Update translations
Update translations
diff --git a/config/locales/client.de.yml b/config/locales/client.de.yml
index 24e0be8..abd59d6 100644
--- a/config/locales/client.de.yml
+++ b/config/locales/client.de.yml
@@ -32,8 +32,8 @@ de:
           null_: "Null"
       export: "Exportieren"
       save: "Änderungen speichern"
-      saverun: "Änderungen speichern und Anfrage starten"
-      run: "Anfrage starten"
+      saverun: "Änderungen speichern und los"
+      run: "los"
       undo: "Änderungen verwerfen"
       edit: "Bearbeiten"
       delete: "Löschen"
diff --git a/config/locales/client.es.yml b/config/locales/client.es.yml
index 8ccbfc9..15dfcf4 100644
--- a/config/locales/client.es.yml
+++ b/config/locales/client.es.yml
@@ -32,8 +32,8 @@ es:
           null_: "Null"
       export: "Exportar"
       save: "Guardar Cambios"
-      saverun: "Guardar cambios y Ejecutar consulta"
-      run: "Ejecutar Consulta"
+      saverun: "Guardar cambios y ejecutar"
+      run: "Ejecutar"
       undo: "Deshacer cambios"
       edit: "Editar"
       delete: "Borrar"
diff --git a/config/locales/client.et.yml b/config/locales/client.et.yml
index a670651..ce3cd37 100644
--- a/config/locales/client.et.yml
+++ b/config/locales/client.et.yml
@@ -22,7 +22,6 @@ et:
           'no': "Ei"
       export: "Ekspordi"
       save: "Salvesta muudatused"
-      run: "Käivita päring"
       edit: "Muuda"
       delete: "Kustuta"
       download_json: "JSON"
diff --git a/config/locales/client.fi.yml b/config/locales/client.fi.yml
index d919500..c488ca2 100644
--- a/config/locales/client.fi.yml
+++ b/config/locales/client.fi.yml
@@ -31,8 +31,6 @@ fi:
           null_: "Tyhjä"
       export: "Vie"
       save: "Tallenna muutokset"
-      saverun: "Tallenna muutokset ja suorita kysely"
-      run: "Suorita kysely"
       undo: "Kumoa muutokset"
       edit: "Muokkaa"
       delete: "Poista"
diff --git a/config/locales/client.he.yml b/config/locales/client.he.yml
index 4f72003..13469e3 100644
--- a/config/locales/client.he.yml
+++ b/config/locales/client.he.yml
@@ -31,8 +31,6 @@ he:
           null_: "אפס"
       export: "ייצוא"
       save: "שמירת שינויים"
-      saverun: "שמירת השינויים והרצת השאילתה"
-      run: "הרצת השאילתה"
       undo: "התעלמות מהשינויים"
       edit: "עריכה"
       delete: "מחיקה"
diff --git a/config/locales/client.hu.yml b/config/locales/client.hu.yml
index 5efc61e..cae8d7d 100644
--- a/config/locales/client.hu.yml
+++ b/config/locales/client.hu.yml
@@ -26,8 +26,6 @@ hu:
           null_: "Null"
       export: "Exportálás"
       save: "Módosítások mentése"
-      saverun: "Módosítások mentése és a lekérdezés futtatása"
-      run: "Lekérdezés futtatása"
       undo: "Változtatások eldobása"
       edit: "Szerkesztés"
       delete: "Törlés"
diff --git a/config/locales/client.it.yml b/config/locales/client.it.yml
index 24ba997..9880b0b 100644
--- a/config/locales/client.it.yml
+++ b/config/locales/client.it.yml
@@ -32,8 +32,6 @@ it:
           null_: "Null"
       export: "Esporta"
       save: "Salva Modifiche"
-      saverun: "Salva Modifiche e Esegui Query"
-      run: "Esegui Query"
       undo: "Annulla Modifiche"
       edit: "Modifica"
       delete: "Elimina"
diff --git a/config/locales/client.nb_NO.yml b/config/locales/client.nb_NO.yml
index 438e252..d486522 100644
--- a/config/locales/client.nb_NO.yml
+++ b/config/locales/client.nb_NO.yml
@@ -28,8 +28,6 @@ nb_NO:
           null_: "Null"
       export: "Eksporter"
       save: "Lagre endringer"
-      saverun: "Lagre endringer og kjør spørring"
-      run: "Kjør spørring"
       undo: "Forkast endringer"
       edit: "Rediger"
       delete: "Slett"
diff --git a/config/locales/client.pt_BR.yml b/config/locales/client.pt_BR.yml
index 636ae8e..aff7dc2 100644
--- a/config/locales/client.pt_BR.yml
+++ b/config/locales/client.pt_BR.yml
@@ -31,8 +31,6 @@ pt_BR:
           null_: "Nulo"
       export: "Exportar"
       save: "Salvar Mudanças"
-      saverun: "Salvar alterações e executar consulta"
-      run: "Executar consulta"
       undo: "Descartar mudanças"
       edit: "Editar"
       delete: "Apagar"
diff --git a/config/locales/client.ru.yml b/config/locales/client.ru.yml
index 13229f3..99f5f90 100644
--- a/config/locales/client.ru.yml
+++ b/config/locales/client.ru.yml
@@ -32,8 +32,6 @@ ru:
           null_: "Null"
       export: "Экспорт"
       save: "Сохранить изменения"
-      saverun: "Сохранить изменения и выполнить запрос"
-      run: "Запустить запрос"
       undo: "Отменить изменения"
       edit: "Редактировать"
       delete: "Удалить"
diff --git a/config/locales/client.sw.yml b/config/locales/client.sw.yml
index c35f551..295a99f 100644
--- a/config/locales/client.sw.yml
+++ b/config/locales/client.sw.yml
@@ -32,8 +32,6 @@ sw:
           null_: "Hamna Kitu"
       export: "Hamisha"
       save: "Hifadhi Mabadiliko"
-      saverun: "Hifadhi Mabadiliko na Uliza Swali"
-      run: "Uliza Swali"
       undo: "Kataa Mabadiliko"
       edit: "Hariri"
       delete: "Futa"
diff --git a/config/locales/client.ur.yml b/config/locales/client.ur.yml
index f9bd87b..658ac0c 100644
--- a/config/locales/client.ur.yml
+++ b/config/locales/client.ur.yml
@@ -31,8 +31,6 @@ ur:
           null_: "خالی"
       export: "برآمد"
       save: "تبدیلیاں محفوظ کریں"
-      saverun: "تبدیلیاں محفوظ کریں اور ڈیٹا کمانڈ چلائیں"
-      run: "ڈیٹا کمانڈ چلائیں"
       undo: "تبدیلیاں منسوخ کریں"
       edit: "ترمیم کریں"
       delete: "حذف کریں"
GitHub sha: 7a1cd31f
