Update translations
Update translations
index 8007aa4..5c2528f 100644
--- a/Gemfile.lock
+++ b/Gemfile.lock
@@ -1,6 +1,6 @@
 GIT
   remote: https://github.com/discourse/translations-manager.git
-  revision: ecddec65f6a45d678b7db45045d712106d7a69d8
+  revision: 7fe7d67f53fe917341b7abfb101b529be264fc8d
   specs:
     translations-manager (0.4)
diff --git a/config/locales/client.ar.yml b/config/locales/client.ar.yml
index 5595db2..74bc4ee 100644
--- a/config/locales/client.ar.yml
+++ b/config/locales/client.ar.yml
@@ -19,3 +19,8 @@ ar:
       unaccept_answer: "احذف الاختيار إن كان هذا الرد لا يحل المشكلة الآن"
       accepted_answer: "الحل"
       solution: "الحل"
+      topic_status_filter:
+        all: "الكل"
+    topic_statuses:
+      solved:
+        help: "هذا الموضوع فيه الحل"
diff --git a/config/locales/client.bg.yml b/config/locales/client.bg.yml
index 53ef6a6..99735bf 100644
--- a/config/locales/client.bg.yml
+++ b/config/locales/client.bg.yml
@@ -5,4 +5,8 @@
 # To work with us on translations, join this project:
 # https://www.transifex.com/projects/p/discourse-org/
-bg: {}
+bg:
+  js:
+    solved:
+        all: "всички подкатегории"
diff --git a/config/locales/client.bs_BA.yml b/config/locales/client.bs_BA.yml
index 7b73cd2..63410e2 100644
--- a/config/locales/client.bs_BA.yml
+++ b/config/locales/client.bs_BA.yml
@@ -5,4 +5,8 @@
-bs_BA: {}
+bs_BA:
+  js:
+    solved:
+        all: "sve"
diff --git a/config/locales/client.ca.yml b/config/locales/client.ca.yml
index c1cd4ef..3785155 100644
--- a/config/locales/client.ca.yml
+++ b/config/locales/client.ca.yml
@@ -15,3 +15,5 @@ ca:
       title: "Solucionat"
       accepted_answer: "Solució"
       solution: "Solució"
+        all: "tots"
diff --git a/config/locales/client.cs.yml b/config/locales/client.cs.yml
index de2509c..d142d86 100644
--- a/config/locales/client.cs.yml
+++ b/config/locales/client.cs.yml
@@ -19,3 +19,8 @@ cs:
       unaccept_answer: "Tato odpověď již neřeší tento problém"
       accepted_answer: "Řešení"
       solution: "Řešení"
+        all: "vše"
+    topic_statuses:
+      solved:
+        help: "Toto téma má řešení"
diff --git a/config/locales/client.da.yml b/config/locales/client.da.yml
index dc14ff1..11ab310 100644
--- a/config/locales/client.da.yml
+++ b/config/locales/client.da.yml
@@ -11,3 +11,8 @@ da:
       allow_accepted_answers: "Tillad ejer af emne og stab at markere svar som en løsning"
       accepted_answer: "Løsning"
       solution: "Løsning"
+        all: "alle"
+    topic_statuses:
+      solved:
+        help: "Dette svar har en løsning"
diff --git a/config/locales/client.el.yml b/config/locales/client.el.yml
index 63bf4b0..b1ca4c3 100644
--- a/config/locales/client.el.yml
+++ b/config/locales/client.el.yml
@@ -5,4 +5,8 @@
-el: {}
+el:
+  js:
+    solved:
+        all: "όλα"
diff --git a/config/locales/client.et.yml b/config/locales/client.et.yml
index 6338637..df5d9ea 100644
--- a/config/locales/client.et.yml
+++ b/config/locales/client.et.yml
@@ -16,3 +16,8 @@ et:
       has_no_accepted_answer: "Sellel teemal pole lahendust"
       accepted_answer: "Lahendus"
       solution: "Lahendus"
+        all: "kõik"
+    topic_statuses:
+      solved:
+        help: "ellel teemal on lahendus"
diff --git a/config/locales/client.fa_IR.yml b/config/locales/client.fa_IR.yml
index 49cf912..fee635b 100644
--- a/config/locales/client.fa_IR.yml
+++ b/config/locales/client.fa_IR.yml
@@ -18,3 +18,8 @@ fa_IR:
       accepted_answer: "راه حل مورد قبول"
       solution: "راه حل"
       accepted_html: "{{icon}}<span class='by'>توسط<a href data-user-card='{{username_lower}}'>{{username}}</a></span> در <a href='{{post_path}}' class='back'>پست {{post_number}}</a>حل شد. "
+        all: "همه"
+    topic_statuses:
+      solved:
+        help: "این موضوع راه حلی دارد"
diff --git a/config/locales/client.fi.yml b/config/locales/client.fi.yml
index 35cd7c4..ac64154 100644
--- a/config/locales/client.fi.yml
+++ b/config/locales/client.fi.yml
@@ -24,3 +24,8 @@ fi:
         other: "ratkaisut"
       accepted_html: "{{icon}} <span class='by'><a href data-user-card='{{username_lower}}'>{{username}}</a></span> ratkaisi <a href='{{post_path}}' class='back'>viestissä #{{post_number}}</a>"
       accepted_notification: "<p><span>{{username}}</span> {{description}}</p>"
+        all: "kaikki"
+    topic_statuses:
+      solved:
+        help: "Tämä aihe on ratkaistu"
diff --git a/config/locales/client.gl.yml b/config/locales/client.gl.yml
index 695b5cf..8996954 100644
--- a/config/locales/client.gl.yml
+++ b/config/locales/client.gl.yml
@@ -5,4 +5,8 @@
-gl: {}
+gl:
+  js:
+    solved:
+        all: "todo"
diff --git a/config/locales/client.he.yml b/config/locales/client.he.yml
index 014e07b..e37cda6 100644
--- a/config/locales/client.he.yml
+++ b/config/locales/client.he.yml
@@ -14,6 +14,22 @@ he:
     solved:
       title: "נפתר"
       allow_accepted_answers: "אפשר למשתמשים לאשר תשובות"
+      accept_answer: "יש לבחור בזה אם התגובה הזאת פותרת את הבעיה"
       has_no_accepted_answer: "לנושא הזה אין פתרון"
-      accepted_answer: "קבל תשובה"
+      unaccept_answer: "יש לבטל את הסימון אם התגובה הזו אינה פותרת עוד את הבעיה."
+      accepted_answer: "פתרון"
       solution: "פתרון"
+      solution_summary:
+        one: "פתרון"
+        two: "פתרונות"
+        many: "פתרונות"
+        other: "פתרונות"
+      accepted_html: "{{icon}} נפתר <span class='by'>על ידי <a href data-user-card='{{username_lower}}'>{{username}}</a></span> ב<a href='{{post_path}}' class='back'>פוסט מס׳ {{post_number}}</a>"
+      accepted_notification: "<p><span>{{username}}</span> {{description}}</p>"
+        all: "הכול"
+        solved: "נפתר"
+        unsolved: "בלתי פתור"
+    topic_statuses:
+      solved:
+        help: "נושא זה נפתר"
diff --git a/config/locales/client.hu.yml b/config/locales/client.hu.yml
index fe3de7d..b66388d 100644
--- a/config/locales/client.hu.yml
+++ b/config/locales/client.hu.yml
@@ -21,3 +21,8 @@ hu:
       solution: "Megoldás"
       accepted_html: "{{icon}} Megoldva <span class='by'><a href data-user-card='{{username_lower}}'>{{username}}</a> által, </span>ebben a témában: <a href='{{post_path}}' class='back'>{{post_number}}</a>"
+        all: "Összes"
+    topic_statuses:
+      solved:
+        help: "Ez a téma tartalmaz egy megoldást"
diff --git a/config/locales/client.id.yml b/config/locales/client.id.yml
index 78a6c25..c93d8b5 100644
--- a/config/locales/client.id.yml
+++ b/config/locales/client.id.yml
@@ -11,3 +11,6 @@ id:
       alt:
         solved:
           accepted_notification: "Diterima"
+    solved:
+        all: "Semua"
diff --git a/config/locales/client.ja.yml b/config/locales/client.ja.yml
index eb6fc21..497c640 100644
--- a/config/locales/client.ja.yml
+++ b/config/locales/client.ja.yml
@@ -7,5 +7,26 @@
 ja:
   js:
+    notifications:
+      alt:
+        solved:
+          accepted_notification: "受け入れられました"
     solved:
       title: "解決"
+      allow_accepted_answers: "トピックオーナーとスタッフにリプライを解決策としてマークすることを許可する"
+      accept_answer: "このリプライが問題を解決したか選択してください"
+      has_no_accepted_answer: "このトピックは解決策がありません"
+      unaccept_answer: "このリプライがもはや解決策でないなら選択を外してください"
+      accepted_answer: "解決策"
+      solution: "解決策"
GitHub sha: 24789547
