Update translations
Update translations
diff --git a/config/locales/client.ar.yml b/config/locales/client.ar.yml
index 7613a74..26b5c00 100644
--- a/config/locales/client.ar.yml
+++ b/config/locales/client.ar.yml
@@ -21,4 +21,6 @@ ar:
       save: "احفظ التعديلات"
       edit: "عدّل"
       delete: "أحذف"
+      query_description: "الوصف"
       reset_params: "اعادة تعيين"
+      search_placeholder: "بحث..."
diff --git a/config/locales/client.bg.yml b/config/locales/client.bg.yml
index 53ef6a6..16daf5c 100644
--- a/config/locales/client.bg.yml
+++ b/config/locales/client.bg.yml
@@ -5,4 +5,20 @@
 # To work with us on translations, join this project:
 # https://www.transifex.com/projects/p/discourse-org/
-bg: {}
+bg:
+  js:
+    explorer:
+      import:
+        label: "Импорт"
+      schema:
+        filter: "Търсене ... "
+      types:
+        bool:
+          'yes': "Да"
+          'no': "Не"
+      export: "Експорт "
+      save: "Запази промените"
+      edit: "Редактирай"
+      delete: "Изтрий"
+      query_description: "Описание"
+      search_placeholder: "Търсене ... "
diff --git a/config/locales/client.bs_BA.yml b/config/locales/client.bs_BA.yml
index 7b73cd2..f64a940 100644
--- a/config/locales/client.bs_BA.yml
+++ b/config/locales/client.bs_BA.yml
@@ -5,4 +5,17 @@
-bs_BA: {}
+bs_BA:
+  js:
+    explorer:
+      schema:
+        filter: "Pretraga..."
+      types:
+        bool:
+          'yes': "Da"
+          'no': "Ne"
+      save: "Spremiti promjene"
+      edit: "Izmijeni"
+      delete: "Delete"
+      query_description: "Opis"
+      search_placeholder: "Pretraga..."
diff --git a/config/locales/client.ca.yml b/config/locales/client.ca.yml
index 4102071..07aa5d6 100644
--- a/config/locales/client.ca.yml
+++ b/config/locales/client.ca.yml
@@ -20,5 +20,9 @@ ca:
       export: "Exporta"
       save: "Desa els canvis"
       edit: "Edita"
+      delete: "Esborra"
       download_json: "JSON"
       download_csv: "CSV"
+      query_description: "Descripció"
+      reset_params: "Reinicia"
+      search_placeholder: "Cerca..."
diff --git a/config/locales/client.cs.yml b/config/locales/client.cs.yml
index c422233..efdc05a 100644
--- a/config/locales/client.cs.yml
+++ b/config/locales/client.cs.yml
@@ -24,4 +24,7 @@ cs:
       delete: "Smazat"
       download_csv: "CSV"
+      query_description: "Popis"
       column: "Sloupec {{number}}"
+      reset_params: "obnovit výchozí"
+      search_placeholder: "Hledat..."
diff --git a/config/locales/client.da.yml b/config/locales/client.da.yml
index 9ca8189..ae00749 100644
--- a/config/locales/client.da.yml
+++ b/config/locales/client.da.yml
@@ -5,4 +5,21 @@
-da: {}
+da:
+  js:
+    explorer:
+      import:
+        label: "Importer"
+      schema:
+        filter: "Søg..."
+      types:
+        bool:
+          'yes': "Ja"
+          'no': "Nej"
+      export: "Eksporter"
+      save: "Gem ændringer"
+      edit: "Rediger"
+      delete: "Slet"
+      query_description: "Beskrivelse"
+      reset_params: "Nulstil"
+      search_placeholder: "Søg..."
diff --git a/config/locales/client.el.yml b/config/locales/client.el.yml
index 63bf4b0..654d54c 100644
--- a/config/locales/client.el.yml
+++ b/config/locales/client.el.yml
@@ -5,4 +5,21 @@
-el: {}
+el:
+  js:
+    explorer:
+      import:
+        label: "Εισαγωγή"
+      schema:
+        filter: "Αναζήτηση..."
+      types:
+        bool:
+          'yes': "Ναι "
+          'no': "Όχι"
+      export: "Εξαγωγή"
+      save: "Αποθήκευση Αλλαγών"
+      edit: "Επεξεργασία"
+      delete: "Σβήσιμο"
+      query_description: "Περιγραφή"
+      reset_params: "Επαναφορά"
+      search_placeholder: "Αναζήτηση..."
diff --git a/config/locales/client.et.yml b/config/locales/client.et.yml
index ce3cd37..497de97 100644
--- a/config/locales/client.et.yml
+++ b/config/locales/client.et.yml
@@ -26,5 +26,7 @@ et:
       delete: "Kustuta"
       download_csv: "CSV"
+      query_description: "Kirjeldus"
       save_params: "Määra vaikeväärtused"
       reset_params: "Nulli"
+      search_placeholder: "Otsi..."
diff --git a/config/locales/client.fa_IR.yml b/config/locales/client.fa_IR.yml
index 3f564b2..b85d6a6 100644
--- a/config/locales/client.fa_IR.yml
+++ b/config/locales/client.fa_IR.yml
@@ -5,4 +5,21 @@
-fa_IR: {}
+fa_IR:
+  js:
+    explorer:
+      import:
+        label: "ورود داده‌ها"
+      schema:
+        filter: "جستجو..."
+      types:
+        bool:
+          'yes': "بله"
+          'no': "خیر"
+      export: "خروجی گرفتن"
+      save: "ذخیره تغییرات"
+      edit: "ویرایش"
+      delete: "حذف"
+      query_description: "توضیح"
+      reset_params: "بازنشانی"
+      search_placeholder: "جستجو..."
diff --git a/config/locales/client.fi.yml b/config/locales/client.fi.yml
index c488ca2..8589d27 100644
--- a/config/locales/client.fi.yml
+++ b/config/locales/client.fi.yml
@@ -39,7 +39,9 @@ fi:
       download_csv: "CSV"
       others_dirty: "Kyselyyn tehdyt tallentamattomat muutokset menetetään, jos navigoit pois. "
       run_time: "Kysely suoritettiin ajassa {{value}} ms."
+      query_description: "Kuvaus"
       column: "Sarake {{number}}"
       explain_label: "Sisällytä kyselysuunnitelma?"
       save_params: "Aseta oletusarvot"
       reset_params: "Nollaa"
+      search_placeholder: "Hae..."
diff --git a/config/locales/client.gl.yml b/config/locales/client.gl.yml
index 695b5cf..d237d0b 100644
--- a/config/locales/client.gl.yml
+++ b/config/locales/client.gl.yml
@@ -5,4 +5,17 @@
-gl: {}
+gl:
+  js:
+    explorer:
+      import:
+        label: "Importar"
+      types:
+        bool:
+          'yes': "Si"
+          'no': "Non"
+      export: "Exportar"
+      save: "Gardar os cambios"
+      edit: "Editar"
+      delete: "Eliminar"
+      query_description: "Descrición"
diff --git a/config/locales/client.he.yml b/config/locales/client.he.yml
index 13469e3..d56726d 100644
--- a/config/locales/client.he.yml
+++ b/config/locales/client.he.yml
@@ -16,6 +16,7 @@ he:
       title: "דפדפן נתונים"
       create: "יצירת חדשה"
       create_placeholder: "שם השאילתה…"
+      description_placeholder: "יש להקליד תיאור כאן"
       import:
         label: "ייבוא"
         modal: "ייבוא שאילתה"
@@ -31,6 +32,8 @@ he:
           null_: "אפס"
       export: "ייצוא"
       save: "שמירת שינויים"
+      saverun: "שמירת השינויים והרצה"
+      run: "הרצה"
       undo: "התעלמות מהשינויים"
       edit: "עריכה"
       delete: "מחיקה"
@@ -39,7 +42,23 @@ he:
       download_csv: "CSV"
       others_dirty: "בשאילתה נערכו שינויים שטרם נשמרו ועשויים ללכת לאיבוד בעת ניווט למקום אחר."
       run_time: "השאילתה הושלמה תוך {{value}} מילישניות."
+      result_count:
+        one: "תוצאה אחת."
+        two: "2 תוצאות."
+        many: "%{count} תוצאות."
+        other: "%{count} תוצאות."
+      max_result_count:
+        one: "התוצאה המובילה מופיעה."
+        two: "2 התוצאות המובילות מופיעות."
+        many: "%{count} התוצאות המובילות מופיעות."
+        other: "%{count} התוצאות המובילות מופיעות."
+      query_name: "שאילתה"
+      query_description: "תיאור"
+      query_time: "הרצה אחרונה"
+      query_user: "נוצר על ידי"
       column: "עמודה {{number}}"
       explain_label: "לכלול תכנית שאילתה?"
       save_params: "הגדרת בררות מחדל"
       reset_params: "איפוס"
+      search_placeholder: "חיפוש..."
+      no_search_results: "לא הצלחנו למצוא תוצאות שתואמות לטקסט שלך, עמך הסליחה."
GitHub sha: 9e5a252e
