Update translations (#186)
diff --git a/config/locales/client.he.yml b/config/locales/client.he.yml
index a623fc1..2bcd5e1 100644
--- a/config/locales/client.he.yml
+++ b/config/locales/client.he.yml
@@ -79,5 +79,7 @@ he:
           fields:
             assignees_group:
               label: קבוצת מוקצים
+            minimum_time_between_assignments:
+              label: שעות בין הקצאות
             assigned_topic:
               label: מזהה נושא מוקצה
diff --git a/config/locales/client.pl_PL.yml b/config/locales/client.pl_PL.yml
index 0b9aaa2..1ce4e9c 100644
--- a/config/locales/client.pl_PL.yml
+++ b/config/locales/client.pl_PL.yml
@@ -59,3 +59,9 @@ pl_PL:
       web_hooks:
         assign_event:
           name: "Przypisz wydarzenie"
+    discourse_automation:
+      scriptables:
+        random_assign:
+          fields:
+              label: Godziny między przydziałami
diff --git a/config/locales/client.ru.yml b/config/locales/client.ru.yml
index b0860b2..7a30e9d 100644
--- a/config/locales/client.ru.yml
+++ b/config/locales/client.ru.yml
@@ -77,5 +77,9 @@ ru:
       scriptables:
         random_assign:
           fields:
+            assignees_group:
+              label: Группа назначенных
+              label: Минимальное количество часов между назначениями
             assigned_topic:
               label: ID назначенной темы
diff --git a/config/locales/client.sv.yml b/config/locales/client.sv.yml
index 5de5a8b..42fa16b 100644
--- a/config/locales/client.sv.yml
+++ b/config/locales/client.sv.yml
@@ -79,5 +79,7 @@ sv:
           fields:
             assignees_group:
               label: Tilldelade-grupp
+              label: Timmar mellan uppdrag
             assigned_topic:
               label: Tilldelat ämnes-ID
diff --git a/config/locales/client.zh_CN.yml b/config/locales/client.zh_CN.yml
index 5a965f6..760aa12 100644
--- a/config/locales/client.zh_CN.yml
+++ b/config/locales/client.zh_CN.yml
@@ -17,6 +17,8 @@ zh_CN:
       add_unassigned_filter: "将“未指派的”过滤器添加到分类"
       cant_act: "你不能操作已经指派给其他用户的标记"
       cant_act_unclaimed: "在对标记执行操作之前,你必须认领此主题。"
+      topic_search_placeholder: "按标题或帖子内容搜索主题"
+      sidebar_name_filter_placeholder: "姓名/用户名"
       assigned: "已指派"
       group_everyone: "所有人"
       assigned_to: "指派给"
@@ -52,8 +54,32 @@ zh_CN:
         assigned_title: "已指派%{count}"
         assigned: "已指派"
+      no_assignments_title: "您还没有任何任务"
+      no_assignments_body: >
+        您分配的主题和消息将在此处列出。您还将收到关于您的任务的定期提醒通知,您可以在 <a href='%{preferencesUrl}'>用户首选项</a>进行调整。 <br><br> 要将主题或消息分配给自己或其他人,请查找 %{icon} 分配按钮。
     admin:
       web_hooks:
         assign_event:
           details: "当用户被分配或取消分配一个主题时。"
+    search:
+      advanced:
+        in:
+          assigned: "已分配"
+          unassigned: "未指派的"
+        assigned:
+          label: "指派给"
+    topics:
+      bulk:
+        unassign: "取消指派主题"
+        assign: "指派主题"
+      scriptables:
+        random_assign:
+          fields:
+            assignees_group:
+              label: 指派给群组
+              label: 指派间隔时间
+            assigned_topic:
+              label: 指派主题
diff --git a/config/locales/server.he.yml b/config/locales/server.he.yml
index 7b32cb3..78c93ab 100644
--- a/config/locales/server.he.yml
+++ b/config/locales/server.he.yml
@@ -71,3 +71,4 @@ he:
     scriptables:
       random_assign:
         title: הקצאה אקראית
+        no_one: "היה ניסיון אקראי להקצות אחד מחברי הקבוצה @%{group}, אך אף אחד מהם לא היה זמין."
diff --git a/config/locales/server.pl_PL.yml b/config/locales/server.pl_PL.yml
index 97739de..a800d8b 100644
--- a/config/locales/server.pl_PL.yml
+++ b/config/locales/server.pl_PL.yml
@@ -69,3 +69,4 @@ pl_PL:
     scriptables:
       random_assign:
         title: Przypisanie losowe
+        no_one: "Próbowano losowo przypisać członka @%{group}, ale nikt nie był dostępny."
diff --git a/config/locales/server.ru.yml b/config/locales/server.ru.yml
index 32b9fa9..09f6157 100644
--- a/config/locales/server.ru.yml
+++ b/config/locales/server.ru.yml
@@ -13,7 +13,7 @@ ru:
     unassign_creates_tracking_post: "При снятии ответственного с темы создается скрытое сообщение, чтобы можно было отследить изменения в теме"
     assign_self_regex: "Шаблон, по которому тема будет автоматически закрепляться за текущим пользователем. Например, 'мой список'"
     assign_other_regex: "Шаблон, по которому назначение будет происходить автоматически на пользователя при его упоминании. Например, 'твой список'"
-    unassign_on_group_archive: "Когда сообщение архивируется группой, отменить назначение сообщения (переназначить, если оно возвращено обратно из архива)"
+    unassign_on_group_archive: "Отменить назначение сообщения, когда сообщение архивируется группой (переназначить, если оно возвращено обратно из архива)"
     unassign_on_close: "Снимать ответственного с темы при её закрытии"
     assign_mailer: "Когда отправлять уведомления по электронной почте для назначений"
     remind_assigns: "Напоминать пользователям об ожидающих назначениях."
diff --git a/config/locales/server.sv.yml b/config/locales/server.sv.yml
index 95abd52..7781288 100644
--- a/config/locales/server.sv.yml
+++ b/config/locales/server.sv.yml
@@ -72,3 +72,4 @@ sv:
     scriptables:
       random_assign:
         title: Tilldela slumpmässigt
+        no_one: "Försökte slumpmässigt tilldela en medlem av @%{group}, men ingen var tillgänglig."
diff --git a/config/locales/server.zh_CN.yml b/config/locales/server.zh_CN.yml
index decc1d5..312a897 100644
--- a/config/locales/server.zh_CN.yml
+++ b/config/locales/server.zh_CN.yml
@@ -19,12 +19,16 @@ zh_CN:
     remind_assigns: "提醒用户正在分配"
     remind_assigns_frequency: "指派主题的用户提醒频率"
     max_assigned_topics: "每个用户每天能分配的主题数量的最大值。"
+    assign_allowed_on_groups: "这些组中的用户被允许指派主题并且可以被分配到主题。"
   discourse_assign:
     assigned_to: "主题被指派给 @%{username}"
     unassigned: "主题未被指派"
     already_claimed: "这个主题已经被分配"
     already_assigned: "主题已被指派给 @%{username}"
     too_many_assigns: "@%{username}已经到达指派主题的最大值(%{max})。"
+    forbidden_assign_to: "@%{username} 不能分配,因为它们不属于被指派组。"
+    forbidden_assignee_not_pm_participant: "@%{username} 无法指派,因为他们无权访问此私信。您可以通过邀请 @%{username} 来使其加入。"
+    forbidden_assignee_cant_see_topic: "无法分配 @%{username} ,因为他们没有访问此主题的权限。"
     flag_assigned: "抱歉,这个标记的主题已被指派给其他用户"
     flag_unclaimed: "在对标记执行操作之前,你必须认领此主题。"
     topic_assigned_excerpt: "主题%{title}已分配给您"
@@ -63,3 +67,8 @@ zh_CN:
       %{topic_0}
       %{topic_1}
       %{topic_2}
+    scriptables:
+      random_assign:
+        title: 随机分配
+        no_one: "尝试随机分配 @%{group}的成员,但没有人可用。"
GitHub sha: 489dfafb32162a56f9c64d467f5693c314721362
This commit appears in #186 which was approved by gschlager. It was merged by gschlager.
