Update translations
Update translations
diff --git a/config/locales/client.ar.yml b/config/locales/client.ar.yml
index cf0a57f..1d7c7b8 100644
--- a/config/locales/client.ar.yml
+++ b/config/locales/client.ar.yml
@@ -1,9 +1,8 @@
-# encoding: utf-8
-# Never edit this file. It will be overwritten when translations are pulled from Transifex.
+# WARNING: Never edit this file.
+# It will be overwritten when translations are pulled from Crowdin.
 # To work with us on translations, join this project:
-# https://www.transifex.com/projects/p/discourse-org/
+# https://translate.discourse.org/
 ar:
   js:
diff --git a/config/locales/client.be.yml b/config/locales/client.be.yml
index 420eed3..63b83db 100644
--- a/config/locales/client.be.yml
+++ b/config/locales/client.be.yml
@@ -1,9 +1,8 @@
-# encoding: utf-8
 be:
   js:
diff --git a/config/locales/client.bg.yml b/config/locales/client.bg.yml
index 1a6ca4d..ed1b3be 100644
--- a/config/locales/client.bg.yml
+++ b/config/locales/client.bg.yml
@@ -1,9 +1,8 @@
-# encoding: utf-8
 bg:
   js:
diff --git a/config/locales/client.bs_BA.yml b/config/locales/client.bs_BA.yml
index 3b064a6..8b8a117 100644
--- a/config/locales/client.bs_BA.yml
+++ b/config/locales/client.bs_BA.yml
@@ -1,9 +1,8 @@
-# encoding: utf-8
 bs_BA:
   js:
diff --git a/config/locales/client.ca.yml b/config/locales/client.ca.yml
index 223e649..6a9c818 100644
--- a/config/locales/client.ca.yml
+++ b/config/locales/client.ca.yml
@@ -1,9 +1,8 @@
-# encoding: utf-8
 ca:
   js:
diff --git a/config/locales/client.cs.yml b/config/locales/client.cs.yml
index d0ae056..d18b87f 100644
--- a/config/locales/client.cs.yml
+++ b/config/locales/client.cs.yml
@@ -1,9 +1,8 @@
-# encoding: utf-8
 cs:
   js:
diff --git a/config/locales/client.da.yml b/config/locales/client.da.yml
index 5ba2d3b..0e34b12 100644
--- a/config/locales/client.da.yml
+++ b/config/locales/client.da.yml
@@ -1,9 +1,8 @@
-# encoding: utf-8
 da:
   js:
diff --git a/config/locales/client.de.yml b/config/locales/client.de.yml
index da2a58c..bd9df47 100644
--- a/config/locales/client.de.yml
+++ b/config/locales/client.de.yml
@@ -1,9 +1,8 @@
-# encoding: utf-8
 de:
   js:
diff --git a/config/locales/client.el.yml b/config/locales/client.el.yml
index 81db4f0..2acc063 100644
--- a/config/locales/client.el.yml
+++ b/config/locales/client.el.yml
@@ -1,9 +1,8 @@
-# encoding: utf-8
 el:
   js:
diff --git a/config/locales/client.es.yml b/config/locales/client.es.yml
index 634acb6..46f60c9 100644
--- a/config/locales/client.es.yml
+++ b/config/locales/client.es.yml
@@ -1,9 +1,8 @@
-# encoding: utf-8
 es:
   js:
diff --git a/config/locales/client.et.yml b/config/locales/client.et.yml
index 88b9d84..7652f47 100644
--- a/config/locales/client.et.yml
+++ b/config/locales/client.et.yml
@@ -1,9 +1,8 @@
-# encoding: utf-8
 et:
   js:
diff --git a/config/locales/client.fa_IR.yml b/config/locales/client.fa_IR.yml
index 32ded43..6f271b7 100644
--- a/config/locales/client.fa_IR.yml
+++ b/config/locales/client.fa_IR.yml
@@ -1,19 +1,26 @@
-# encoding: utf-8
 fa_IR:
   js:
     patreon:
+      title: 'پاترون'
       header:
         rules: 'فیلترها'
       group: 'گروه'
+      rewards: 'پاداش'
       filter: 'فیلتر'
       edit: 'ویرایش'
       delete: 'حذف'
       save: 'ذخیره'
+      select_group: 'یک گروه را انتخاب کنید'
       field:
+        id: "شناسه"
         email: "ایمیل"
+        amount_cents: "مقدار (به سنت)"
+        rewards: "پاداش"
+        more_details:
+          label: "پرداخت‌ها و جزئیات بیشتر"
diff --git a/config/locales/client.fi.yml b/config/locales/client.fi.yml
index b47d0dc..4167feb 100644
--- a/config/locales/client.fi.yml
+++ b/config/locales/client.fi.yml
@@ -1,9 +1,8 @@
-# encoding: utf-8
 fi:
   js:
diff --git a/config/locales/client.fr.yml b/config/locales/client.fr.yml
index 839b058..73da3d2 100644
GitHub sha: 7e4df37f
