Update translations
Update translations
diff --git a/config/locales/client.ar.yml b/config/locales/client.ar.yml
index 7db7f71..fd92cf6 100644
--- a/config/locales/client.ar.yml
+++ b/config/locales/client.ar.yml
@@ -1,9 +1,8 @@
-# encoding: utf-8
-# Never edit this file. It will be overwritten when translations are pulled from Transifex.
+# WARNING: Never edit this file.
+# It will be overwritten when translations are pulled from Crowdin.
 # To work with us on translations, join this project:
-# https://www.transifex.com/projects/p/discourse-org/
+# https://translate.discourse.org/
 ar:
   js:
diff --git a/config/locales/client.be.yml b/config/locales/client.be.yml
index b4000c4..f096949 100644
--- a/config/locales/client.be.yml
+++ b/config/locales/client.be.yml
@@ -1,9 +1,8 @@
-# encoding: utf-8
 be:
   js:
diff --git a/config/locales/client.bg.yml b/config/locales/client.bg.yml
index 2186c8e..05346ee 100644
--- a/config/locales/client.bg.yml
+++ b/config/locales/client.bg.yml
@@ -1,9 +1,8 @@
-# encoding: utf-8
 bg:
   js:
diff --git a/config/locales/client.bs_BA.yml b/config/locales/client.bs_BA.yml
index 380e844..fac349c 100644
--- a/config/locales/client.bs_BA.yml
+++ b/config/locales/client.bs_BA.yml
@@ -1,9 +1,8 @@
-# encoding: utf-8
 bs_BA:
   js:
diff --git a/config/locales/client.ca.yml b/config/locales/client.ca.yml
index f454418..a25cd4c 100644
--- a/config/locales/client.ca.yml
+++ b/config/locales/client.ca.yml
@@ -1,9 +1,8 @@
-# encoding: utf-8
 ca:
   js:
diff --git a/config/locales/client.cs.yml b/config/locales/client.cs.yml
index d142d86..63f2d33 100644
--- a/config/locales/client.cs.yml
+++ b/config/locales/client.cs.yml
@@ -1,9 +1,8 @@
-# encoding: utf-8
 cs:
   js:
diff --git a/config/locales/client.da.yml b/config/locales/client.da.yml
index 72726b0..37dc8eb 100644
--- a/config/locales/client.da.yml
+++ b/config/locales/client.da.yml
@@ -1,9 +1,8 @@
-# encoding: utf-8
 da:
   js:
diff --git a/config/locales/client.de.yml b/config/locales/client.de.yml
index 10fe70e..4341e88 100644
--- a/config/locales/client.de.yml
+++ b/config/locales/client.de.yml
@@ -1,9 +1,8 @@
-# encoding: utf-8
 de:
   js:
diff --git a/config/locales/client.el.yml b/config/locales/client.el.yml
index b1ca4c3..c062270 100644
--- a/config/locales/client.el.yml
+++ b/config/locales/client.el.yml
@@ -1,9 +1,8 @@
-# encoding: utf-8
 el:
   js:
diff --git a/config/locales/client.es.yml b/config/locales/client.es.yml
index 73bbb89..09d86c4 100644
--- a/config/locales/client.es.yml
+++ b/config/locales/client.es.yml
@@ -1,9 +1,8 @@
-# encoding: utf-8
 es:
   js:
@@ -23,6 +22,8 @@ es:
       solution_summary:
         one: "solución"
         other: "soluciones"
+      accepted_html: "%{icon} Resuelto <span class='by'>por <a href data-user-card='%{username_lower}'>%{username}</a></span> en la <a href='%{post_path}' class='back'>publicación n° %{post_number}</a>"
+      accepted_notification: "<p><span>%{username}</span> %{description}</p>"
       topic_status_filter:
         all: "todos"
         solved: "solucionado"
diff --git a/config/locales/client.et.yml b/config/locales/client.et.yml
index b73b35d..bdc4794 100644
--- a/config/locales/client.et.yml
+++ b/config/locales/client.et.yml
@@ -1,9 +1,8 @@
-# encoding: utf-8
 et:
   js:
diff --git a/config/locales/client.fa_IR.yml b/config/locales/client.fa_IR.yml
index 95f22af..7fbe055 100644
--- a/config/locales/client.fa_IR.yml
+++ b/config/locales/client.fa_IR.yml
@@ -1,9 +1,8 @@
-# encoding: utf-8
 fa_IR:
   js:
diff --git a/config/locales/client.fi.yml b/config/locales/client.fi.yml
index 5c0686e..403dfdb 100644
--- a/config/locales/client.fi.yml
+++ b/config/locales/client.fi.yml
@@ -1,9 +1,8 @@
-# encoding: utf-8
 fi:
   js:
diff --git a/config/locales/client.fr.yml b/config/locales/client.fr.yml
GitHub sha: 80e4cb87
