Update translations
Update translations
diff --git a/config/locales/client.zh_CN.yml b/config/locales/client.zh_CN.yml
index 1d8d78b..517637e 100644
--- a/config/locales/client.zh_CN.yml
+++ b/config/locales/client.zh_CN.yml
@@ -13,13 +13,32 @@ zh_CN:
     explorer:
       title: "数据查看"
       create: "创建新的"
+      description_placeholder: "在此键入描述"
+      import:
+        label: "导入"
       schema:
         filter: "搜索"
+        type_help: "<a href='http://www.postgresql.org/docs/9.3/static/datatype.html#DATATYPE-TABLE' target='_blank'>类型</a>"
       types:
         bool:
+          'yes': "是"
+          'no': "否"
           null_: "空"
       export: "导出"
+      save: "保存更改"
+      undo: "放弃更改"
       edit: "编辑"
       delete: "删除"
       download_json: "JSON"
       download_csv: "CSV"
+      result_count:
+        other: "%{count}结果"
+      max_result_count:
+        other: "显示前%{count}个结果。"
+      query_description: "描述"
+      query_time: "最后运行"
+      query_user: "创建于"
+      save_params: "设置为默认"
+      reset_params: "重置"
+      search_placeholder: "搜索……"
+      no_search_results: "抱歉,我们找不到符合你文本的结果。"
diff --git a/config/locales/server.nl.yml b/config/locales/server.nl.yml
index bb31021..39283bd 100644
--- a/config/locales/server.nl.yml
+++ b/config/locales/server.nl.yml
@@ -5,4 +5,6 @@
 # To work with us on translations, join this project:
 # https://www.transifex.com/projects/p/discourse-org/
-nl: {}
+nl:
+  site_settings:
+    data_explorer_enabled: "De Data Explorer bij /admin/plugins/explorer inschakelen."
GitHub sha: 297aefcd
