
@@ -3268,6 +3269,7 @@ ar:
             other: "نعم، و%{count} رد"
           just_the_post: "لا، هذا المنشور فقط"
         admin: "إجراءات المسؤول على المنشور"
+        permanently_delete: "الحذف بشكلٍ دائم"
         wiki: "التحويل إلى Wiki"
         unwiki: "إزالة Wiki"
         convert_to_moderator: "لون إضافة فريق العمل"
diff --git a/config/locales/client.bg.yml b/config/locales/client.bg.yml
index 557f39d..804f0e1 100644
--- a/config/locales/client.bg.yml
+++ b/config/locales/client.bg.yml
@@ -1486,6 +1486,7 @@ bg:
         remove: "Деактивиране"
       topic_status_update:
         when: "Кога:"
+        duration: "Продължителност"
       auto_update_input:
         none: "Избери времева рамка"
         later_today: "По-късно днес"
diff --git a/config/locales/client.bs_BA.yml b/config/locales/client.bs_BA.yml
index 741e233..bbe1933 100644
--- a/config/locales/client.bs_BA.yml
+++ b/config/locales/client.bs_BA.yml
@@ -2067,6 +2067,7 @@ bs_BA:
         publish_to: "Objavi u:"
         when: "Kada:"
         time_frame_required: "Odaberite vremenski okvir"
+        duration: "Trajanje"
       auto_update_input:
         none: "Označi vremenski period"
         later_today: "Na kraju dana"
diff --git a/config/locales/client.ca.yml b/config/locales/client.ca.yml
index ecf773e..57c29c0 100644
--- a/config/locales/client.ca.yml
+++ b/config/locales/client.ca.yml
@@ -1938,6 +1938,7 @@ ca:
         publish_to: "Publica en:"
         when: "Quan:"
         time_frame_required: "Seleccioneu un període de temps"
+        duration: "Duració"
       auto_update_input:
         none: "Seleccioneu un període de temps"
         later_today: "Més tard avui"
diff --git a/config/locales/client.cs.yml b/config/locales/client.cs.yml
index 1b7fe66..0c1ee17 100644
--- a/config/locales/client.cs.yml
+++ b/config/locales/client.cs.yml
@@ -1915,6 +1915,7 @@ cs:
         publish_to: "Publikovat v:"
         when: "Když:"
         time_frame_required: "Vyberte prosím časové období"
+        duration: "Doba trvání"
       auto_update_input:
         none: "Vyberte časové období"
         later_today: "Později během dnešního dne"
diff --git a/config/locales/client.da.yml b/config/locales/client.da.yml
index 496d956..ac82b7e 100644
--- a/config/locales/client.da.yml
+++ b/config/locales/client.da.yml
@@ -2331,6 +2331,7 @@ da:
         time_frame_required: "Vælg venligst en tidsramme"
         min_duration: "Varigheden skal være større end 0"
         max_duration: "Varigheden skal være mindre end 20 år"
+        duration: "Varighed"
       auto_update_input:
         none: "Vælg en tidsramme"
         now: "Nu"
@@ -2747,6 +2748,7 @@ da:
             other: "Ja, og alle %{count} svar"
           just_the_post: "Nej, kun dette indlæg"
         admin: "indlæg administrator handlinger"
+        permanently_delete: "Slet permanent"
         wiki: "Opret Wiki"
         unwiki: "Fjern Wiki"
         convert_to_moderator: "Tilføj Personale farve"
diff --git a/config/locales/client.de.yml b/config/locales/client.de.yml
index ee9223f..72c0ba0 100644
--- a/config/locales/client.de.yml
+++ b/config/locales/client.de.yml
@@ -283,6 +283,7 @@ de:
     bookmarks:
       created: "Du hast diesen Beitrag mit einem Lesezeichen versehen. %{name}"
       not_bookmarked: "diesen Beitrag mit Lesezeichen versehen"
+      remove_reminder_keep_bookmark: "Erinnerung entfernen und Lesezeichen behalten"
       created_with_reminder: "Du wirst %{date} an dieses Lesezeichen erinnert. %{name}"
       remove: "Lesezeichen entfernen"
       delete: "Lesezeichen löschen"
@@ -2160,7 +2161,9 @@ de:
       tags: "Schlagwörter"
       in: "in"
       in_this_topic: "in diesem Thema"
+      in_this_topic_tooltip: "zur Suche in allen Themen wechseln"
       in_topics_posts: "in allen Themen und Beiträgen"
+      enter_hint: "oder drücke die Eingabetaste"
       in_posts_by: "in Beiträgen von %{username}"
       type:
         default: "Themen/Beiträge"
@@ -2420,6 +2423,7 @@ de:
         time_frame_required: "Bitte wähle einen Zeitrahmen aus"
         min_duration: "Dauer muss mehr als 0 betragen"
         max_duration: "Dauer muss weniger als 20 Jahre betragen"
+        duration: "Dauer"
       auto_update_input:
         none: "Wähle einen Zeitrahmen aus"
         now: "Jetzt"
@@ -2849,6 +2853,8 @@ de:
             other: "Ja und alle %{count} Antworten"
           just_the_post: "Nein, nur diesen Beitrag"
         admin: "Administrative Aktionen"
+        permanently_delete: "Endgültig löschen"
+        permanently_delete_confirmation: "Bist Du sicher, dass Du diesen Beitrag dauerhaft löschen möchtest? Du wirst ihn nicht wiederherstellen können."
         wiki: "Wiki erstellen"
         unwiki: "Wiki entfernen"
         convert_to_moderator: "Team-Einfärbung hinzufügen"
diff --git a/config/locales/client.el.yml b/config/locales/client.el.yml
index 5a77c2f..3d2c722 100644
--- a/config/locales/client.el.yml
+++ b/config/locales/client.el.yml
@@ -2061,6 +2061,7 @@ el:
         publish_to: "Δημοσίευση Σε:"
         when: "Πότε:"
         time_frame_required: "Παρακαλώ επιλέξτε ένα χρονικό πλαίσιο"
+        duration: "Διάρκεια"
       auto_update_input:
         none: "Επιλέξτε χρονικό περιθώριο"
         now: "Τώρα"
diff --git a/config/locales/client.es.yml b/config/locales/client.es.yml
index f4e06be..f69b66f 100644
--- a/config/locales/client.es.yml
+++ b/config/locales/client.es.yml
@@ -1142,6 +1142,7 @@ es:
         tags: "Etiquetas"
         warnings: "Advertencias oficiales"
         read_more_in_group: "¿Quieres leer más? Consulta otros mensajes de %{groupLink}."
+        read_more: "¿Quieres leer más? Echa un vistazo a otros mensajes dentro de tus <a href='%{basePath}/u/%{username}/message'>mensajes personales</a>."
       preferences_nav:
         account: "Cuenta"
         security: "Seguridad"
@@ -2158,6 +2159,7 @@ es:
       in: "en"
       in_this_topic: "en este tema"
       in_topics_posts: "en todos los temas y publicaciones"
+      enter_hint: "o pulsa Intro"
       in_posts_by: "en publicaciones por %{username}"
       type:
         default: "Temas/respuestas"
@@ -2171,6 +2173,10 @@ es:
         topic: "Buscar en este tema"
         private_messages: "Buscar en mensajes"
       tips:
+        category_tag: "filtra por categoría o etiqueta"
+        author: "filtra por el autor de la publicación"
+        in: "filtra según los metadatos (por ejemplo, in:title, in:personal, in:pinned)"
+        status: "filtra por el estado del tema"
         full_search: "lanza la página de búsqueda"
         full_search_key: "%{modifier} + Intro"
       advanced:
@@ -2413,6 +2419,7 @@ es:
         time_frame_required: "Selecciona un intervalo de tiempo"
         min_duration: "La duración debe ser mayor que 0"
         max_duration: "La duración debe ser inferior a 20 años"
+        duration: "Duración"
       auto_update_input:
         none: "Selecciona el plazo"
         now: "Ahora"
@@ -2747,7 +2754,9 @@ es:
       deleted_by_author_simple: "(tema eliminado por su autor/a)"
     post:
       quote_reply: "Citar"
+      quote_reply_shortcut: "O pulsa q"
       quote_edit: "Editar"
+      quote_edit_shortcut: "O pulsa e"
       quote_share: "Compartir"
       edit_reason: "Motivo: "
       post_number: "publicación %{number}"
@@ -2840,6 +2849,8 @@ es:
             other: "Sí, y todas las %{count} respuestas"
           just_the_post: "No, solo esta publicación"
         admin: "acciones de administrador para la publicación"
GitHub sha: 25097fa0af9927d4fb43a5b195951c8c533acf02
This commit appears in #14648 which was approved by gschlager. It was merged by gschlager.
