Update translations
Update translations
index 4e2f5e9..8007aa4 100644
--- a/Gemfile.lock
+++ b/Gemfile.lock
@@ -1,6 +1,6 @@
 GIT
   remote: https://github.com/discourse/translations-manager.git
-  revision: 263dc4b189629c748229b3c2564e1d1fac0a84a7
+  revision: ecddec65f6a45d678b7db45045d712106d7a69d8
   specs:
     translations-manager (0.4)
diff --git a/config/locales/client.ar.yml b/config/locales/client.ar.yml
index cad7d85..5595db2 100644
--- a/config/locales/client.ar.yml
+++ b/config/locales/client.ar.yml
@@ -15,7 +15,6 @@ ar:
       title: "تم الحل"
       allow_accepted_answers: "السماح لصاحب الموضوع وفريق العمل الرد كـحل للموضوع"
       accept_answer: "اختر إن كان هذا الرد يحل المشكلة"
-      has_accepted_answer: "هذا الموضوع فيه الحل"
       has_no_accepted_answer: "لا يوجد حل بخصوص هذا الموضوع"
       unaccept_answer: "احذف الاختيار إن كان هذا الرد لا يحل المشكلة الآن"
       accepted_answer: "الحل"
diff --git a/config/locales/client.cs.yml b/config/locales/client.cs.yml
index 116f3d0..de2509c 100644
--- a/config/locales/client.cs.yml
+++ b/config/locales/client.cs.yml
@@ -15,7 +15,6 @@ cs:
       title: "Vyřešeno"
       allow_accepted_answers: "Povolit vlastníkovi tématu a správcům označit odpověď jako řešení"
       accept_answer: "Tato odpověď je řešením problému"
-      has_accepted_answer: "Toto téma má řešení"
       has_no_accepted_answer: "Toto téma nemá žádné řešení"
       unaccept_answer: "Tato odpověď již neřeší tento problém"
       accepted_answer: "Řešení"
diff --git a/config/locales/client.da.yml b/config/locales/client.da.yml
index 485c4b9..dc14ff1 100644
--- a/config/locales/client.da.yml
+++ b/config/locales/client.da.yml
@@ -9,6 +9,5 @@ da:
   js:
     solved:
       allow_accepted_answers: "Tillad ejer af emne og stab at markere svar som en løsning"
-      has_accepted_answer: "Dette svar har en løsning"
       accepted_answer: "Løsning"
       solution: "Løsning"
diff --git a/config/locales/client.de.yml b/config/locales/client.de.yml
index 7430bb6..f24addd 100644
--- a/config/locales/client.de.yml
+++ b/config/locales/client.de.yml
@@ -15,7 +15,6 @@ de:
       title: "Gelöst"
       allow_accepted_answers: "Erlaube dem Ersteller des Themas und Mitarbeitern eine Antwort als Lösung zu markieren"
       accept_answer: "Auswählen, wenn diese Antwort das Problem löst"
-      has_accepted_answer: "Dieses Thema hat eine Lösung"
       has_no_accepted_answer: "Dieses Thema hat keine Lösung"
       unaccept_answer: "Abwählen, wenn diese Antwort das Problem nicht mehr löst"
       accepted_answer: "Lösung"
@@ -25,3 +24,10 @@ de:
         other: "Lösungen"
       accepted_html: "{{icon}} Gelöst <span class='by'>von <a href data-user-card='{{username_lower}}'>{{username}}</a></span> in <a href='{{post_path}}' class='back'>Beitrag #{{post_number}}</a>"
       accepted_notification: "<p><span>{{username}}</span> {{description}}</p>"
+      topic_status_filter:
+        all: "alle"
+        solved: "gelöst"
+        unsolved: "ungelöst"
+    topic_statuses:
+      solved:
+        help: "Dieses Thema hat eine Lösung"
diff --git a/config/locales/client.es.yml b/config/locales/client.es.yml
index 0ae92da..2f7a7f8 100644
--- a/config/locales/client.es.yml
+++ b/config/locales/client.es.yml
@@ -15,7 +15,6 @@ es:
       title: "Solucionado"
       allow_accepted_answers: "Permitir que el autor del tema y el staff marquen una respuesta como solución"
       accept_answer: "Seleccionar si esta respuesta soluciona el problema"
-      has_accepted_answer: "Este tema tiene una solución"
       has_no_accepted_answer: "Este tema no tiene una solución"
       unaccept_answer: "Deseleccionar si esta respuesta ya no resuelve el problema"
       accepted_answer: "Solución"
@@ -25,3 +24,10 @@ es:
         other: "soluciones"
       accepted_html: "{{icon}} Solucionado <span class='by'>por <a href data-user-card='{{username_lower}}'>{{username}}</a></span> en el <a href='{{post_path}}' class='back'>post #{{post_number}}</a>"
+        all: "todas"
+        solved: "solucionado"
+        unsolved: "sin solución"
+    topic_statuses:
+      solved:
+        help: "Este tema tiene una solución"
diff --git a/config/locales/client.et.yml b/config/locales/client.et.yml
index b64804f..6338637 100644
--- a/config/locales/client.et.yml
+++ b/config/locales/client.et.yml
@@ -13,7 +13,6 @@ et:
           accepted_notification: "aktsepteeritud"
     solved:
       title: "Lahendatud"
-      has_accepted_answer: "ellel teemal on lahendus"
       has_no_accepted_answer: "Sellel teemal pole lahendust"
       accepted_answer: "Lahendus"
       solution: "Lahendus"
diff --git a/config/locales/client.fa_IR.yml b/config/locales/client.fa_IR.yml
index c3e8e1c..49cf912 100644
--- a/config/locales/client.fa_IR.yml
+++ b/config/locales/client.fa_IR.yml
@@ -14,7 +14,6 @@ fa_IR:
     solved:
       title: "حل شده"
       allow_accepted_answers: "به صاحب عنوان و مدیران اجازه انتخاب یک پاسخ را به عنوان راه حل بده."
-      has_accepted_answer: "این موضوع راه حلی دارد"
       has_no_accepted_answer: "این موضوع هیچ راه حلی ندارد"
       accepted_answer: "راه حل مورد قبول"
       solution: "راه حل"
diff --git a/config/locales/client.fi.yml b/config/locales/client.fi.yml
index 76381da..35cd7c4 100644
--- a/config/locales/client.fi.yml
+++ b/config/locales/client.fi.yml
@@ -15,7 +15,6 @@ fi:
       title: "Ratkaisemat"
       allow_accepted_answers: "Salli aiheen omistajan ja henkilökunnan merkitä viesti ratkaisuksi"
       accept_answer: "Valitse, tämä vastaus ratkaisee ongelman"
-      has_accepted_answer: "Tämä aihe on ratkaistu"
       has_no_accepted_answer: "Tähän aiheeseen ei ole ratkaisua"
       unaccept_answer: "Kumoa valinta, tämä vastaus ei enää ratkaise ongelmaa"
       accepted_answer: "Ratkaisu"
diff --git a/config/locales/client.fr.yml b/config/locales/client.fr.yml
index 42921c4..dfffdf8 100644
--- a/config/locales/client.fr.yml
+++ b/config/locales/client.fr.yml
@@ -15,7 +15,6 @@ fr:
       title: "Solutions"
       allow_accepted_answers: "Autoriser l'auteur du sujet et les responsables à marquer une réponse comme solution"
       accept_answer: "Sélectionner si cette réponse résout le problème"
-      has_accepted_answer: "Ce sujet a une solution"
       has_no_accepted_answer: "Ce sujet n'a pas de solution"
       unaccept_answer: "Désélectionner si cette réponse ne résout plus le problème"
       accepted_answer: "Solution"
@@ -25,3 +24,10 @@ fr:
         other: "solutions"
       accepted_html: "{{icon}} Résolu <span class='by'>par <a href data-user-card='{{username_lower}}'>{{username}}</a></span> dans le <a href='{{post_path}}' class='back'>message #{{post_number}}</a>"
+        all: "tout"
+        solved: "résolu"
+        unsolved: "non résolu"
+    topic_statuses:
+      solved:
+        help: "Ce sujet a une solution"
diff --git a/config/locales/client.he.yml b/config/locales/client.he.yml
index cbc1820..014e07b 100644
--- a/config/locales/client.he.yml
+++ b/config/locales/client.he.yml
@@ -14,7 +14,6 @@ he:
     solved:
       title: "נפתר"
       allow_accepted_answers: "אפשר למשתמשים לאשר תשובות"
-      has_accepted_answer: "נושא זה נפתר"
       has_no_accepted_answer: "לנושא הזה אין פתרון"
       accepted_answer: "קבל תשובה"
       solution: "פתרון"
diff --git a/config/locales/client.hu.yml b/config/locales/client.hu.yml
index acd9d13..fe3de7d 100644
--- a/config/locales/client.hu.yml
+++ b/config/locales/client.hu.yml
@@ -15,7 +15,6 @@ hu:
       title: "Megoldva"
       allow_accepted_answers: "Engedélyezi a téma tulajdonosának és a személyzetnek, hogy megjelöljenek egy bejegyzést mint megoldás"
       accept_answer: "Válaszd ki, ha ez a válasz megoldotta a problémát"
-      has_accepted_answer: "Ez a téma tartalmaz egy megoldást"
GitHub sha: ab1eb503
