Update translations
Update translations
diff --git a/.tx/config b/.tx/config
index fe96f3b..95e5fad 100644
--- a/.tx/config
+++ b/.tx/config
@@ -13,3 +13,4 @@ file_filter = config/locales/server.<lang>.yml
 source_file = config/locales/server.en.yml
 source_lang = en
 type = YML
diff --git a/config/locales/client.ar.yml b/config/locales/client.ar.yml
new file mode 100644
index 0000000..d1dc657
--- /dev/null
+++ b/config/locales/client.ar.yml
@@ -0,0 +1,12 @@
+# encoding: utf-8
+# Never edit this file. It will be overwritten when translations are pulled from Transifex.
+# To work with us on translations, join this project:
+# https://www.transifex.com/projects/p/discourse-org/
+ar:
+  js:
+    encrypt:
+      manage_paper_keys:
+        delete: "أحذف"
diff --git a/config/locales/client.be.yml b/config/locales/client.be.yml
index 0000000..4c5b271
--- /dev/null
+++ b/config/locales/client.be.yml
@@ -0,0 +1,12 @@
+# encoding: utf-8
+be:
+  js:
+    encrypt:
+        delete: "выдаліць"
diff --git a/config/locales/client.bg.yml b/config/locales/client.bg.yml
index 0000000..32ab4c0
--- /dev/null
+++ b/config/locales/client.bg.yml
@@ -0,0 +1,12 @@
+# encoding: utf-8
+bg:
+  js:
+    encrypt:
+        delete: "Изтрий"
diff --git a/config/locales/client.bs_BA.yml b/config/locales/client.bs_BA.yml
index 0000000..caa9637
--- /dev/null
+++ b/config/locales/client.bs_BA.yml
@@ -0,0 +1,12 @@
+# encoding: utf-8
+bs_BA:
+  js:
+    encrypt:
+        delete: "Izbriši"
diff --git a/config/locales/client.ca.yml b/config/locales/client.ca.yml
index 0000000..54cc8db
--- /dev/null
+++ b/config/locales/client.ca.yml
@@ -0,0 +1,12 @@
+# encoding: utf-8
+ca:
+  js:
+    encrypt:
+        delete: "Suprimeix"
diff --git a/config/locales/client.cs.yml b/config/locales/client.cs.yml
index 0000000..9e543a0
--- /dev/null
+++ b/config/locales/client.cs.yml
@@ -0,0 +1,12 @@
+# encoding: utf-8
+cs:
+  js:
+    encrypt:
+        delete: "Smazat"
diff --git a/config/locales/client.da.yml b/config/locales/client.da.yml
index 0000000..ddc458c
--- /dev/null
+++ b/config/locales/client.da.yml
@@ -0,0 +1,12 @@
+# encoding: utf-8
+da:
+  js:
+    encrypt:
+        delete: "Slet"
diff --git a/config/locales/client.de.yml b/config/locales/client.de.yml
index 0000000..3826559
--- /dev/null
+++ b/config/locales/client.de.yml
@@ -0,0 +1,74 @@
+# encoding: utf-8
+de:
+  js:
+    encrypt:
+      title: "Verschlüsselte Nachrichten"
+      decrypting: "Entschlüssele..."
+      decryption_failed: "Diese Nachricht kann nicht entschlüsselt werden."
+      no_backup_warn: "Verschlüsselung ist aktiviert, aber keine Papierschlüssel wurde generiert. Ohne Papierschlüssel besteht die Gefahr, dass der Zugriff auf verschlüsselte Nachrichten verloren geht. Um einen Papierschlüssel zu generieren, navigiere zur <a href='%{basePath}/my/preferences/account'> Benutzereinstellungen Seite</a> und drücke die Schaltfläche <kbd>Papierschlüssel generieren</kbd> und befolge die Anweisungen."
+      integrity_check_pass: "Die Integritätsprüfung für diesen Beitrag war gültig."
+      integrity_check_fail: "Die Integritätsprüfung für diesen Beitrag ist fehlgeschlagen (%{fields} stimmt nicht überein)."
+      integrity_check_warn_updated_at: "Die Metadaten des Beitrags wurde aktualisiert ohne erneut signiert zu werden. "
+      integrity_check_warn_signed_by: "Dieser Beitrag wurde signiert von %{actual} und nicht von %{expected}."
+      encrypted_topic_title: "Eine sichere Nachricht."
+      encrypted_post: "Dies ist eine geheime Nachricht mit Ende-zu-Ende-Verschlüsselung. Um sie anzuzeigen, musst du zu diesem Thema eingeladen sein."
+      encrypted_post_email: "Dies ist eine geheime Nachricht mit Ende-zu-Ende-Verschlüsselung. Du musst dieses Thema besuchen, um sie anzuzeigen."
+      encrypted_icon_title: "Diese Nachricht ist Ende-zu-Ende verschlüsselt."
+      encrypted_uploads: "Uploads können aktuell nicht verschlüsselt werden. "
+      cannot_encrypt: "Du kannst keine Nachrichten in dieser Unterhaltung verschlüsseln. "
+      cannot_invite: "Du kannst keinen einladen zu dieser Unterhaltung."
+      cannot_invite_group: "Du kannst keine Gruppen zu verschlüsselte Nachrichten einladen."
+      checkbox:
+        checked: "Diese Nachricht wird Ende-zu-Ende verschlüsselt."
+        unchecked: "Kicke das Schloss Symbol zum Verschlüsseln dieser Nachricht."
+        disabled: "Eine Empfänger hat Verschlüsselung nicht aktiviert."
+      composer:
+        encrypt: "Nachricht verschlüsseln?"
+        group_not_allowed: "Du bist nicht berechtigt Nachrichten an Gruppen zu schicken. "
+        user_has_no_key: "Leider hat %{username} keine verschlüsselten Nachrichten aktiviert."
+      preferences:
+        ie11: "Die erforderliche Verschlüsselungssuite ist in Internet Explorer 11 nicht verfügbar."
+        insecure_context: "Die Verschlüsselung kann nicht in einem unsicheren Kontext verwendet werden (nicht HTTPS)."
+        status_enabled: "Du hast die Verschlüsselung aktiviert und auf diesem Gerät aktiviert."
+        status_enabled_other: "Dieser Benutzer hat die Verschlüsselung aktiviert und kann verschlüsselte Nachrichten empfangen."
+        status_enabled_but_inactive: "Verschlüsselung ist angeschaltet, jedoch nicht für dieses Gerät aktiviert."
+        status_disabled: "Verschlüsselung ist für dieses Konto nicht aktiviert."
+        status_disabled_other: "Dieser Benutzer hat die Verschlüsselung nicht aktiviert und kann keine verschlüsselten Nachrichten empfangen."
+        passphrase_label: "Passphrase:"
+        passphrase_invalid: "Die eingegebene Passphrase ist falsch."
+        import_key: "Ich habe bereits einen Verschlüsselungsschlüssel."
+        notice_active: |
+          <p> Bitte verwende ein anderes Gerät oder einen Papierschlüssel, um dieses Gerät zu aktivieren. Vergieß nicht die Zwischenräume zwischen den Wörtern. <p>
+        notice_import: |
+          <p> Bitte füge den zuvor exportierten Verschlüsselungsschlüssel ein. </p>
+        activate: "Aktiviere verschlüsselte Nachrichten"
+        deactivate: "Deaktiviere die Verschlüsselung auf diesem Gerät"
+        enable: "Aktiviere verschlüsselte Nachrichten"
+        import: "Importiere das Verschlüsselungsschlüsselpaar"
GitHub sha: 5745ee55
