Update translations
Update translations
diff --git a/config/locales/client.ca.yml b/config/locales/client.ca.yml
index f480440..dd54456 100644
--- a/config/locales/client.ca.yml
+++ b/config/locales/client.ca.yml
@@ -41,7 +41,7 @@ ca:
       download_json: "JSON"
       download_csv: "CSV"
       others_dirty: "Una consulta té canvis no desats que es perdran si continueu navegant."
-      run_time: "Consulta completada en {{value}} ms."
+      run_time: "La consulta s'ha completat en %{value} ms."
       result_count:
         one: "%{count} resultat."
         other: "%{count} resultats."
@@ -55,7 +55,7 @@ ca:
       query_description: "Descripció"
       query_time: "Darrera execució"
       query_user: "Creat per"
-      column: "Columna {{number}}"
+      column: "Columna %{number}"
       explain_label: "Hi incloem pla de consulta?"
       save_params: "Estableix valors per defecte"
       reset_params: "Reinicia"
diff --git a/config/locales/client.cs.yml b/config/locales/client.cs.yml
index 5a6d85d..1727a0e 100644
--- a/config/locales/client.cs.yml
+++ b/config/locales/client.cs.yml
@@ -26,6 +26,5 @@ cs:
       download_csv: "CSV"
       query_groups: "Skupiny"
       query_description: "Popis"
-      column: "Sloupec {{number}}"
       reset_params: "obnovit výchozí"
       search_placeholder: "Hledat..."
diff --git a/config/locales/client.de.yml b/config/locales/client.de.yml
index 7b17234..5e6475f 100644
--- a/config/locales/client.de.yml
+++ b/config/locales/client.de.yml
@@ -42,7 +42,6 @@ de:
       download_csv: "CSV"
       others_dirty: "Eine Anfrage hat ungespeicherte Änderungen, die verloren gehen, wenn du woanders hingehst."
-      run_time: "Anfrage abgeschlossen in {{value}} ms."
       result_count:
         one: "%{count} Ergebnis."
         other: "%{count} Ergebnisse."
@@ -56,7 +55,6 @@ de:
       query_description: "Beschreibung"
       query_time: "Letzter Lauf"
       query_user: "Erstellt von"
-      column: "Spalte {{number}}"
       explain_label: "Anfrageplan beinhalten?"
       save_params: "Standard festlegen"
       reset_params: "Zurücksetzen"
diff --git a/config/locales/client.es.yml b/config/locales/client.es.yml
index 098651e..cd7abd4 100644
--- a/config/locales/client.es.yml
+++ b/config/locales/client.es.yml
@@ -42,7 +42,6 @@ es:
       download_csv: "CSV"
       others_dirty: "Una consulta tiene cambios no guardados que se perderán si sales."
       result_count:
         one: "%{count} resultado."
         other: "%{count} resultados."
@@ -56,7 +55,6 @@ es:
       query_description: "Descripción"
       query_time: "Última ejecución"
       query_user: "Creada por"
       explain_label: "¿Incluir plan de consulta?"
       save_params: "Establecer configuración por defecto"
       reset_params: "Resetear"
diff --git a/config/locales/client.et.yml b/config/locales/client.et.yml
index 8fd8645..8672f1e 100644
--- a/config/locales/client.et.yml
+++ b/config/locales/client.et.yml
@@ -33,7 +33,6 @@ et:
       download_csv: "CSV"
       query_groups: "Grupid"
       query_description: "Kirjeldus"
-      column: "Veerg {{number}}"
       save_params: "Määra vaikeväärtused"
       reset_params: "Nulli"
       search_placeholder: "Otsi..."
diff --git a/config/locales/client.fi.yml b/config/locales/client.fi.yml
index 04c3b56..1ab2cd0 100644
--- a/config/locales/client.fi.yml
+++ b/config/locales/client.fi.yml
@@ -41,7 +41,6 @@ fi:
       download_csv: "CSV"
       others_dirty: "Kyselyyn tehdyt tallentamattomat muutokset menetetään, jos navigoit pois. "
-      run_time: "Kysely suoritettiin ajassa {{value}} ms."
       result_count:
         one: "%{count} tulos. "
         other: "%{count} tulokset. "
@@ -53,7 +52,6 @@ fi:
       query_description: "Kuvaus"
       query_time: "Viimeksi suoritettu"
       query_user: "Luonut"
-      column: "Sarake {{number}}"
       explain_label: "Sisällytä kyselysuunnitelma?"
       save_params: "Aseta oletusarvot"
       reset_params: "Nollaa"
diff --git a/config/locales/client.fr.yml b/config/locales/client.fr.yml
index 2fe40fe..f7b7701 100644
--- a/config/locales/client.fr.yml
+++ b/config/locales/client.fr.yml
@@ -12,7 +12,7 @@ fr:
         no_semicolons: "Enlever les points-virgules de la requête."
         dirty: "Vous devez sauvegarder la requête avant de l'exécuter."
     explorer:
-      admins_only: "L'explorateur de données n'est disponible qu'aux administrateurs"
+      admins_only: "L'explorateur de données n'est disponible qu'aux administrateurs."
       allow_groups: "Autoriser les groupes à accéder à cette requête"
       title: "Explorateur de données"
       create: "Créer un nouveau"
@@ -42,12 +42,12 @@ fr:
       download_csv: "CSV"
       others_dirty: "La requête a des modifications non sauvegardées qui seront perdues si vous poursuivez la navigation."
-      run_time: "Requête exécutée en {{count}} secondes."
+      run_time: "Requête exécutée en %{value} millisecondes."
       result_count:
         one: "%{count} résultat."
         other: "%{count} résultats."
       max_result_count:
-        one: "Affichage des %{count} premièrs résultats."
+        one: "Affichage du %{count} premier résultat."
         other: "Affichage des %{count} premiers résultats."
       query_name: "Requête"
       query_groups: "Groupes"
@@ -56,7 +56,7 @@ fr:
       query_description: "Description"
       query_time: "Dernière exécution"
       query_user: "Créée par"
-      column: "Colonne {{number}}"
+      column: "Colonne %{number}"
       explain_label: "Inclure le plan d'exécution ?"
       save_params: "Définir les valeurs par défaut"
       reset_params: "Réinitialiser"
diff --git a/config/locales/client.gl.yml b/config/locales/client.gl.yml
index c1a0bc6..35ed09c 100644
--- a/config/locales/client.gl.yml
+++ b/config/locales/client.gl.yml
@@ -10,6 +10,8 @@ gl:
     explorer:
       import:
         label: "Importar"
+      schema:
+        filter: "Buscar..."
       types:
         bool:
           'yes': "Si"
@@ -20,3 +22,6 @@ gl:
       delete: "Eliminar"
       query_groups: "Grupos"
       query_description: "Descrición"
+      search_placeholder: "Buscar..."
+    group:
+      reports: "Informes"
diff --git a/config/locales/client.he.yml b/config/locales/client.he.yml
index 7f0f16b..4aa9afb 100644
--- a/config/locales/client.he.yml
+++ b/config/locales/client.he.yml
@@ -42,7 +42,7 @@ he:
       download_csv: "CSV"
       others_dirty: "בשאילתה נערכו שינויים שטרם נשמרו ועשויים ללכת לאיבוד בעת ניווט למקום אחר."
-      run_time: "השאילתה הושלמה תוך {{value}} מילישניות."
+      run_time: "השאילתה הושלמה תוך %{value} מילישניות"
       result_count:
         one: "תוצאה אחת."
         two: "2 תוצאות."
@@ -60,7 +60,7 @@ he:
       query_description: "תיאור"
       query_time: "הרצה אחרונה"
       query_user: "נוצר על ידי"
-      column: "עמודה {{number}}"
+      column: "עמודה %{number}"
       explain_label: "לכלול תכנית שאילתה?"
       save_params: "הגדרת בררות מחדל"
       reset_params: "איפוס"
diff --git a/config/locales/client.hu.yml b/config/locales/client.hu.yml
index a82eccb..be26f22 100644
--- a/config/locales/client.hu.yml
+++ b/config/locales/client.hu.yml
@@ -33,6 +33,5 @@ hu:
       download_csv: "CSV"
       query_groups: "Csoportok"
       query_description: "Leírás"
-      column: "Oszlop {{number}}"
       reset_params: "Alaphelyzet"
       search_placeholder: "Keresés..."
diff --git a/config/locales/client.hy.yml b/config/locales/client.hy.yml
index ea29ffd..d5f95bd 100644
--- a/config/locales/client.hy.yml
+++ b/config/locales/client.hy.yml
@@ -41,7 +41,6 @@ hy:
       download_csv: "CSV"
       others_dirty: "Հարցումն ունի չպահպանված փոփոխություններ, որոնք կկորչեն, եթե Դուք տեղափոխվեք:"
GitHub sha: fc041d8b
