Update translations
Update translations
diff --git a/config/locales/client.ko.yml b/config/locales/client.ko.yml
index 844b3e5..d320fab 100644
--- a/config/locales/client.ko.yml
+++ b/config/locales/client.ko.yml
@@ -1,46 +1,12 @@
-# encoding: utf-8
-# Never edit this file. It will be overwritten when translations are pulled from Transifex.
+# WARNING: Never edit this file.
+# It will be overwritten when translations are pulled from Crowdin.
 # To work with us on translations, join this project:
-# https://www.transifex.com/projects/p/discourse-org/
+# https://translate.discourse.org/
 ko:
-  js:
-    adplugin:
-      advertisement_label: '광고'
   admin_js:
     admin:
       site_settings:
         categories:
-          ad_plugin: '광고 플러그인'
-          dfp_plugin: 'DFP/Ad 관리자'
-          adsense_plugin: '애드센스'
-          amazon_plugin: 'Amazon'
-          codefund_plugin: '코드 펀드'
-          carbonads_plugin: '카본 광고'
-          adbutler_plugin: 'AdButler'
-      adplugin:
-        house_ads:
-          title: "하우스 광고"
-          new: "새값"
-          settings: "설정"
-          new_name: "새 집 광고"
-          save: "저장"
-          delete: "삭제"
-          description: "자신의 광고와 광고를 게재 할 위치를 정의하십시오."
-          get_started: "새 광고를 만들어 시작하십시오."
-          filter_placeholder: "광고 선택 ..."
-          more_settings: "자세한 설정"
-          topic_list_top:
-            title: "주제 목록 인기 광고"
-            description: "주제 목록 페이지 상단에 게재 할 광고"
-          topic_above_post_stream:
-            title: "포스트 스트림 위의 주제"
-            description: "주제 페이지에서 주제 제목 위에 게재되는 광고"
-          topic_above_suggested:
-            title: "위의 주제 제안"
-            description: "제안 된 주제 위에 주제의 마지막 게시물 이후에 게재 할 광고입니다."
-          post_bottom:
-            title: "게시물 사이"
-            description: "N 개의 게시물마다 게시물 사이에 광고가 게재됩니다."
+          amazon_plugin: '아마존'
diff --git a/config/locales/client.ru.yml b/config/locales/client.ru.yml
index 59a753c..8aeac8f 100644
--- a/config/locales/client.ru.yml
+++ b/config/locales/client.ru.yml
@@ -7,7 +7,7 @@
 ru:
   js:
     adplugin:
-      advertisement_label: 'Реклама'
+      advertisement_label: 'РЕКЛАМА'
   admin_js:
     admin:
       site_settings:
@@ -20,25 +20,25 @@ ru:
       adplugin:
         house_ads:
-          title: "House Ads"
-          new: "Новые"
+          title: "Собственные рекламные объявления"
+          new: "Новое"
           settings: "Настройки"
-          new_name: "New House Ad"
+          new_name: "Название"
           save: "Сохранить"
           delete: "Удалить"
-          description: "Определить свои собственные объявления и где они должны отображаться."
+          description: "Определить свои собственные рекламные объявления и где они должны отображаться."
           get_started: "Начните с создания нового объявления."
           filter_placeholder: "Выберите объявления..."
           more_settings: "Больше настроек"
           topic_list_top:
-            title: "Список тем топ-объявлений"
-            description: "Объявления для показа в верхней части страницы списка тем."
+            title: "Список рекламных объявлений"
+            description: "Объявления для показа над списком тем."
-            title: "Тема выше потока сообщений"
-            description: "Объявления, отображаемые над заголовком темы на странице темы."
+            title: "Реклама , расположенная над темами"
+            description: "Объявления, отображаемые над заголовком темы при её открытии."
-            title: "Предложенная тема выше"
-            description: "Объявления показывать после последнего поста в теме, над предложенными темами."
+            title: "Реклама над перечнем похожих тем."
+            description: "Объявления, отображаемые после последнего сообщения в теме над перечнем похожих тем."
           post_bottom:
-            title: "Между постами"
-            description: "Объявления показывать между постами, после каждого N поста."
+            title: "Между сообщениями"
+            description: "Показывать рекламу между сообщениями, после каждых N сообщений."
diff --git a/config/locales/server.ko.yml b/config/locales/server.ko.yml
index 4d20c67..cfef7e0 100644
--- a/config/locales/server.ko.yml
+++ b/config/locales/server.ko.yml
@@ -1,117 +1,7 @@
-# encoding: utf-8
-ko:
-  site_settings:
-    no_ads_for_personal_messages: "개인 메시지를 볼 때 광고를 표시하지 않습니다"
-    no_ads_for_restricted_categories: "모든 사람에게 보이지 않는 카테고리에 광고를 게재하지 마십시오."
-    no_ads_for_groups: "이 그룹의 사용자에게 광고를 게재하지 마십시오."
-    no_ads_for_categories: "이러한 카테고리에 속하는 주제 목록 및 주제 페이지에 광고를 게재하지 마십시오."
-    no_ads_for_tags: "이 태그에 속하는 주제 목록 및 주제 페이지에 광고를 게재하지 마십시오."
-    house_ads_after_nth_post: ''게시물 사이'하우스 광고가 정의 된 경우 N 개의 게시물마다 광고를 게재합니다. 여기서 N은이 값입니다.'
-    house_ads_frequency: "다른 광고 네트워크가 광고 슬롯에 표시되도록 구성된 경우 하우스 광고를 얼마나 자주 게재해야하는지 백분율로 표시합니다."
-    ads_txt: "ads.txt 파일의 내용 자세한 내용은 <a href='https://support.google.com/adsense/answer/7532444?hl=en' target='_blank'>이 Google 애드 센스 도움말 페이지를 참조하십시오</a> ."
-    dfp_publisher_id: "네트워크 설정에있는 Google Ad Manager (이전의 DFP) 네트워크 코드를 입력하십시오. 참고 : &#39;콘텐츠 보안 정책 스크립트 src&#39;설정을 업데이트해야합니다. 최신 지시 사항은 <a href='https://meta.discourse.org/t/33734' target='_blank'>이 주제</a> 를 참조하십시오."
-    dfp_publisher_id_mobile: "(선택 사항) 모바일 버전의 사이트에 다른 Ad Manager 게시자 ID를 사용하려면 여기에 입력하십시오. 모바일에서 dfp_publisher_id를 사용하려면 비워 두십시오."
-    dfp_through_trust_level: "사용자 레벨에 맞추어 광고를 표시합니다. 지정된 레벨 이상의 사용자에게는 광고가 보이지 않습니다."
-    dfp_topic_list_top_code: "토픽 목록 상단에 표시할 광고 유닛의 고유 부호를 입력하세요. 이 코드는 최대 100자의 짧은 코드로 광고 유닛이 생성될 때 만들어집니다. (자바스크립트 코드가 아닙니다.)"
-    dfp_topic_list_top_ad_sizes: "토픽 목록 상단에 표시할 광고 유닛의 광고 사이즈를 선택하세요."
-    dfp_mobile_topic_list_top_code: "모바일 뷰에서 토픽 목록 상단에 표시할 광고 유닛의 고유 부호를 입력하세요. 이 코드는 최대 100자의 짧은 코드로 광고 유닛이 생성될 때 만들어집니다. (자바스크립트 코드가 아닙니다.)"
-    dfp_mobile_topic_list_top_ad_sizes: "모바일 뷰에서 토픽 목록 상단에 표시할 광고 유닛의 광고 사이즈를 선택하세요."
-    dfp_target_topic_list_top_key_code: "커스텀 타게팅 키를 입력하세요 - 인벤토리 레벨"
-    dfp_target_topic_list_top_value_code: "커스텀 타게팅 값을 입력하세요 - 인벤토리 레벨"
-    dfp_topic_above_post_stream_code: "토픽 페이지에서 토픽 제목 위에 표시할 광고 유닛의 고유 부호를 입력하세요. 이 코드는 최대 100자의 짧은 코드로 광고 유닛이 생성될 때 만들어집니다. (자바스크립트 코드가 아닙니다.)"
-    dfp_topic_above_post_stream_ad_sizes: "토픽 페이지 최상단에 표시할 광고 유닛의 광고 사이즈를 선택하세요"
-    dfp_mobile_topic_above_post_stream_code: "모바일보기의 주제 페이지에서 주제 제목 위에 표시 할 광고 단위의 고유 코드를 입력하십시오. 자바 스크립트 코드가 아니라 광고 단위를 만들 때 광고 단위에 제공되는 짧은 코드 (최대 100 자)입니다."
-    dfp_mobile_topic_above_post_stream_ad_sizes: "모바일뷰에서 토픽 페이지 최상단에 표시할 광고 유닛의 광고 사이즈를 선택하세요"
-    dfp_target_topic_above_post_stream_key_code: "커스텀 타게팅 키를 입력하세요 - 인벤토리 레벨"
-    dfp_target_topic_above_post_stream_value_code: "커스텀 타게팅 값을 입력하세요 - 인벤토리 레벨"
-    dfp_topic_above_suggested_code: "토픽의 마지막 포스트에 표시할 광고 유닛의 고유 부호를 입력하세요. 이 코드는 최대 100자의 짧은 코드로 광고 유닛이 생성될 때 만들어집니다. (자바스크립트 코드가 아닙니다.)"
-    dfp_topic_above_suggested_ad_sizes: "토픽의 가장 마지막 포스트 다음에 표시할 광고 유닛의 광고 사이즈를 선택하세요"
-    dfp_mobile_topic_above_suggested_code: "모바일보기에서 제안 된 주제 위에 주제의 마지막 게시물 이후에 표시 할 광고 단위의 고유 코드를 입력하십시오. 자바 스크립트 코드가 아니라 광고 단위를 만들 때 광고 단위에 제공되는 짧은 코드 (최대 100 자)입니다."
-    dfp_mobile_topic_above_suggested_ad_sizes: "모바일뷰에서 토픽의 가장 마지막 포스트 다음에 표시할 광고 유닛의 광고 사이즈를 선택하세요"
-    dfp_target_topic_above_suggested_key_code: "커스텀 타게팅 키를 입력하세요 - 인벤토리 레벨"
-    dfp_target_topic_above_suggested_value_code: "커스텀 타게팅 값을 입력하세요 - 인벤토리 레벨"
-    dfp_nth_post_code: "몇 개의 포스트 다음에 광고를 표시할까요?"
-    dfp_post_bottom_code: "포스트 사이에 설정된 갯수 만큼의 포스트 다음에 표시할 광고 유닛의 고유 부호를 입력하세요. 이 코드는 최대 100자의 짧은 코드로 광고 유닛이 생성될 때 만들어집니다. (자바스크립트 코드가 아닙니다.)"
-    dfp_post_bottom_ad_sizes: "포스트 사이에 표시될 광고 유닛의 광고 사이즈를 선택하세요"
GitHub sha: 20ebd91f
