Update translations
Update translations
diff --git a/config/locales/client.bg.yml b/config/locales/client.bg.yml
index 99735bf..2186c8e 100644
--- a/config/locales/client.bg.yml
+++ b/config/locales/client.bg.yml
@@ -7,6 +7,12 @@
 bg:
   js:
+    notifications:
+      alt:
+        solved:
+          accepted_notification: "прието"
     solved:
+      accepted_answer: "Решение"
+      solution: "Решение"
       topic_status_filter:
         all: "всички подкатегории"
diff --git a/config/locales/client.es.yml b/config/locales/client.es.yml
index a1f12ec..75dc9ff 100644
--- a/config/locales/client.es.yml
+++ b/config/locales/client.es.yml
@@ -32,3 +32,12 @@ es:
     topic_statuses:
       solved:
         help: "Este tema tiene una solución"
+    search:
+      advanced:
+        statuses:
+          solved: "están resueltos"
+    admin:
+      web_hooks:
+        solved_event:
+          name: "Al resolver"
+          details: "Cuando un usuario marca o desmarca una publicación como la respuesta aceptada."
diff --git a/config/locales/client.he.yml b/config/locales/client.he.yml
index c0dbc46..da27e30 100644
--- a/config/locales/client.he.yml
+++ b/config/locales/client.he.yml
@@ -34,3 +34,12 @@ he:
     topic_statuses:
       solved:
         help: "נושא זה נפתר"
+    search:
+      advanced:
+        statuses:
+          solved: "נפתרו"
+    admin:
+      web_hooks:
+        solved_event:
+          name: "אירוע שנפתר"
+          details: "כאשר משתמש מסמן פוסט בתור התשובה המקובלת או הבלתי מקובלת."
diff --git a/config/locales/client.it.yml b/config/locales/client.it.yml
index e2632c9..458240e 100644
--- a/config/locales/client.it.yml
+++ b/config/locales/client.it.yml
@@ -15,7 +15,7 @@ it:
       title: "Risolto"
       allow_accepted_answers: "Consentire al proprietario dell'argomento e allo staff di contrassegnare una risposta come la soluzione"
       accept_answer: "Questa risposta risolve il problema"
-      accepted_description: "Questa è la soluzione accettata di questo argomento"
+      accepted_description: "Questa è la soluzione accettata per questo argomento"
       has_no_accepted_answer: "Questo argomento non ha soluzioni"
       unaccept_answer: "Deseleziona se questa risposta non risolve più il problema"
       accepted_answer: "Soluzione"
@@ -32,3 +32,12 @@ it:
     topic_statuses:
       solved:
         help: "Questo argomento ha una soluzione"
+    search:
+      advanced:
+        statuses:
+          solved: "sono risolti"
+    admin:
+      web_hooks:
+        solved_event:
+          name: "Evento Solved"
+          details: "Quando un utente contrassegna un messaggio come risposta accettata o non accettata."
diff --git a/config/locales/client.ko.yml b/config/locales/client.ko.yml
index 1c1f49a..668bbb1 100644
--- a/config/locales/client.ko.yml
+++ b/config/locales/client.ko.yml
@@ -15,11 +15,14 @@ ko:
       title: "해결됨"
       allow_accepted_answers: "토픽 소유자 및 스태프가 해결책으로 답글을 표시하도록 허용"
       accept_answer: "이 답변이 문제를 해결할 경우 선택하십시오"
+      accepted_description: "이것이이 주제에 대한 해결책입니다."
       has_no_accepted_answer: "이 토픽에는 해결책이 없습니다"
+      unaccept_answer: "이 답변으로 더 이상 문제가 해결되지 않으면 선택 취소"
       accepted_answer: "해결책"
       solution: "해결책"
       solution_summary:
         other: "해결책"
+      accepted_notification: "<p> <span>{{username}}</span> {{description}} </p>"
         all: "모두"
         solved: "해결됨"
@@ -27,3 +30,12 @@ ko:
     topic_statuses:
       solved:
         help: "이 토픽에는 해결책이 있습니다"
+    search:
+      advanced:
+        statuses:
+          solved: "해결되다"
+    admin:
+      web_hooks:
+        solved_event:
+          name: "해결 된 이벤트"
+          details: "사용자가 게시물을 수락 또는 수락되지 않은 답변으로 표시 한 경우"
diff --git a/config/locales/client.nl.yml b/config/locales/client.nl.yml
index f5936d2..a350fe0 100644
--- a/config/locales/client.nl.yml
+++ b/config/locales/client.nl.yml
@@ -32,3 +32,12 @@ nl:
     topic_statuses:
       solved:
         help: "Dit topic heeft een oplossing"
+    search:
+      advanced:
+        statuses:
+          solved: "zijn opgelost"
+    admin:
+      web_hooks:
+        solved_event:
+          name: "Opgelost-gebeurtenis"
+          details: "Wanneer een gebruiker een bericht als het geaccepteerde of niet-geaccepteerde antwoord markeert."
diff --git a/config/locales/client.ru.yml b/config/locales/client.ru.yml
index df83b2e..cdf4723 100644
--- a/config/locales/client.ru.yml
+++ b/config/locales/client.ru.yml
@@ -34,3 +34,7 @@ ru:
     topic_statuses:
       solved:
         help: "Тема содержит решение вопроса"
+    search:
+      advanced:
+        statuses:
+          solved: "Решённые"
diff --git a/config/locales/client.sv.yml b/config/locales/client.sv.yml
index 0337aa3..e0f1cfc 100644
--- a/config/locales/client.sv.yml
+++ b/config/locales/client.sv.yml
@@ -32,3 +32,12 @@ sv:
     topic_statuses:
       solved:
         help: "Detta ämne har en lösning"
+    search:
+      advanced:
+        statuses:
+          solved: "är lösta"
+    admin:
+      web_hooks:
+        solved_event:
+          name: "Löst händelse"
+          details: "När en användare markerar ett svarsinlägg som accepterat eller icke accepterat. "
diff --git a/config/locales/client.zh_CN.yml b/config/locales/client.zh_CN.yml
index 23f6abe..c3044fd 100644
--- a/config/locales/client.zh_CN.yml
+++ b/config/locales/client.zh_CN.yml
@@ -31,3 +31,12 @@ zh_CN:
     topic_statuses:
       solved:
         help: "这个主题已经有了解决方案"
+    search:
+      advanced:
+        statuses:
+          solved: "已解决"
+    admin:
+      web_hooks:
+        solved_event:
+          name: "已解决事件"
+          details: "当用户将帖子标记为接受或不被接受的答案时。"
diff --git a/config/locales/server.bs_BA.yml b/config/locales/server.bs_BA.yml
index 3ce1c26..0e62ccd 100644
--- a/config/locales/server.bs_BA.yml
+++ b/config/locales/server.bs_BA.yml
@@ -9,3 +9,4 @@ bs_BA:
   reports:
     accepted_solutions:
       xaxis: "Day"
+      yaxis: "Suma"
diff --git a/config/locales/server.it.yml b/config/locales/server.it.yml
index 01974a3..6e1c04d 100644
--- a/config/locales/server.it.yml
+++ b/config/locales/server.it.yml
@@ -13,7 +13,7 @@ it:
     empty_box_on_unsolved: "Mostra una casella vuota accanto agli argomenti non risolti"
     solved_quote_length: "Numero di caratteri da citare quando si visualizza la soluzione sotto il primo messaggio"
     solved_topics_auto_close_hours: "Chiudi automaticamente l'argomento (n) ore dopo l'ultima risposta una volta che l'argomento è stato contrassegnato come risolto"
-    show_filter_by_solved_status: "Mostra una lista a discesa per filtrare una lista di argomenti per stato"
+    show_filter_by_solved_status: "Mostra un menu a discesa per filtrare un elenco di argomenti in base allo stato risolto."
   reports:
     accepted_solutions:
       title: "Soluzioni accettate"
@@ -23,3 +23,10 @@ it:
     no_solutions:
       self: "Non hai ancora soluzioni accettate."
       others: "Nessuna soluzione accettata."
+  badges:
+    helpdesk:
+      name: "Helpdesk"
+      description: "Prima Risposta Accettata su un Argomento"
+    tech_support:
+      name: "Supporto Tecnico"
+      description: "10 Risposte accettate"
diff --git a/config/locales/server.ko.yml b/config/locales/server.ko.yml
index b67931a..26d7a7d 100644
--- a/config/locales/server.ko.yml
+++ b/config/locales/server.ko.yml
@@ -6,7 +6,27 @@
 # https://www.transifex.com/projects/p/discourse-org/
 ko:
+  site_settings:
+    solved_enabled: "해결 된 플러그인 사용, 사용자가 주제에 대한 솔루션을 선택할 수 있도록 허용"
+    allow_solved_on_all_topics: "사용자가 모든 주제에 대한 솔루션을 선택할 수 있도록 허용 (기본적으로 카테고리를 편집하여 제어)"
+    accept_all_solutions_trust_level: "모든 주제에 대한 솔루션을 수락하는 데 필요한 최소 신뢰 수준 (OP가 아닌 경우에도)"
+    empty_box_on_unsolved: "해결되지 않은 주제 옆에 빈 상자 표시"
+    solved_quote_length: "첫 번째 게시물 아래에 솔루션을 표시 할 때 인용 할 문자 수"
+    solved_topics_auto_close_hours: "주제가 해결 된 것으로 표시되면 마지막 회신 후 주제 자동 닫기 (n)"
+    show_filter_by_solved_status: "해결 된 상태별로 주제 목록을 필터링하는 드롭 다운을 표시하십시오."
   reports:
     accepted_solutions:
+      title: "허용되는 솔루션"
GitHub sha: af53c1d5
