Update translations
Update translations
diff --git a/config/locales/client.ar.yml b/config/locales/client.ar.yml
index 52abfe6..d19c998 100644
--- a/config/locales/client.ar.yml
+++ b/config/locales/client.ar.yml
@@ -1,9 +1,8 @@
-# encoding: utf-8
-# Never edit this file. It will be overwritten when translations are pulled from Transifex.
+# WARNING: Never edit this file.
+# It will be overwritten when translations are pulled from Crowdin.
 # To work with us on translations, join this project:
-# https://www.transifex.com/projects/p/discourse-org/
+# https://translate.discourse.org/
 ar:
   js:
@@ -15,8 +14,8 @@ ar:
         filter: "بحث..."
       types:
         bool:
-          'yes': "نعم"
-          'no': "لا"
+          yes: "نعم"
+          no: "لا"
       export: "تصدير"
       save: "احفظ التعديلات"
       edit: "عدّل"
diff --git a/config/locales/client.be.yml b/config/locales/client.be.yml
index 3def422..c3468ff 100644
--- a/config/locales/client.be.yml
+++ b/config/locales/client.be.yml
@@ -1,17 +1,16 @@
-# encoding: utf-8
 be:
   js:
     explorer:
       types:
         bool:
-          'yes': "Так"
-          'no': "Не"
+          yes: "Так"
+          no: "Не"
       export: "экспарт"
       save: "Захаваць"
       edit: "Рэдагаваць"
diff --git a/config/locales/client.bg.yml b/config/locales/client.bg.yml
index 18e57ff..5a0bc38 100644
--- a/config/locales/client.bg.yml
+++ b/config/locales/client.bg.yml
@@ -1,9 +1,8 @@
-# encoding: utf-8
 bg:
   js:
@@ -14,8 +13,8 @@ bg:
         filter: "Търсене ... "
       types:
         bool:
-          'yes': "Да"
-          'no': "Не"
+          yes: "Да"
+          no: "Не"
       export: "Експорт "
       save: "Запази промените"
       edit: "Редактирай"
diff --git a/config/locales/client.bs_BA.yml b/config/locales/client.bs_BA.yml
index 9c2a72b..933de76 100644
--- a/config/locales/client.bs_BA.yml
+++ b/config/locales/client.bs_BA.yml
@@ -1,9 +1,8 @@
-# encoding: utf-8
 bs_BA:
   js:
@@ -12,8 +11,8 @@ bs_BA:
         filter: "Pretraga..."
       types:
         bool:
-          'yes': "Da"
-          'no': "Ne"
+          yes: "Da"
+          no: "Ne"
       export: "Izvoz"
       save: "Spremiti promjene"
       edit: "Izmijeni"
diff --git a/config/locales/client.ca.yml b/config/locales/client.ca.yml
index dd54456..e7fcda5 100644
--- a/config/locales/client.ca.yml
+++ b/config/locales/client.ca.yml
@@ -1,9 +1,8 @@
-# encoding: utf-8
 ca:
   js:
@@ -27,8 +26,8 @@ ca:
         type_help: "<a href='http://www.postgresql.org/docs/9.3/static/datatype.html#DATATYPE-TABLE' target='_blank'>Tipus</a>"
       types:
         bool:
-          'yes': "Sí"
-          'no': "No"
+          yes: "Sí"
+          no: "No"
           null_: "Nul"
       export: "Exporta"
       save: "Desa els canvis"
diff --git a/config/locales/client.cs.yml b/config/locales/client.cs.yml
index 1727a0e..5c4112e 100644
--- a/config/locales/client.cs.yml
+++ b/config/locales/client.cs.yml
@@ -1,9 +1,8 @@
-# encoding: utf-8
 cs:
   js:
@@ -15,8 +14,8 @@ cs:
         filter: "Hledat..."
       types:
         bool:
-          'yes': "Ano"
-          'no': "Ne"
+          yes: "Ano"
+          no: "Ne"
           null_: "Null"
       export: "Export"
       save: "Uložit změny"
diff --git a/config/locales/client.da.yml b/config/locales/client.da.yml
index 5c8c075..3aadf4d 100644
--- a/config/locales/client.da.yml
+++ b/config/locales/client.da.yml
@@ -1,9 +1,8 @@
-# encoding: utf-8
 da:
   js:
@@ -14,8 +13,8 @@ da:
         filter: "Søg..."
       types:
         bool:
-          'yes': "Ja"
-          'no': "Nej"
+          yes: "Ja"
+          no: "Nej"
       export: "Eksporter"
       save: "Gem ændringer"
       edit: "Rediger"
diff --git a/config/locales/client.de.yml b/config/locales/client.de.yml
index 5e6475f..7bfb25a 100644
--- a/config/locales/client.de.yml
+++ b/config/locales/client.de.yml
@@ -1,9 +1,8 @@
-# encoding: utf-8
 de:
   js:
@@ -28,8 +27,8 @@ de:
         type_help: "<a href='http://www.postgresql.org/docs/9.3/static/datatype.html#DATATYPE-TABLE' target='_blank'>Typen</a>"
       types:
         bool:
-          'yes': "Ja"
-          'no': "Nein"
+          yes: "Ja"
+          no: "Nein"
           null_: "Null"
       export: "Exportieren"
       save: "Änderungen speichern"
diff --git a/config/locales/client.el.yml b/config/locales/client.el.yml
index 672e9be..1b9a1a0 100644
--- a/config/locales/client.el.yml
+++ b/config/locales/client.el.yml
@@ -1,9 +1,8 @@
-# encoding: utf-8
 el:
   js:
@@ -14,8 +13,8 @@ el:
         filter: "Αναζήτηση..."
       types:
         bool:
-          'yes': "Ναι "
-          'no': "Όχι"
+          yes: "Ναι "
+          no: "Όχι"
       export: "Εξαγωγή"
       save: "Αποθήκευση Αλλαγών"
       edit: "Επεξεργασία"
diff --git a/config/locales/client.es.yml b/config/locales/client.es.yml
index cd7abd4..63f58fb 100644
--- a/config/locales/client.es.yml
+++ b/config/locales/client.es.yml
@@ -1,9 +1,8 @@
-# encoding: utf-8
GitHub sha: 3ef3d0bc
