Update translations
Update translations
diff --git a/config/locales/client.ko.yml b/config/locales/client.ko.yml
index a525801..7878780 100644
--- a/config/locales/client.ko.yml
+++ b/config/locales/client.ko.yml
@@ -1,40 +1,10 @@
-# encoding: utf-8
-# Never edit this file. It will be overwritten when translations are pulled from Transifex.
+# WARNING: Never edit this file.
+# It will be overwritten when translations are pulled from Crowdin.
 # To work with us on translations, join this project:
-# https://www.transifex.com/projects/p/discourse-org/
+# https://translate.discourse.org/
 ko:
   js:
-    admin:
-      logs:
-        staff_actions:
-          actions:
-            confirmed_ham: "스팸 아님"
-            confirmed_spam: "스팸 확인"
-            confirmed_spam_deleted: "스팸 확인 및 사용자 삭제"
-            dismissed: '스팸 해제'
-            ignored: '스팸 무시'
-      akismet_states:
-        new: Akismet 님은 아직이 사용자에게 스팸을 확인하지 않았습니다.
-        skipped: 이 사용자는 Akismet에서 검토 할 정보가 충분하지 않습니다.
-        confirmed_ham: Akismet는이 사용자를 확인하고 스팸이 아닌 것으로 판단했습니다.
-        confirmed_spam: Akismet은이 사용자가 스팸이라고 결정했습니다.
     akismet:
-      title: "Akismet"
-      confirm_spam: "스팸처리"
-      not_spam: "스팸아님"
-      confirm_delete: "스팸과 사용자를 삭제함"
-      reject_spam_user_delete: "사용자 삭제"
-      dismiss: "해지"
-      ignore: "무시"
-      reviewable_delete_prompt: "이 사용자를 삭제 하시겠습니까? 이렇게하면 모든 게시물이 삭제되고 이메일과 IP 주소가 차단됩니다."
-    review:
-      user:
-        bio: "바이오"
-      types:
-        reviewable_akismet_post:
-          title: "Akismet 깃발 포스트"
-        reviewable_akismet_user:
-          title: "Akismet 신고 된 사용자"
+      reject_spam_user_delete: "회원 삭제"
diff --git a/config/locales/client.zh_CN.yml b/config/locales/client.zh_CN.yml
index 52684b6..c06b7de 100644
--- a/config/locales/client.zh_CN.yml
+++ b/config/locales/client.zh_CN.yml
@@ -10,9 +10,9 @@ zh_CN:
       logs:
         staff_actions:
           actions:
-            confirmed_ham: "非垃圾信息"
+            confirmed_ham: "不是垃圾信息"
             confirmed_spam: "确认垃圾信息"
-            confirmed_spam_deleted: "确认垃圾信息并删除用户"
+            confirmed_spam_deleted: "确认是垃圾信息并删除用户"
             dismissed: '忽略垃圾信息'
             ignored: '忽略垃圾信息'
       akismet_states:
diff --git a/config/locales/server.ko.yml b/config/locales/server.ko.yml
index 1dc91f8..cfef7e0 100644
--- a/config/locales/server.ko.yml
+++ b/config/locales/server.ko.yml
@@ -1,25 +1,7 @@
-# encoding: utf-8
-ko:
-  site_settings:
-    akismet_enabled: 'Akismet을 사용하여 스팸을 확인 하시겠습니까?'
-    akismet_api_key: '스팸 검사를위한 Akismet API 키'
-    akismet_transmit_email: "스팸 확인시 포스터 이메일을 Akismet으로 전송"
-    skip_akismet_trust_level: "사용자가이 신뢰 수준 이상인 경우 게시물을 Akismet에 제출하지 마십시오."
-    skip_akismet_posts: "사용자가이 게시물을 여러 번 게시 한 경우 Akismet에 게시물을 제출하지 마십시오."
-    akismet_notify_user: "Akismet이 일시적으로 게시물을 숨겼을 때 사용자에게 알립니다."
-    akismet_review_users: "스팸 검사를 위해 TL0 사용자 바이오스를 Akismet으로 보냅니다."
-  akismet:
-    delete_reason: "%{performed_by}에서 스패머로 확인"
-  reviewables:
-    reasons:
-      akismet_spam_post: "Akismet은이 게시물을 잠재적 인 스팸으로 표시했습니다. `akismet` 설정에서 더 많은 것을보십시오."
-      akismet_spam_user: "Akismet은이 사용자를 신뢰 수준과 사용자 프로필에 따라 잠재적 인 스팸으로 표시했습니다. `akismet` 설정에서 더 많은 것을보십시오."
-  system_messages:
-    akismet_spam:
-      subject_template: "Akismet 님이 일시적으로 소식을 숨겼습니다."
+ko:
GitHub sha: e41f3718
