Update translations
Update translations
diff --git a/config/locales/client.ar.yml b/config/locales/client.ar.yml
index 3e9b7d1..72083bc 100644
--- a/config/locales/client.ar.yml
+++ b/config/locales/client.ar.yml
@@ -2045,7 +2045,6 @@ ar:
           last: "آخر مراجعة"
           hide: "أخفِ المراجعة"
           show: "أظهر المراجعة"
-          revert: "ارجع إلى هذه المراجعة"
           edit_wiki: "عدل الwiki"
           edit_post: "عدل المنشور"
         displays:
diff --git a/config/locales/client.be.yml b/config/locales/client.be.yml
index 22754d8..0ce957b 100644
--- a/config/locales/client.be.yml
+++ b/config/locales/client.be.yml
@@ -1028,6 +1028,8 @@ be:
         error: "Пры пераносе паведамленняў да гэтай тэмы адбылася памылка."
       move_to_new_message:
         radio_label: "новае паведамленне"
+      publish_page:
+        public: "грамадскага"
       change_timestamp:
         title: "Змяніць метку часу"
         action: "змяніць метку часу"
@@ -1063,7 +1065,6 @@ be:
           last: "Апошняя рэвізія"
           hide: " Схаваць рэвізію"
           show: "Паказаць рэвізію"
-          revert: "Адкат да гэтай рэвізіі"
         displays:
           inline:
             title: "Адлюстраваць паведамленне з улучанымі дадаткамі і выдаленнямі."
diff --git a/config/locales/client.bg.yml b/config/locales/client.bg.yml
index 2cf0f0c..22b381d 100644
--- a/config/locales/client.bg.yml
+++ b/config/locales/client.bg.yml
@@ -1660,6 +1660,7 @@ bg:
         radio_label: "Ново Съобщение"
       publish_page:
         title: "Публикуване на страници"
+        public: "Публични"
       change_owner:
         action: "смени собственика"
         error: "Възникна грешка при смяната на собственика"
@@ -1801,7 +1802,6 @@ bg:
           last: "Последна ревизия"
           hide: "Скрий ревизията"
           show: "Покажи ревизията"
-          revert: "Връщане към тази редакция"
           edit_wiki: "Редактиране на Wiki"
           edit_post: "Редактиране на публикацията"
         displays:
diff --git a/config/locales/client.bs_BA.yml b/config/locales/client.bs_BA.yml
index e4e1f7c..0eda001 100644
--- a/config/locales/client.bs_BA.yml
+++ b/config/locales/client.bs_BA.yml
@@ -779,7 +779,6 @@ bs_BA:
           all: "Sve"
           read: "Učitaj"
           unread: "Nepročitanih"
-        ignore_duration_title: "Zanemari tajmer"
         ignore_duration_username: "Ime"
         ignore_duration_when: "Trajanje:"
         ignore_duration_save: "Zanemari"
@@ -1022,7 +1021,8 @@ bs_BA:
         secondary: "Sekundari Emailovi"
         primary_label: "primary"
         update_email: "Promijeni Email"
-        ssDestroy_override_instructions: "E-pošta se može ažurirati od SSO provajdera."
+        sso_override_instructions: "E-pošta se može ažurirati od SSO provajdera."
+        no_secondary: "Nema sekundarnih emailova"
         instructions: "Nikada nije prikazan javnosti."
         ok: "Izgleda dobro. Poslat ćemo email sa potvrdom."
         invalid: "Molimo vas da unesete validnu email adresu."
@@ -2230,6 +2230,8 @@ bs_BA:
         title: "Spoji izabrane postove"
         action: "spoji izabrane postove"
         error: "Desila se greška prilikom spajanja označenih objava."
+      publish_page:
+        public: "Javno"
       change_owner:
         title: "Change Owner"
         action: "change ownership"
@@ -2432,7 +2434,6 @@ bs_BA:
           last: "Last revision"
           hide: "Hide revision"
           show: "Show revision"
-          revert: "Vratite se na ovu reviziju"
           edit_wiki: "Promjni Wiki"
           edit_post: "Promjeni Post"
           comparing_previous_to_current_out_of_total: "<strong>%{previous}</strong> %{icon} <strong>%{current}</strong> / %{total}"
diff --git a/config/locales/client.ca.yml b/config/locales/client.ca.yml
index 768da7d..a998e63 100644
--- a/config/locales/client.ca.yml
+++ b/config/locales/client.ca.yml
@@ -734,7 +734,6 @@ ca:
           all: "Tot"
           read: "Llegit"
           unread: "No llegits"
-        ignore_duration_title: "Ignora el temporitzador"
         ignore_duration_username: "Nom d'usuari "
         ignore_duration_when: "Duració:"
         ignore_duration_save: "Ignora"
@@ -973,7 +972,8 @@ ca:
         secondary: "Adreces de correu secundàries"
         primary_label: "primari"
         update_email: "Canvi de correu"
-        ssDestroy_override_instructions: "L'adreça de correu es pot actualitzar des d'un proveïdor SSO"
+        sso_override_instructions: "L'adreça de correu es pot actualitzar des d'un proveïdor SSO"
+        no_secondary: "Sense adreces de correu secundàries"
         instructions: "No es mostra mai en públic."
         ok: "Us enviarem un correu electrònic de confirmació"
         invalid: "Introduïu una adreça vàlida de correu electrònic"
@@ -2164,6 +2164,8 @@ ca:
         title: "Combina les publicacions seleccionades"
         action: "combina les publicacions seleccionades"
         error: "Hi ha hagut un error en unir les publicacions seleccionades."
+      publish_page:
+        public: "Públic"
       change_owner:
         title: "Canvia el propietari"
         action: "canvia la propietat"
@@ -2358,7 +2360,6 @@ ca:
           last: "Darrera revisió"
           hide: "Amaga la revisió"
           show: "Mostra la revisió"
-          revert: "Reverteix a aquesta revisió"
           edit_wiki: "Edita Wiki"
           edit_post: "Edita publicació"
diff --git a/config/locales/client.cs.yml b/config/locales/client.cs.yml
index 0f47ac3..91283d1 100644
--- a/config/locales/client.cs.yml
+++ b/config/locales/client.cs.yml
@@ -824,6 +824,7 @@ cs:
         secondary: "Záložní emailové adresy"
         primary_label: "primární"
         update_email: "Změnit emailovou adresu"
+        no_secondary: "Žádné záložní emailové adresy"
         instructions: "Nikdy nebude zveřejněno."
         ok: "Pro potvrzení vám pošleme email."
         invalid: "Zadejte prosím správnou emailovou adresu"
@@ -1946,6 +1947,8 @@ cs:
         title: "Sluč vybrané příspěvky"
         action: "sluč vybrané příspěvky"
         error: "Během slučování vybraných příspěvků došlo k chybě."
+      publish_page:
+        public: "Veřejné"
       change_owner:
         title: "Změnit vlastníka"
         action: "změnit autora"
@@ -2145,7 +2148,6 @@ cs:
           last: "Poslední revize"
           hide: "Schovejte revizi"
           show: "Zobrazte revizi"
-          revert: "Vrátit se k této revizi"
           edit_wiki: "Upravit Wiki"
           edit_post: "upravit příspěvek"
         displays:
diff --git a/config/locales/client.da.yml b/config/locales/client.da.yml
index 2aacfa5..1adeb84 100644
--- a/config/locales/client.da.yml
+++ b/config/locales/client.da.yml
@@ -730,7 +730,6 @@ da:
           all: "Alle"
           read: "Læste"
           unread: "Ulæst"
-        ignore_duration_title: "Ignorér timer"
         ignore_duration_username: "Brugernavn"
         ignore_duration_when: "Varighed:"
         ignore_duration_save: "Ignorér"
@@ -960,7 +959,8 @@ da:
         secondary: "Sekundære emails"
         primary_label: "Primær"
         update_email: "Skift e-mail-adresse"
-        ssDestroy_override_instructions: "Email kan opdateres fra SSO-udbyderen."
+        sso_override_instructions: "Email kan opdateres fra SSO-udbyderen."
+        no_secondary: "Ingen sekundære emails"
         instructions: "Vis aldrig offentligt"
         ok: "Vi vil sende dig en bekræftelses email"
         invalid: "Indtast venligst en gyldig email adresse"
@@ -2124,6 +2124,8 @@ da:
         title: "Flet valgte indlæg"
         action: "flet valgte indlæg"
         error: "Der opstod en fejl med at flette de valgte indlæg."
+      publish_page:
+        public: "Offentlig"
       change_owner:
         title: "Skift ejer"
         action: "skift ejerskab"
@@ -2313,7 +2315,6 @@ da:
           last: "Sidste udgave"
GitHub sha: 390dc5c7
