Update translations
Update translations
diff --git a/config/locales/client.ar.yml b/config/locales/client.ar.yml
index baeee73..7ca8eec 100644
--- a/config/locales/client.ar.yml
+++ b/config/locales/client.ar.yml
@@ -1,13 +1,13 @@
-# encoding: utf-8
-# Never edit this file. It will be overwritten when translations are pulled from Transifex.
+# WARNING: Never edit this file.
+# It will be overwritten when translations are pulled from Crowdin.
 # To work with us on translations, join this project:
-# https://www.transifex.com/projects/p/discourse-org/
+# https://translate.discourse.org/
 ar:
   js:
     discourse_assign:
+      group_everyone: "الكل"
       assign_mailer:
         never: "أبدا"
         always: "دوما"
diff --git a/config/locales/client.be.yml b/config/locales/client.be.yml
index 728b466..4356d07 100644
--- a/config/locales/client.be.yml
+++ b/config/locales/client.be.yml
@@ -1,14 +1,14 @@
-# encoding: utf-8
 be:
   js:
     discourse_assign:
       assigned: "прызначаны"
+      group_everyone: "усе"
       assign_mailer:
         never: "ніколі"
         always: "заўсёды"
diff --git a/config/locales/client.bg.yml b/config/locales/client.bg.yml
index 6800332..01e85ec 100644
--- a/config/locales/client.bg.yml
+++ b/config/locales/client.bg.yml
@@ -1,13 +1,13 @@
-# encoding: utf-8
 bg:
   js:
     discourse_assign:
+      group_everyone: "Всички"
       assign_mailer:
         never: "Никога"
         always: "Винаги"
diff --git a/config/locales/client.bs_BA.yml b/config/locales/client.bs_BA.yml
index 248b721..b05be11 100644
--- a/config/locales/client.bs_BA.yml
+++ b/config/locales/client.bs_BA.yml
@@ -1,13 +1,13 @@
-# encoding: utf-8
 bs_BA:
   js:
     discourse_assign:
+      group_everyone: "Svatko"
       assign_mailer:
         never: "Nikad"
         always: "Uvijek"
diff --git a/config/locales/client.ca.yml b/config/locales/client.ca.yml
index 9284f89..66f264d 100644
--- a/config/locales/client.ca.yml
+++ b/config/locales/client.ca.yml
@@ -1,9 +1,8 @@
-# encoding: utf-8
 ca:
   js:
@@ -18,6 +17,7 @@ ca:
       cant_act: "No podeu actuar sobre banderes assignades a altres usuaris."
       cant_act_unclaimed: "Cal reclamar el tema abans d'actuar sobre les banderes"
       assigned: "Assignat"
+      group_everyone: "Tothom"
       assigned_to: "Assignat a"
       assign_notification: "<p><span>%{username}</span> %{description}</p>"
       unassign:
diff --git a/config/locales/client.cs.yml b/config/locales/client.cs.yml
index fb0aebd..03d587a 100644
--- a/config/locales/client.cs.yml
+++ b/config/locales/client.cs.yml
@@ -1,9 +1,8 @@
-# encoding: utf-8
 cs:
   js:
@@ -12,6 +11,7 @@ cs:
       unassigned: "zadání odebráno %{when}"
     discourse_assign:
       assigned: "Zadáno"
+      group_everyone: "Všichni"
       unassign:
         title: "Odebrat zadání"
       assign:
diff --git a/config/locales/client.da.yml b/config/locales/client.da.yml
index 074a549..949ca49 100644
--- a/config/locales/client.da.yml
+++ b/config/locales/client.da.yml
@@ -1,13 +1,13 @@
-# encoding: utf-8
 da:
   js:
     discourse_assign:
+      group_everyone: "Alle"
       assign_mailer:
         never: "Aldrig"
         always: "Altid"
diff --git a/config/locales/client.de.yml b/config/locales/client.de.yml
index b21915e..9401284 100644
--- a/config/locales/client.de.yml
+++ b/config/locales/client.de.yml
@@ -1,9 +1,8 @@
-# encoding: utf-8
 de:
   js:
@@ -14,6 +13,7 @@ de:
       cant_act: "Du kannst nicht auf Meldungen reagieren, die anderen Benutzern zugewiesen wurden."
       cant_act_unclaimed: "Du musst das Thema übernehmen, bevor du Meldungen behandeln kannst."
       assigned: "Zugeordnet"
+      group_everyone: "Jeder"
       assigned_to: "Zugewiesen an"
       unassign:
         title: "Zuordnung aufheben"
diff --git a/config/locales/client.el.yml b/config/locales/client.el.yml
index f7ea612..88ff99a 100644
--- a/config/locales/client.el.yml
+++ b/config/locales/client.el.yml
@@ -1,13 +1,13 @@
-# encoding: utf-8
 el:
   js:
     discourse_assign:
+      group_everyone: "Όλοι"
       assign_mailer:
         never: "Ποτέ"
         always: "Πάντα"
diff --git a/config/locales/client.es.yml b/config/locales/client.es.yml
index 3a30461..00287e1 100644
--- a/config/locales/client.es.yml
+++ b/config/locales/client.es.yml
@@ -1,9 +1,8 @@
-# encoding: utf-8
 es:
   js:
@@ -19,6 +18,7 @@ es:
       cant_act: "No puedes actuar sobre reportes que han sido asignados a otros usuarios"
       cant_act_unclaimed: "Debes reclamar este tema antes de actuar sobre los reportes."
       assigned: "Asignado"
+      group_everyone: "Todos"
       assigned_to: "Asignado a"
       unassign:
         title: "Desasignar"
diff --git a/config/locales/client.et.yml b/config/locales/client.et.yml
index 2246537..1d68512 100644
--- a/config/locales/client.et.yml
+++ b/config/locales/client.et.yml
@@ -1,14 +1,14 @@
GitHub sha: baa9f5bc
