Update translations (#14757)
diff --git a/config/locales/client.ar.yml b/config/locales/client.ar.yml
index d2b293f..a2710fb 100644
--- a/config/locales/client.ar.yml
+++ b/config/locales/client.ar.yml
@@ -4756,12 +4756,8 @@ ar:
               %{example}
               يوصى بشدة بوضع بادئة لأسماء الخصائص لتجنُّب تعارضها مع المكوِّنات الإضافية أو الأساسية.
-          head_tag:
-            text: "</‎head>"
-            title: "HTML الذي سيتم إدراجه قبل وسم ‎</head>‎"
           body_tag:
-            text: "</‎body>"
-            title: "HTML الذي سيتم إدراجه قبل وسم ‎</body>‎"
+            text: "النص الأساسي"
           yaml:
             text: "YAML"
             title: "تحديد إعدادات السمة بتنسيق YAML"
diff --git a/config/locales/client.be.yml b/config/locales/client.be.yml
index f45ae45..b8653f4 100644
--- a/config/locales/client.be.yml
+++ b/config/locales/client.be.yml
@@ -1563,8 +1563,8 @@ be:
           add: "Дадаць"
           header:
             text: "Header"
-          head_tag:
-            text: "<"
+          body_tag:
+            text: "цела"
         colors:
           title: "<......"
           copy_name_prefix: "капіяваць з"
diff --git a/config/locales/client.bg.yml b/config/locales/client.bg.yml
index 804f0e1..80fd99d 100644
--- a/config/locales/client.bg.yml
+++ b/config/locales/client.bg.yml
@@ -2444,12 +2444,8 @@ bg:
             text: "Футър"
           embedded_scss:
             text: "ембеднато CSS"
-          head_tag:
-            text: "</head>"
-            title: "HTML код който ще бъде поставен преди </head> тага"
           body_tag:
-            text: "</body>"
-            title: "HTML код който ще бъде поставен преди </body> тага"
+            text: "Тяло"
         colors:
           title: "Цветове"
           copy_name_prefix: "Копие на"
diff --git a/config/locales/client.bs_BA.yml b/config/locales/client.bs_BA.yml
index bbe1933..09cdfca 100644
--- a/config/locales/client.bs_BA.yml
+++ b/config/locales/client.bs_BA.yml
@@ -3596,12 +3596,8 @@ bs_BA:
           embedded_scss:
             text: "Ugrađeni CSS"
             title: "Unesite prilagođeni CSS za isporuku s ugrađenom verzijom komentara"
-          head_tag:
-            text: "</head>"
-            title: "HTML koji će biti umetnut prije </head> tag"
           body_tag:
-            text: "</body>"
-            title: "HTML koji će biti umetnut prije </body> tag"
+            text: "Tijelo"
           yaml:
             text: "YAML"
             title: "Definirajte postavke teme u YAML formatu"
diff --git a/config/locales/client.ca.yml b/config/locales/client.ca.yml
index 57c29c0..2fa441b 100644
--- a/config/locales/client.ca.yml
+++ b/config/locales/client.ca.yml
@@ -3379,12 +3379,8 @@ ca:
           embedded_scss:
             text: "CSS incrustat"
             title: "Introduïu el CSS personalitzat que es lliurarà amb la versió incrustada dels comentaris"
-          head_tag:
-            text: "</head>"
-            title: "HTML que s'inclourà abans de l'etiqueta </head>"
           body_tag:
-            text: "</body>"
-            title: "HTML que s'inclourà abans de l'etiqueta </body>"
+            text: "Cos"
           yaml:
             text: "YAML"
             title: "Definiu la configuració de l'aparença en format YAML"
diff --git a/config/locales/client.cs.yml b/config/locales/client.cs.yml
index 0c1ee17..092916e 100644
--- a/config/locales/client.cs.yml
+++ b/config/locales/client.cs.yml
@@ -3215,12 +3215,8 @@ cs:
           embedded_scss:
             text: "Vloženo CSS"
             title: "Zadat vlastní CSS k doručení s vloženou verzí kometářů"
-          head_tag:
-            text: "</head>"
-            title: "HTML které bude vloženo před</head> štítkem"
           body_tag:
-            text: "</body>"
-            title: "HTML, který bude vložený před </body>štítek"
+            text: "Tělo"
           yaml:
             text: "YAML"
             title: "Definovat nastavení motivu ve formátu YAML"
diff --git a/config/locales/client.da.yml b/config/locales/client.da.yml
index ac82b7e..f66e08b 100644
--- a/config/locales/client.da.yml
+++ b/config/locales/client.da.yml
@@ -4070,12 +4070,8 @@ da:
               %{example}
               Præfiksering af egenskabsnavne anbefales stærkt for at undgå konflikter med plugins og/eller kernen.
-          head_tag:
-            text: "</head>"
-            title: "HTML som vil blive sat ind før tagget </head>"
           body_tag:
-            text: "</body>"
-            title: "HTML som vil blive sat ind før tagget </body>"
+            text: "Brødtekst"
           yaml:
             text: "YAML"
             title: "Definér tema indstillinger i YAML-format"
diff --git a/config/locales/client.de.yml b/config/locales/client.de.yml
index 535a6dd..2ea124e 100644
--- a/config/locales/client.de.yml
+++ b/config/locales/client.de.yml
@@ -4222,12 +4222,8 @@ de:
               %{example}
               Eigenschaften sollten mit einem Präfix versehen werden, um Konflikte mit Discourse und/oder Plug-ins zu vermeiden.
-          head_tag:
-            text: "</head>"
-            title: "HTML, das vor dem </head>-Tag eingefügt wird"
           body_tag:
-            text: "</body>"
-            title: "HTML, das vor dem </body>-Tag eingefügt wird"
+            text: "Body"
           yaml:
             text: "YAML"
             title: "Definiere Theme-Einstellungen im YAML-Format"
diff --git a/config/locales/client.el.yml b/config/locales/client.el.yml
index 3d2c722..6886d48 100644
--- a/config/locales/client.el.yml
+++ b/config/locales/client.el.yml
@@ -3643,12 +3643,8 @@ el:
           color_definitions:
             text: "Ορισμοί χρωμάτων"
             title: "Εισαγωγή προσαρμοσμένων ορισμών χρωμάτων (μόνο για προχωρημένους χρήστες)"
-          head_tag:
-            text: "</head>"
-            title: "HTML το οποίο θα προστίθεται πριν το </head> tag"
           body_tag:
-            text: "</body>"
-            title: "HTML το οποίο θα προστίθεται πριν το </body> tag"
+            text: "Body"
           yaml:
             text: "YAML"
             title: "Ορισμός ρυθμίσεων θέματος σε μορφή YAML"
diff --git a/config/locales/client.es.yml b/config/locales/client.es.yml
index e0b6da5..dbcdaf3 100644
--- a/config/locales/client.es.yml
+++ b/config/locales/client.es.yml
@@ -4216,12 +4216,8 @@ es:
               %{example}
               Se recomienda poner prefijos a los nombres de propiedad para evitar conflictos con plugins o el core
-          head_tag:
-            text: "</head>"
-            title: "HTML a insertar antes de la etiqueta </head>"
           body_tag:
-            text: "</body>"
-            title: "HTML a insertar antes de la etiqueta </body>"
+            text: "Cuerpo"
           yaml:
             text: "YAML"
             title: "Definir ajustes al tema en formato YAML"
diff --git a/config/locales/client.et.yml b/config/locales/client.et.yml
index 3337d90..78190f3 100644
--- a/config/locales/client.et.yml
+++ b/config/locales/client.et.yml
@@ -2899,12 +2899,8 @@ et:
             text: "Jalus"
           embedded_scss:
             text: "Sängitatud CSS"
-          head_tag:
-            text: "</head>"
-            title: "HTML, mida lisatakse enne </head> silti"
           body_tag:
-            text: "</body>"
-            title: "HTML, mida lisatakse enne </body> silti"
+            text: "Sisu"
           yaml:
             text: "YAML"
         colors:
diff --git a/config/locales/client.fa_IR.yml b/config/locales/client.fa_IR.yml
index e525caa..e0a1019 100644
--- a/config/locales/client.fa_IR.yml
+++ b/config/locales/client.fa_IR.yml
@@ -3480,12 +3480,8 @@ fa_IR:
           embedded_scss:
             text: "کد CSS جاسازی شده"
             title: "کد CSS سفارشی مد نظرتان را اینجا وارد کنید"
-          head_tag:
-            text: "</‎head>"
-            title: "کد HTML که قبل از برچسب </head> اضافه می‌شود"
           body_tag:
-            text: "</‎body>"
GitHub sha: efc23b6a8deb86aa6caadfaecd95b32f1581c1e7
This commit appears in #14757 which was approved by gschlager. It was merged by gschlager.
