Update translations
Update translations
index 9f8bf5f..4e2f5e9 100644
--- a/Gemfile.lock
+++ b/Gemfile.lock
@@ -1,8 +1,8 @@
 GIT
   remote: https://github.com/discourse/translations-manager.git
-  revision: 30ee1a4bbceac724794778ad7654f0434b836a06
+  revision: 263dc4b189629c748229b3c2564e1d1fac0a84a7
   specs:
-    translations-manager (0.3)
+    translations-manager (0.4)
 GEM
   specs:
@@ -14,4 +14,4 @@ DEPENDENCIES
   translations-manager!
 BUNDLED WITH
-   1.17.1
+   1.17.3
diff --git a/config/locales/client.fa_IR.yml b/config/locales/client.fa_IR.yml
index 76bfc02..c3e8e1c 100644
--- a/config/locales/client.fa_IR.yml
+++ b/config/locales/client.fa_IR.yml
@@ -18,3 +18,4 @@ fa_IR:
       has_no_accepted_answer: "این موضوع هیچ راه حلی ندارد"
       accepted_answer: "راه حل مورد قبول"
       solution: "راه حل"
+      accepted_html: "{{icon}}<span class='by'>توسط<a href data-user-card='{{username_lower}}'>{{username}}</a></span> در <a href='{{post_path}}' class='back'>پست {{post_number}}</a>حل شد. "
diff --git a/config/locales/client.fi.yml b/config/locales/client.fi.yml
index b1cd017..76381da 100644
--- a/config/locales/client.fi.yml
+++ b/config/locales/client.fi.yml
@@ -14,7 +14,14 @@ fi:
     solved:
       title: "Ratkaisemat"
       allow_accepted_answers: "Salli aiheen omistajan ja henkilökunnan merkitä viesti ratkaisuksi"
+      accept_answer: "Valitse, tämä vastaus ratkaisee ongelman"
       has_accepted_answer: "Tämä aihe on ratkaistu"
       has_no_accepted_answer: "Tähän aiheeseen ei ole ratkaisua"
+      unaccept_answer: "Kumoa valinta, tämä vastaus ei enää ratkaise ongelmaa"
       accepted_answer: "Ratkaisu"
       solution: "Ratkaisu"
+      solution_summary:
+        one: "ratkaisu"
+        other: "ratkaisut"
+      accepted_html: "{{icon}} <span class='by'><a href data-user-card='{{username_lower}}'>{{username}}</a></span> ratkaisi <a href='{{post_path}}' class='back'>viestissä #{{post_number}}</a>"
+      accepted_notification: "<p><span>{{username}}</span> {{description}}</p>"
diff --git a/config/locales/client.it.yml b/config/locales/client.it.yml
index 8c592aa..5c48992 100644
--- a/config/locales/client.it.yml
+++ b/config/locales/client.it.yml
@@ -20,3 +20,5 @@ it:
       unaccept_answer: "Deseleziona se questa risposta non risolve più il problema"
       accepted_answer: "Soluzione"
       solution: "Soluzione"
+      accepted_html: "{{icon}} Risolto<span class='by'>da <a href data-user-card='{{username_lower}}'>{{username}}</a></span> nel <a href='{{post_path}}' class='back'>messaggio n°{{post_number}}</a>"
diff --git a/config/locales/client.ja.yml b/config/locales/client.ja.yml
index 8c2dc00..eb6fc21 100644
--- a/config/locales/client.ja.yml
+++ b/config/locales/client.ja.yml
@@ -5,4 +5,7 @@
 # To work with us on translations, join this project:
 # https://www.transifex.com/projects/p/discourse-org/
-ja: {}
+ja:
+  js:
+    solved:
+      title: "解決"
diff --git a/config/locales/client.nl.yml b/config/locales/client.nl.yml
index 92ff450..5ba42de 100644
--- a/config/locales/client.nl.yml
+++ b/config/locales/client.nl.yml
@@ -13,10 +13,10 @@ nl:
           accepted_notification: "Geaccepteerd"
     solved:
       title: "Opgelost"
-      allow_accepted_answers: "Sta topic (het) eigenaar en personeel toe om een reactie als oplossing te selecteren"
+      allow_accepted_answers: "Sta topic-eigenaar en personeel toe om een reactie als oplossing te selecteren"
       accept_answer: "Selecteer dit als deze reactie het probleem oplost"
-      has_accepted_answer: "Dit topic (het) heeft een oplossing"
-      has_no_accepted_answer: "Dit topic (het) heeft geen oplossing"
+      has_accepted_answer: "Dit topic heeft een oplossing"
+      has_no_accepted_answer: "Dit topic heeft geen oplossing"
       unaccept_answer: "Deselecteer dit als deze reactie je probleem niet langer oplost"
       accepted_answer: "Oplossing"
       solution: "Oplossing"
diff --git a/config/locales/client.ru.yml b/config/locales/client.ru.yml
index a82c003..fbbb4af 100644
--- a/config/locales/client.ru.yml
+++ b/config/locales/client.ru.yml
@@ -20,3 +20,8 @@ ru:
       unaccept_answer: "Отмените выбор, если этот ответ больше не решает проблему"
       accepted_answer: "Подтвержденный ответ"
       solution: "Ответ"
+      solution_summary:
+        one: "Подтвержденный ответ"
+        few: "Подтвержденных ответов"
+        many: "Подтвержденных ответов"
+        other: "Подтвержденных ответов"
diff --git a/config/locales/client.zh_CN.yml b/config/locales/client.zh_CN.yml
index 891a8d5..2301c5f 100644
--- a/config/locales/client.zh_CN.yml
+++ b/config/locales/client.zh_CN.yml
@@ -20,3 +20,7 @@ zh_CN:
       unaccept_answer: "取消选择如果此回复不再解决问题"
       accepted_answer: "解决方案"
       solution: "解决方案"
+      solution_summary:
+        other: "解决方案"
+      accepted_html: "{{icon}}由<span class='by'><a href data-user-card='{{username_lower}}'>{{username}}</a></span>在<a href='{{post_path}}'>#{{post_number}}楼</a>解决"
diff --git a/config/locales/server.nl.yml b/config/locales/server.nl.yml
index eaad6bb..28312f7 100644
--- a/config/locales/server.nl.yml
+++ b/config/locales/server.nl.yml
@@ -8,6 +8,8 @@
 nl:
   site_settings:
     solved_enabled: "Schakel solved plugin in, stelt gebruikers in staat om oplossing voor hun topics te selecteren"
+    allow_solved_on_all_topics: "Sta gebruikers toe om oplossen te selecteren voor alle topics (standaard controleer je deze setting bij het opzetten van de categorieën)"
+    empty_box_on_unsolved: "Toon een lege checkbox bij onopgeloste topics"
   reports:
     accepted_solutions:
       title: "Geaccepteerde oplossingen"
GitHub sha: 93c08c8d
